Author Topic: modifying IC  (Read 37820 times)
walter
modifying IC
« on: February 19, 2014, 06:51:43 PM »
Hi, im looking for to install this in a Civic Ep 02-05.
So i was wondering if it will works to put in and out in the same side.. i know the other option will be like this:
this is what i means.
What do you think?
Re: modifying IC
« Reply #1 on: February 19, 2014, 07:41:52 PM »
bottom pic only works if the top and bottom of the core is seperated inside the end tank
Re: modifying IC
« Reply #2 on: February 20, 2014, 12:13:23 AM »
I have a cx motor sports intercooler that is backdoored on each end. It's a pretty big radiator blocker. It's a thick core. 2.75" or 3" thick I think. If you have any cooling issues with the car do not buy one. It made my crx over heat because there simply wasn't enough airflow. But on my dc integra it's fine.
walter
Re: modifying IC
« Reply #3 on: February 20, 2014, 05:47:38 AM »
what i thought , ok , thanks.
Ratcityrex, you meant water radiator..this is for IC.
Re: modifying IC
« Reply #4 on: February 20, 2014, 02:29:00 PM »
I understand that it's is for cooling your air. What I'm saying is that the core of the intercooler is so thick that it blocks airflow to your radiator and and your radiator doesn't cool the water very well. But you will probably be fine since it's in a ep civic. And not a ef crx.
walter
Re: modifying IC
« Reply #5 on: April 12, 2014, 07:32:24 PM »
this is what i finally did..
n/a mike
  • Mr. Hotpocket
Re: modifying IC
« Reply #6 on: April 12, 2014, 10:04:56 PM »
Well I like it  :noel:
Re: modifying IC
« Reply #7 on: May 26, 2014, 09:45:20 PM »
Bueno job walter  :noel:
walter
Re: modifying IC
« Reply #8 on: May 28, 2014, 07:44:34 PM »
thank you!  :)
