Author Topic: backfire at idle..  (Read 16588 times)
walter
backfire at idle..
« on: February 25, 2013, 10:54:17 AM »
! Private video
what do you think? engine is z6 vitara/eagle, ignition map at idle is set at 16.5º, i assume i should increase that due to low compressiont but idk if backfires will be for this. Car is not runs in the street yet.
what do you think?
Re: backfire at idle..
« Reply #1 on: February 25, 2013, 12:06:36 PM »
Did ya check your firing order?
By the way your video is private, I do not have a youtube account to look at it.  :noel:
walter
« Reply #2 on: February 25, 2013, 01:47:23 PM »
yeah, everything is ok, check vid again plz. thanks!
« Reply #3 on: February 25, 2013, 06:30:46 PM »
You sure that is backfiring?
Sounds more like it might be a slight misfire to me.
« Reply #4 on: February 25, 2013, 08:24:22 PM »
what are you tuning with? crome? occasionally i get a car that does that. havent found a way to get rid of it yet
« Reply #5 on: February 26, 2013, 01:42:36 AM »
WHere are the afrs?
walter
« Reply #6 on: February 26, 2013, 10:35:54 AM »
Hi, engine sounds great, just sometimes it misfire/backfire.. idk if a stock base timing will cause that..
AFR is ok. 13.8-14 solid.
another video.
20130222_204732.mp4
thanks for replies.
P.S i know TB is to tight  :noel:
« Reply #7 on: February 27, 2013, 06:35:02 AM »
Stock injectors or firehose?
Most large injectors won't work *perfect*. I look at it this way - if the problem is only at idle, DONT LET IT IDLE! Post ripper vids already!! :P
walter
« Reply #8 on: February 27, 2013, 07:17:26 AM »
using 550cc evo injectors.. i will do it soon!!.
« Reply #9 on: February 27, 2013, 07:49:21 AM »
I have never tuned those, but if they are anything like dsm 450's then that's your problem. I hate trying to idle dsm 450's. I always get stock idle and drivability with my tunes, but dsm injectors make me look bad
Speed Phreak
  • I'm an OG because I say so.
« Reply #10 on: February 27, 2013, 10:27:35 AM »
I honestly don't hear anything that sounds problematic, I've had stock cars idle worse. The g/f's SRT4 that sits in the yard is bone stock and doesn't sound that smooth at idle, I think you're fine personally.
1988 CRX HF - Turbo deathtrap
« Reply #11 on: February 27, 2013, 11:07:47 AM »
It's a dodge. I have never heard of more idling issues with a brand like I have dodge.
Speed Phreak
« Reply #12 on: February 27, 2013, 11:15:04 AM »
Lol, I didn't say it was a good example.
« Reply #13 on: March 01, 2013, 12:13:54 AM »
They use Deka IV injectors, they aren't fantastic but better than old pintle style injectors.
Walter I'm in the process of making a whole bunch more 900cc sets, so I'll be getting you some pics soon.
« Reply #14 on: March 05, 2013, 10:05:06 PM »
Wes got 42mpg off of 500cc SRT-4 injectors in his turbo wagon.  Fuck all of you.
« Reply #15 on: March 06, 2013, 01:47:32 AM »
I got 37mpg on my turbo EF with 780cc Deka 1's. On uberdata. The srt-4 has 8-hole caps, but nearly all others use 2 or 4 holes. Jeep guys rave about upgrading to EV6 4-hole injectors over the Deka 4's, which is a half-decade older design.
