Author Topic: Ignition timing on Vitara setups  (Read 46869 times)
Re: Ignition timing on Vitara setups
« Reply #30 on: July 12, 2009, 12:39:22 PM »
jagojon, is that map with the default timing shit in crome left alone?
Yes, the default timing shift hasn't been modified. I haven't changed anything on this setup page.
Is that crome gold? Mine looks nothing like that.
DmC
« Reply #31 on: July 12, 2009, 12:42:16 PM »
yeah thats gold. Sometimes I can get gold working good sometimes it doesn't
« Reply #32 on: July 12, 2009, 12:44:26 PM »
when you say antilag in crome free, are you talking about modifying and using the low side vtec off the launch?
Yes I am talking about using the last couple rows and dropping the timing all the way to -6 on the low side of vtec, adding some fuel and using "_rom_fill(0x58e6, 0x590d, 0x00); _rom_fill(0x6a99, 0x6ac0, 0x00);"
Now it doesn't bark and crack like ectune antilag, but unlike just using the two step, it will build 15psi+ at the line and do so relatively quickly.
« Reply #33 on: July 12, 2009, 12:46:15 PM »
eCtune antilag is glitchy.
Like sometimes it works sometimes it doesn't? Or just isn't linear, Or works fine for us mere mortals, but isn't perfect?
« Reply #34 on: July 12, 2009, 04:11:45 PM »
Sometimes it works and then sometimes the code gets fiddled and it doesn't work.  Of the last two cars I've tried to use it on in the last two months, one broke up horriby under load and the other would spool up great then completely bog upon launch before moving out correctly.
Dr. D-Series
« Reply #35 on: July 13, 2009, 01:00:49 AM »
Sometimes it works and then sometimes the code gets fiddled and it doesn't work.  Of the last two cars I've tried to use it on in the last two months, one broke up horriby under load and the other would spool up great then completely bog upon launch before moving out correctly.[/color]
This happened to me last year when i was having trouble at the track. Only did it on the slicks. VERY frustrated over that shit.
D16Y8-Z6.
« Reply #36 on: July 13, 2009, 05:06:19 AM »
Fucking with the fuel/timing in the high rpm eaches of the low cam map works great, though.
« Reply #37 on: July 13, 2009, 05:43:43 AM »
Anyone touched a dohc zc/vitara motor yet?
DmC
« Reply #38 on: July 13, 2009, 11:01:35 AM »
Now that sounds cool.. Do they make cams and valve upgrades for those heads?
« Reply #39 on: July 13, 2009, 01:30:38 PM »
I think hks made cams for 'em.  I'm sure you can get a set of stockers re-cut.  6.5 to 1 compression ftw...
« Reply #40 on: July 13, 2009, 01:42:19 PM »
LS intake valves are a hair over 1mm oversize, the LS exhaust valves are maybe 1/10th of a mm larger but weigh a LOT less.  The nice thing is the LS valves are the tiniest bit taller above the keeper groove, so geometry isn't thrown off a whole lot by regrinds.  IDK if there's enough meat to port out to make B20A intake valves feasible.
I know back in the 'teens they used to drop the CR down to 4:1 for turbocharging...  I bet you could push 400 on pump gas with that CR.
« Reply #41 on: July 13, 2009, 02:37:44 PM »
[/quote]
Just like the aircooled guys.
« Reply #42 on: July 13, 2009, 05:11:57 PM »
And I thought my mid 7 compression ratio was a fuckin dog out of boost.... Fuck I wonder what 4:1 would be like.
« Reply #43 on: January 31, 2010, 10:41:10 PM »
« Reply #44 on: February 01, 2010, 12:03:32 AM »
you might get some free help if someone is in a good mood but don't count on it.
especially if you haven't contributed to the community
« Reply #45 on: February 01, 2010, 04:57:38 AM »
Refer to the gentleman above me if you wonder where your posts have gone.
