Author Topic: Newb here, Start of my build *now with goods*  (Read 29466 times)
Zerorob
« on: May 13, 2009, 09:52:00 AM »
as promised, there from a web cam, havent found the others yet, she loved to dance on webcam. higher qualitys to come
last summers fling... nothing good but something
Well ive been browsing this for a bit, figured im far along in my build i can start posting some stuff up
I suppose an informal introduction might be needed... not that any of you give a shit haha.
My names Rob, im from kingston, alot of my cars parts are from Lowerit, and another local guy with a type R ef.
i suppose on with the pictures... i know im suppost to post porn, but your gonna have to wait till i find the pics of my phyco ex girlfriend.
the damage on the what used to be good side from someone backing into it
Pretty sure the fluid is NOT suppose to look like that lol
usless stuff
started on the pedal assembly, figured since it was out, might as well freshen it up, and what better way then to do it with Grip tape from skateboards. think i got the idea from lowerit.
the gas pedal im gonna have to weld on a small piece of metal to put the tape over as you can see its kind of... well not flat
picked up a cometic head gasket, 75.5mm along with a Z6 head with aftermarket cam... dont know the lifts or anything exactly it was one of 2 cams, gonna get the specs on both shortly. and i have a feeling it has aftermarket springs and retainers as well but i could be wrong about that.
porting starts this weekend, then off to be milled to be sure its true.
Pictures of the Donner car with motor in it, and a few others, JDM D15B VTAAKK
itsssaaaaaa niiiceeee
Old motor out, pulled up all the wiring for a tuck
my clutch setup FREEBIE looks rough but its fairly new
eyeballed it up
perfect the first try
now the fun starts
the DPFI harness
starting to shave it
old head to make sure i have the right sensors plugged in along with donnar harness
at the end of the stripping, this is what im left with, tomorrow looming
and Lowerits Dildo shift knob so he calls it haha
Not SS autochrome or what ever that junk is, thicker gauge steel, not greatest but half decent quality.
« Last Edit: May 14, 2009, 11:50:09 AM by Zerorob »
Zerorob
Re: Newb here, Start of my build
« Reply #1 on: May 13, 2009, 09:53:08 AM »
Quote from: Lowerit
Id like to give a special thanks to myself and Danno....
#1) I saw the sedan at the wreckers when we dropped off the turd
the turd
#2) Danno and I convinced Blonde Brillo head Pube face to get the sedan over another car which was...errrr funky Funky...
Pube face listened..and I have to say even my ego driven mentality is impressed.. This car is gonna look tits.
Zerorob
« Reply #2 on: May 13, 2009, 09:57:47 AM »
put a NA header on it to pressure was it before it gets installed
engine harness pretty much done, injector harness is gonna be on its own
So after finding the rear tranny mount and bracket, i sandblasted them and laid a quick coat of low gloss to it. next came time to install the motor...
that didnt go so well the crank pully was gonna take out my fresh paint that seems to be fairly brittle as is. not a good thing at all. oh welllllllll it is rather chilly out
so we tried for a bit to break the pully bolt loose, and we lost, cracked the pully tho haha take that bitch pully. gonna hit it iwth air tomorrow and in she goes
now with the fun stuff the pictures....
yes im licking my clean harness lol dont ask.
yes the entire wire harness is attached to the motor aside from the injector one, which is completely separate and will be installed tomorrow
Some more quick pics of the start of my brake tuck,still gotta bleed teh system and mount the prop valve, but all the lines are run and done, camera died part way through.
Rear brake lines pulled through
front brake line done
shaved
start of the injector wire harness, its gonna run underneath the manifold and come up to each injector, later on injectors will be flipped and fuel rail notched to fit the plug
mmmm no rust me like
gonna have to change the manifold a bit, need to change the wastegate it doesnt clear the hood and i want to stay stock looking hood. gonna need an aftermarket cross member, thinking of the weir one, but might just go with hasport
the injector harness, was gonna use differnt loom, but i just want it done, didnt have time or money to spend on good loom and i had this stuff laying around aslo some fittings for the block, and oil pan
working 12 hours in brockville, but thursday should be good ill have lots of money to buy what ever im missing, also need to make a fast dump run to clean it out a bit
anyway oil pan finished today, welded and jb welded to be sure....
oil temp sensor and oil return lines
some more work done today, fuel lines, and power wires are done, just need to do grounds, and get a rad and im set.
my new suspension courtesy of Danno
inpart with dannos idea from last year, slightly refined. this is what i started with
and this is what i ended up with
i added more water so its compleatly submerged, and i... agitate it every hour or so, its already solid black, probably doesnt need to stay in there much longer, but im in no rush to install it. so there it will sit till thursday
« Last Edit: May 14, 2009, 11:57:05 AM by Zerorob »
Zerorob
« Reply #3 on: May 13, 2009, 10:00:04 AM »
sneak peak of the carpet already
some work done today, dye worked mint, it looks factory.
Some more goodies for the car
some clearance issues with the rad and manifold,
so i bought a new one....
And thats it for now, plans for the car to go Champ white, and wait till you see the exhuast im gonna be temporarily running
« Last Edit: May 14, 2009, 12:00:09 PM by Zerorob »
« Reply #4 on: May 13, 2009, 10:18:10 AM »
What is about people using portable garages. ;D
If you use those in Wyoming that garage would be shreded in less that 5 min. :o
Interesting build keep the updates coming. :yes:
Zerorob
« Reply #5 on: May 13, 2009, 10:26:33 AM »
the portable garage lasted... 8 days before the city was on my ass to take it down, but i only needed it to paint the engine bay.
i suppose the city would rather me have my car torn apart and worked on outside of a portable garage depreciating the value of the neighborhood.  oh welll haha
« Reply #6 on: May 13, 2009, 12:09:59 PM »
thats a nice fruity green for the engine bay..
doesnt beat my fruity blue bitches....
« Reply #7 on: May 13, 2009, 12:17:59 PM »
No Labia - No Care..
Post porn robbie. your FB is filled with underage girls of questionable morals...share the love.
« Reply #8 on: May 13, 2009, 01:10:10 PM »
So many words, no porn.
BenDover
« Reply #9 on: May 13, 2009, 01:43:50 PM »
where you find that ef2 front?
« Reply #10 on: May 13, 2009, 02:33:44 PM »
Holy fuck. Lots of pix, no porn  ::) Good luck with the build. Almost got mine done.
« Reply #11 on: May 13, 2009, 02:45:45 PM »
Hope you get that over spray of the windsheild. ;D
If you are painting the car championship white why do you have the engine bay painted green?
Paint the whole car that gaggle green would give that Incredible Hulk look and would other people from getting mean with you.
Because no one wants to see your car get mad. ;D
jhonda
  • BOATS-n-HOES
« Reply #12 on: May 13, 2009, 04:38:29 PM »
got to love project cars ----looks good
Zerorob
« Reply #13 on: May 13, 2009, 09:32:09 PM »
lol im just trying to find the pix of my ex girlfriend... i promise you.. there will be porn for all
Zerorob
« Reply #14 on: May 13, 2009, 09:33:55 PM »
frienbd of mine picked it up from some importer, forget who the importer was tho... but i dont see many of them go around. still need a hood tho :(
Zerorob
Re: Newb here, Start of my build *now with goods*
« Reply #15 on: May 13, 2009, 09:54:17 PM »
maybe ill go through and remove about half those pictures, didnt realize how many there were till i posted them on one page..
« Reply #16 on: May 13, 2009, 10:37:04 PM »
You and your car are both ugly especially that green...you should fit in perfectly around here. I love the grip tape on the pedals.
Zerorob
« Reply #17 on: May 13, 2009, 11:06:55 PM »
HAHAHAHAHAHA that just made my week already. lol thanks man
cocksucker you have the same phone as me
i hate it more and more every day... was good for the first year tho. probably doesnt help its been buried in sand, dropped a billion times, covered in oil all the time. all that good stuff
« Reply #18 on: May 14, 2009, 01:54:47 AM »
Nice write up, Man its hard to take pics when you are right in the middle of putting shit together.
« Reply #19 on: May 14, 2009, 08:40:58 AM »
Doesn't matter how many hot chicks robbie knows...he is always in the friend zone....  :yes:
Zerorob
« Reply #20 on: May 14, 2009, 10:17:46 AM »
haha not always... just like... 90% of the time... or maybe... 98% of the time damnit... the whole idea was hot female friends, will hook me up with there hot friends... hasnt worked out so well tho. time for a new game plan
« Reply #21 on: May 14, 2009, 10:22:28 AM »
Now that it has porn, albeit sketchy camera phone porn.
I give is a solid  O0 O0 O0 O0 out of a possible  O0 O0 O0 O0 O0
Looks like you will do fine around here.
Zerorob
« Reply #22 on: May 14, 2009, 12:00:57 PM »
haha more will come no worries :D, and there i removed almost half the pictures that are just not needed. make a bit shorter
« Reply #23 on: May 14, 2009, 12:04:55 PM »
overspray on the car
overspray still on the tranny..
Good job 1/2 ass. looks fuckin  :somb:
Zerorob
« Reply #24 on: May 14, 2009, 02:32:22 PM »
new windshield next week, fucked if i care about over spray on it,
Zerorob
« Reply #25 on: June 12, 2009, 02:11:32 AM »
trying to get to page 2 so people dont have to deal with all the poics loading that they dont want to, a bunch of progress has been done, care runs and drives on its own power no pushing or boosting it now
Zerorob
« Reply #26 on: June 12, 2009, 02:11:55 AM »
holy fack, page 2 already
Zerorob
« Reply #27 on: June 12, 2009, 02:12:56 AM »
3
Zerorob
« Reply #28 on: June 12, 2009, 02:13:08 AM »
2
Zerorob
« Reply #29 on: June 12, 2009, 02:13:21 AM »
1
