Author Topic: quick question T25 vacuum lines with mbc  (Read 12429 times)
brummy
« on: May 26, 2009, 06:31:06 PM »
So I've never used a T25 before or a turbo with a vacuum port on the comp. housing and the wg itself. I'm going to run a MBC so I can up the boost, but this extra vacuum port is throwing me for a loop. How do I hook up the vacuum lines? Do I need to have a T for the port on the comp. housing and the wg with one single line going to the mbc or do I just ignore the port on the comp. housing or what?
That Guy
  • Fast and danger
Re: quick question T25 vacuum lines with mbc
« Reply #1 on: May 26, 2009, 09:22:38 PM »
Rope
brummy
« Reply #2 on: May 26, 2009, 10:22:21 PM »
Rope
fuck yrself. I spent at least an hour searching here and the new shitty HMT and got nothing. Maybe this is something so simple that nobody feels the need to clarify, and I guess I'm just too stupid to figure it out on my own. A simple "you do 'this'" would be nice. At least I'm not asking you guys to size a turbo for me or ask how much power I can expect to make.
speedjunky01
« Reply #3 on: May 26, 2009, 10:29:57 PM »
external or internal gate??
google found this in (0.19 seconds)
brummy
« Reply #4 on: May 27, 2009, 01:10:01 AM »
It's the stock internal wg.
brummy
« Reply #5 on: May 27, 2009, 01:19:17 AM »
Got this from an EVO forum:
Would this be the correct way? So where do I T-off for the boost gauge then, is it from the wg side?
speedjunky01
« Reply #6 on: May 27, 2009, 01:23:08 AM »
you sir are a fool
i just spoon fed you info and you ask something retarded like that  . . . anywhere off the manifold is fine between the fuel reg is ok or just get a vac manifold
