Author Topic: 80lb siemens deka injectors on GSR?  (Read 10488 times)
krazy4
Re: 80lb siemens deka injectors on GSR?
« Reply #1 on: February 22, 2017, 11:06:07 AM »
never had, bu that is a good price for them.
chinewalker
  • N00B *Read Intro Sticky*
« Reply #2 on: February 28, 2017, 06:23:07 PM »
I used some adapters from xenocron to fit the fuel rail and Some threaded rod to mount the rail higher.
« Reply #3 on: March 01, 2017, 02:15:18 PM »
They are relatively inexpensive cores that have poor linearity below 1.7ms and aren't flow matched for shit.  Not a big deal on ethanol, but you can expect  to idle them rich if you want a good idle.
For anything that doesn't require complex injector data (99+ GM, 98.5+ Ford) HiProfile's IN900s are a much better value.
