Author Topic: post up your J-B fab  (Read 34191 times)
lilpooh21186
« on: May 12, 2009, 01:43:20 AM »
whats Rhmt without some good ole jb-weld post up your jb-fab's
i couldnt source the correct freeze plug to delete the breather box so i jb-fabbed some shit up basicly i took a plug from were i installed the breather nipples hacked up the box and jb'd it into the hole. ill have to update with it in the block
i wanted to breath out the valve cover
added a fitting to my prev catch can
Ecu chipping
basmaps
Travis
Re: post up your J-B fab
« Reply #1 on: May 12, 2009, 01:55:14 AM »
wrong section, fuck naut
« Reply #2 on: May 12, 2009, 02:54:53 AM »
excellent work none-the less
lilpooh21186
« Reply #3 on: May 12, 2009, 09:02:37 AM »
damn figured it would get more traffic in GD post up your jb-fab
Ecu chipping
basmaps
« Reply #4 on: May 12, 2009, 11:15:03 AM »
Good shit!   ;D
Who gives a fuck if it posted in the wrong section!
Its got J-Bweld....
« Reply #5 on: May 12, 2009, 11:16:57 AM »
Good shit!   ;D
Its got J-Bweld....
I would post if J-B weld wasn't too baller.  ;D
J K
txdohczc
« Reply #6 on: May 12, 2009, 05:49:54 PM »
this is th oil return for my zc turbo crx
« Reply #7 on: May 12, 2009, 09:07:32 PM »
« Reply #8 on: May 12, 2009, 09:30:20 PM »
 ;D
Im sitting here lmao.
« Reply #9 on: May 12, 2009, 09:31:13 PM »
lilpooh21186
« Reply #10 on: May 12, 2009, 09:54:32 PM »
that is the shit my new backround
Ecu chipping
basmaps
« Reply #11 on: May 12, 2009, 11:06:59 PM »
JB weld FTW!!  I repaired a gas leak on a gas line near the tank and it works perfect. I have another leak directly on the tank when I full it and I plan to JB weld it.
I want a gallon of JB WELD!!
lilpooh21186
« Reply #12 on: May 13, 2009, 12:40:27 AM »
hell yea jb is strong a fuck can fix almost anything
Ecu chipping
basmaps
civiceggturbo
« Reply #13 on: May 13, 2009, 02:57:18 AM »
not jb weld buy close
« Reply #14 on: May 13, 2009, 06:48:29 AM »
Please tell me that is not a fuel pump....
blacksol4life
« Reply #15 on: May 13, 2009, 04:35:34 PM »
i think soooo
txdohczc
« Reply #16 on: May 13, 2009, 04:48:06 PM »
there was a guy along time ago in the old hmt that fucked up grinding down the webbing of the block to clear the turbo and ground a hole in the block then jb welded the hole shut
« Reply #17 on: May 13, 2009, 05:19:07 PM »
RHMT style drain. Haha
« Reply #18 on: May 13, 2009, 08:32:25 PM »
The only way!
« Reply #19 on: May 13, 2009, 09:52:12 PM »
A/C line on the high side had a leaky connection
Filled the plug on the compressor with JB cause I didn't have a fitting to plug it
Oil drain
Fixed a leaky diesel fuel return line on a 74' ford 4500 with JB too.
crx-ecutioner313
« Reply #20 on: May 14, 2009, 03:46:14 AM »
nice ive never seen a gallon of jb not do its job maybe a pint of super glue and a role of duck tape or... better yet give zack hutton a call he is the macgyver of casper wyoming well know for his submersable pickup
Evan
« Reply #21 on: May 14, 2009, 07:46:36 AM »
 :noel: :noel: :noel:
drivin96
« Reply #22 on: May 15, 2009, 05:28:10 PM »
came out to my car the other morning to find half my oil on the ground and a hole in my oil pan....
« Reply #23 on: May 15, 2009, 09:38:02 PM »
^^ I have to do the same thing tomorrow. I'll do my turbo oil drain while I'm at it.
« Reply #24 on: May 15, 2009, 10:04:18 PM »
The only way!
True that, fuck having someone weld that on. I tapped the pan anyways with a 3/8 pipe tap. Then JB welded the shit shut
« Reply #25 on: May 15, 2009, 11:45:42 PM »
too bad paul harvey isnt still around we could have him tell one of our jb weld stories during those jb weld story/ads he always did
lilpooh21186
« Reply #26 on: May 16, 2009, 10:59:33 PM »
but what do you prefer original j-b weld or JB kwik
Ecu chipping
basmaps
drivin96
« Reply #27 on: May 16, 2009, 11:32:45 PM »
og j-b weld   ftw
jb kwik didnt work for me
BoostForLife
« Reply #28 on: May 16, 2009, 11:35:17 PM »
JB KWIK worked fine for me.
Here's my attempt at the oil pan drain bolt. Mine was stripped, so I cut that shit out of the donor oil pan and welded it in, and then covered the weld with oil pan against leaks.
« Reply #29 on: May 17, 2009, 07:41:05 PM »
Yah know they make re-plugs that probably cost less than your weld+ JB weld+ time spent on that....
