Pages: 1 ... 6 7 [8] 9   Go Down
Author Topic: Ohisofly's 91 Crx  (Read 356588 times)
ohisofly
Re: Ohisofly's 91 Crx
« Reply #210 on: September 26, 2018, 02:47:53 PM »
Honda oil pump, water pump, tensioner, rear main, etc.
Punched out old valve guides
The only reason I put new valve guides in is that two of them looked like this:
Bronze ferrea valve guides installed
H22 clutch reservoir cut and welded to change the mounting angle
Had to order this 90 degree banjo fitting due to clearance issues
Added vtec to the ecu
Tucked driver's side headlight harness
Removed the evaporator
After removing the evaporator I reinstalled the empty box
A/C harness
Tucking passenger side headlight and fuse box harness
Tucked wiper motor harness
Everything sectioned and necessary wires extended
Headlight and fuse box harness pushed back through the firewall
To be continued
91 Crx Si - turbo ls vtec
« Reply #211 on: September 28, 2018, 12:18:35 AM »
Looks good. I remember doing my tuck and saying to myself this is the dumbest thing I've ever decided to do to a car. But it sure looked nice when it was done.
« Reply #212 on: September 30, 2018, 03:10:47 PM »
Looks good man
ohisofly
« Reply #213 on: October 24, 2018, 06:51:02 PM »
Wiring continued
Leaving this fender off for now because I still need to run the battery wiring
This is going to change because I'm probably mounting the msd box is this area too
Ready to go in
Even with the 90 degree fitting I still had to do a good bit of hammering for it to fit properly
Put back together
Ended up having to redo this
There wasn't enough room in between the tank and bungs to get good welds
Round 2
Still need to weld on a -8 bung for the return so just used primer for now
Stock fuel lines out
Previous owner used this as a db drag car  ::)
Ultimately used 40 pounds of dry ice. If there wasn't any dynamat the stock sound deadening would probably come out with 5 or 10 pounds.
This is 40 pounds, when it's said and done it'll be closer to 50
Painted filler neck and cover
Hopefully this weekend I can finish removing the sound deadening and get the interior painted / put back together
« Last Edit: October 25, 2018, 01:00:14 PM by ohisofly »
ohisofly
« Reply #214 on: November 06, 2018, 09:41:54 PM »
Removing dynamat continued
Rust spots after the wire wheel
Primer & paint
I'm not sure what this blue stuff is, seems like a spray on rhino lining type of thing. It came off slowly if you chipped at it but after my third trip to get dry ice it was good enough for me
Floor & trunk all painted
Carpet and rear interior partially back together
Added a -8 bung for the return
Painted it
Put this craft foam on the top to prevent noise. I put a bolt where the stock feed banjo goes and bent the return tube shut on both sides
Picked the head up last Friday, they checked it for flatness & it's good just has some knicks in it here and there. Valve guides are reamed out, should be ready to put back together now
« Last Edit: November 06, 2018, 09:56:46 PM by ohisofly »
ohisofly
« Reply #215 on: November 28, 2018, 04:16:02 PM »
Added a banjo to ¼” barb fitting for the breather
Used an eg evap valve
Tank in
Pumps & pre-filters
Couldn’t find a great spot to easily mount the fuel pumps so ended up making this bracket. It goes right between the tank and driver’s side rear trailing arm
After primer and paint
Mocked up
Starting to run the lines
Used this grommet from the stock fuel lines to run the power wires to the fuel pumps
Area behind the glovebox
Riveted some 16-gauge steel I had to it
Mocked up minus the fuel pump relays
Wiring everything up
Mostly finished
This is how I wired up the pumps, used a delay relay set to 2 seconds for the second fuel pump
Stock ls distributor
Coil removed
Wiring it up for the external coil
Stock coil vs blaster hvc coil
This is how I wired up the MSD, still need to figure out where I want to mount the new coil
Primer & paint for the coolant tube on the back on the block
Bought some Ferrea 6000 valves & dropped the head off at the machine shop for a valve job. While I’m waiting for the head to be finished I’ll be wrapping up the fuel lines and wiring
ohisofly
« Reply #216 on: December 05, 2018, 03:48:08 AM »
Picked up the head from the machine shop, got a 3 angle valve job & head was decked .004"
Ferrea 6000 valves, bronze valve guides & keepers
Supertech 85 lb springs and steel retainers
Blox lma
Made a bracket to move the proportioning valve to the firewall
Primer
Paint
While making more fuel line ended up snapping this fitting, currently waiting on another one
This is the section I was tightening, it was the adapter from one of the fuel pump outlets to -10 an
Making a mount for the coil
My brother is a welder, he wasn't home so I used his mig. It's pretty obvious I have no idea what I'm doing  O0
After Grinder
Primer
Paint
All bolted & wired up. I tried using the top left stud for the ecu but ended up just making a hole where that stud was and using a bolt & nut. You can't see it but the ground for the coil is directly under it which just grounds the coil to the bracket/body
Drilled out the rivets for the valve cover baffling
Used a m6x1 tap so I can use bolts to put it back together. I'll be using red loctite
Used a carbide bit to grind down two bolt holes on the front of the valve cover. I forgot to take a finished picture
Before
During
After
I'll get some better pictures but I ended up using an aluminum 3/4" tube for making the holes
Next on my list is getting this valve cover welded up, finish some wiring and then messing with the engine
ohisofly
« Reply #217 on: December 14, 2018, 02:13:43 AM »
Small update - worked on the valve cover bungs
Welded on the inside and out
Forgot to get a picture before the jb weld but just used this to make it look a lot better
One down, one to go. Used a file and then 150 grit to clean it up. Still has a little bit to go before it's ready for paint
I bought this for $5, intended on putting this on top of the steering column piece as that's where I want the gauges
After some trimming, it was clear that it was still going to block way too much of the center of the gauge cluster. This is an issue because I'm ultimately going to place the tunerview display here
It also looks like this gauge pod would have a similar issue albeit not as bad
I ended up going this route, notched out the upper corners and then jb welded the gauges to the top steering column piece
For the time being, I'm temporarily mounting the tunerview where the radio was. Here's making the plastic cover for it
I think it turned out alright
Finished cleaning up the wiring to the battery and front of the bay. Still need to make or purchase a battery mount, going with a pc680 style battery
Just received this from tristate
Current wiring situation
Almost finished, I still need to wire up my oil pressure sensor, fuel pressure sensor and flex fuel sensor. Sent my cams out for the delta 272 regrind and ordered stuff to degree the cams, once all of that arrives I can start measuring clearances and putting the head together
« Reply #218 on: December 16, 2018, 09:20:13 PM »
Dope! Looks good
ohisofly
« Reply #219 on: December 18, 2018, 02:34:36 AM »
Dope! Looks good
Thanks man
Painted the bay this past weekend
Scuffed everything with a scotch brite pad. I didn't go too crazy trying to make it perfect as someday I'll probably shave the bay, just wanted to clean it up for now
Two coats of rustoleum primer
First two coats of rustoleum gloss white
This is after the third coat but I ended up doing four in total
I ordered some spraymax 2k clear so this weekend I can finish it up
Made a cardboard template for the catch can, it'll go where the windshield washer reservoir was
The side against the car has this notch in order to sit flat
Got some kirkeys, still waiting on the seat covers
« Reply #220 on: December 24, 2018, 11:51:34 AM »
love the kirkeys O0
« Reply #221 on: December 31, 2018, 09:57:16 AM »
FUCK havent check in, in a long time; and this car has come a LONG way. Solid work! :noel:
ohisofly
« Reply #222 on: January 02, 2019, 03:01:51 AM »
love the kirkeys O0
Ty :) My stock driver's side seat was pretty beat up with a bunch of metal/foam showing so figured it was time to bite the bullet and get these
Thanks man, it's getting there little by little. 2019 should be a good year
Not much progress lately with Christmas & New Years but here's some pics anyways
Seat covers came in the mail
Installed a gates 170 degree thermostat
My front rims came in the mail, 15x10 with 5.5" backspacing. I need to clean up some of the weld splatter on them before getting them powdercoated
Finally got around to clear coating the bay
Came out pretty good, far from perfect but I'm happy with it
GM flex fuel sensor with 8 an fittings
Here's the ground for the flex fuel sensor and oil pressure gauge
This is my 12v source at ignition on and run for the boost controller and oil pressure gauge
Removing more dynamat
Didn't get a picture after it was removed from the door panel but you get the idea. If I get bored I'll end up doing the passenger's side door as well
Finished welding the an fittings on the valve cover. They were welded on both the outside and inside to make sure they're solid
I originally wanted to use m6x1 10mm bolts to bolt down the baffle but it didn't end up working as well as I anticipated. Ultimately I ended up using 3/16" x 1/4" aluminum rivets, I was a little skeptical at first but it ended up being really solid. Hondabond was used in between the baffle and the valve cover. You can see some of the holes are missing rivets, this is due to those holes being too shallow for the rivets (wasn't enough material to drill the holes any deeper)
Here's the valve cover as of now, I'm going to use some normal jb weld epoxy to fill in the small pits that I currently have. I used the jb weld 'steelstik' which is basically a 2 part putty for everything so far. I've seen mixed things about powder coating over jb weld so I'll see if my powder coater is comfortable with it or not. If not I'll probably just spray paint it
ohisofly
« Reply #223 on: January 07, 2019, 02:18:11 AM »
Got my Delta 272 cams back
New toy
Had to replace a connector for all the wires I added going to the ECU
Cracked climate control
Jb welded it back together and then put this plate on it
Thicc
Used some normal jb weld to fill in the small holes/imperfections (used jb weld steelstik originally). Still need to sand it down
Didn't take any pictures but also got the mig splatter off the 15x10 rims. Mainly just used a chisel to chip the splatter off and then sanded it smooth. Front & rear rims are packed up ready for powdercoating, now just need to finish the valve cover
« Reply #224 on: February 11, 2019, 09:34:12 AM »
This is good motivation for me to get my crx going again!
ohisofly
« Reply #225 on: March 07, 2019, 04:03:05 PM »
Good to hear man  O0
It’s been a little while but here’s what I’ve been up to
Measured the valve to valve clearances
Have plenty of room for adjustment
Had to file down a washer to get the degree wheel to fit properly
Installed bbs to lock vtec, used check valve springs, and bent a coat hanger to reference against the degree wheel. After putting the timing belt on and setting up the dial indicators I degreed the cams and measured piston to valve clearances
I've seen various figures on what's considered safe minimum p2v clearance but even going conservative with a minimum .100 or .080 still allows for plenty of room to play with cam adjustment. Degreeing them put it at -1, -1 which seems reasonable given the decked head & block
Then I started putting together the head, OEM valve seals
Supertech 85 lb springs, supertech steel retainers, blox lmas
Ferrea 6000 std valves and ferrea keepers
Head ready to bolt down
RHMT
ARP headstuds
Bolted down
Delta 272 cams
Redoing the valve cover
Not perfect but it’ll do
New timing belt covers & gaskets
I accidentally got the wrong bottom cover so had to shave the bottom a little bit. It doesn’t sit flush against the oil pump at the bottom but close enough
Covers on
Started working on my transmission again, the youtube video I was following had the orientation of the 3/4 hub & slider upside down, causing everything on the mainshaft to be off a little bit. The case ultimately was maybe 2 or 3mm from closing
You can see the bearing on the mainshaft isn't down the whole way
The hub & slider being upside down caused this needle bearing to be off, hence pushing up everything on the mainshaft
Took everything apart and cleaned it since it’s been sitting for maybe 6 months or so
All back together, replaced the 5th gear cuff mainshaft bearing as it was a little rough
I still need to find the c-clip that holds the countershaft to the case and the axle seals but it’s almost finished
Skunk2 70mm throttle body
Installed with a thermal gasket
Speedfactory 4bar map sensor
This is how it’s sitting right now
Currently waiting on new vtec solenoid gaskets and need to find the transmission seals that I have somewhere. Hopefully in the next few weeks I’ll be able to get the motor and trans dropped in so I can finish wiring the engine bay and start working on the turbo setup. Planning on a divided top mount manifold
ohisofly
« Reply #226 on: March 12, 2019, 10:41:41 AM »
I don't need this coolant port anymore
Welded it shut
Don't need this small one on the top either
Only the port nipple itself was steel, the rest is aluminum. Forgot to get an after picture but it doesn't look good. It's watertight though which is all that I really care about
Starting to look like an engine. Mocked up the fuel filter, fuel rail, fuel pressure regulator and injectors. Ended up ordering some fittings I'll need to complete the fuel lines but it's looking good overall
Ordered a new distributor connector because this one is toast
New vtec solenoid gaskets
I ordered new axle seals for the transmission, should be able to bolt together the case this weekend. Once that's finished just need to put on the twin disc and drop it in. I ordered a bunch of pipe for the turbo manifold which should be here next weekend as well
« Reply #227 on: March 22, 2019, 01:03:03 PM »
fucking magestic
« Reply #228 on: March 23, 2019, 06:25:32 PM »
Nice!!  :noel:
ohisofly
« Reply #229 on: April 11, 2019, 03:46:47 PM »
Thanks guys  :)
Finishing up the transmission with new seals
Old throwout bearing
Old vs new
New bearing in with Honda urea grease
Ready to go back together
SpeedFactory heavy duty detent springs
Transmission finally all finished
New front bumper
Hasport mounts
2.75" intercooler piping
Piping to make the manifold, treadstone 1.5" schedule 10
1/2" thick mild steel divided t4 flange
Head flange that adapts the head port to 1.5"
4" vibrant exhaust bellow for the exhaust, also have two 1.75" exhaust bellows for the wastegates
Moving on to redoing the engine harness
Removing the wire loom
Mocking everything up, kinda sorta tucking it
Along with shortening and extending wires as needed, I also replaced a bunch of connectors
Old distributor connectors
Old alternator plug, ended up changing it to an obd2 style alternator plug
Almost finished, need to bolt up the trans to finish the reverse switch and starter solenoid wire
Took the engine off the stand so I can bolt up the transmission and finish the engine harness
Hopefully this weekend I can get the flywheel & clutch setup bolted on and then after putting on the trans, it's ready to drop in
ohisofly
« Reply #230 on: April 15, 2019, 11:35:18 AM »
Finished up the engine harness
Distributor plugs tucked away down by the thermostat
Used a BRZ oil drain plug to block off the coolant fan switch on the back of the block, now the switch is on the thermostat housing
ARP flywheel bolts
Flywheel torqued down
Clutch & pressure plate on
Switching to the hush performance pull style slave cylinder
Ready to go in
Used a 9/16” drill bit to drill out the bottom two holes of the t-bracket, as the t-bracket was originally for a cable transmission
Moved the fuel filter here next to the t-bracket
Ready to go in
Mission accomplished
Plenty of room back here
Time to party
« Reply #231 on: April 15, 2019, 04:16:06 PM »
Fuck yea
« Reply #232 on: April 25, 2019, 01:15:44 AM »
Yeah!
ohisofly
« Reply #233 on: May 30, 2019, 07:58:25 PM »
Thanks guys  :)
Small update, here's the hush performance pull type slave cylinder
Starting point, already drilled out the hole in the clutch fork for the slave cylinder to attach
Put this jam nut in
Then put the slave cylinder on
Tighten everything down, keeping in mind that there's adjustment with the jam nut and heim joint depth
Ready to go
And a pic of the fuel filter for those curious about clearance
Right now I'm waiting for some an fittings to arrive so I can finish the fuel lines and clutch line. I'm also doing my best to figure out how the intercooler and turbo setup are going to fit without hacking up the front bumper too bad. Didn't get a picture with the bumper on but I mocked it up to see what space we have to work with
carkrazed
« Reply #234 on: May 31, 2019, 01:13:33 PM »
Nice work bro! Super clean. What kind of power you aiming for?
I had a 91 SI back in the day. Built ZC with a bunch of nitrous. Car was a blast. Always wanted to get another.....
ohisofly
« Reply #235 on: June 01, 2019, 11:59:47 PM »
Thanks man, appreciate it  :) shooting for 700hp, wish me luck
That sounds like fun  O0 I definitely have the ef bug
walter
« Reply #236 on: June 05, 2019, 07:35:53 PM »
really nice! did you replace yourserlf valve guides? im looking for some neway tools for to replace valve guides then reface valves and valve seats.
ohisofly
« Reply #237 on: June 08, 2019, 06:59:42 AM »
Yea I replaced them myself, I used a 5.5mm valve guide drift punch that was apparently designed for removing motorcycle valve guides, but it worked great.
I basically followed what this guy did --> https://www.youtube.com/watch?v=f2VkImRi2QI
One issue I had was that the valve guide drift punch I got off eBay seemed to be pretty cheap, so I accidentally snapped the skinny tip of it off while punching out the valve guides to begin with. You definitely want a soft aluminum washer/spacer or something in between the valve guide and the valve guide drift punch to soften the impact between both parts. I saw some people on youtube that used an air chisel to get the valve guides out but I didn't have any luck with that, I think because of my air compressor and air chisel being from harbor freight :)
The second issue I had was that half of the valves didn't fit into the valve guides after I punched the new bronze valve guides in, it was either all of the intake valves or all of the exhaust valves, I don't remember. I ended up taking my head to the machine shop so they could work their magic and ream out the inside of the valve guides to make them fit. Also, keep in mind that the valve guides for the intake and exhaust can be different (or at least were with this engine), so make sure you keep track of which is which. I believe the height on the valve guides was different between the exhaust and intake on mine.
« Last Edit: June 08, 2019, 07:12:16 AM by ohisofly »
ohisofly
« Reply #238 on: July 17, 2021, 03:57:37 PM »
Glad the forum is back online  O0  Got this thing up and running, no dyno numbers yet but I probably have 100 miles on it or so. I need to iron out a handful of things before it's ready to go on the dyno so it'll still be a little while
« Reply #239 on: July 17, 2021, 05:09:22 PM »
Sweet!!!!    :noel:
Pages: 1 ... 6 7 [8] 9   Go Up
