Author Topic: TYPE R VS TYPE R INTAKE GSR EXHAUST  (Read 7225 times)
99gsrturbo
« on: April 28, 2014, 11:18:34 AM »
I ended up with a free set of Integra type R cams, I plan on replacing my GSR cams with them. I have been doing some research into running a Type R intake and GSR exhaust. Has anybody done this and does it give you a better curve or even more power over running just type R?
Motor is fully build 11:1 sleeved
6262 is turbo 20psi
ported head with valve train
Re: TYPE R VS TYPE R INTAKE GSR EXHAUST
« Reply #1 on: April 28, 2014, 11:37:06 AM »
I would leave the gsr valves.
« Reply #2 on: April 28, 2014, 12:16:37 PM »
think he is asking about cams... not valves..
« Reply #3 on: April 28, 2014, 01:11:03 PM »
Run both itr cams
« Reply #4 on: April 28, 2014, 02:05:45 PM »
99gsrturbo
« Reply #5 on: April 28, 2014, 03:25:25 PM »
OK, I will run both type R cams it is. I should have them installed on sunday. Then its back to a street tune.
« Reply #6 on: April 28, 2014, 06:17:46 PM »
The idea of running only the hype-r intake cam came from people being cheap n only buying one cam, instead of both.
99gsrturbo
« Reply #7 on: April 28, 2014, 11:57:41 PM »
Thanks for the input. As i stated before i will be installing both of them on sunday.
