Pages: 1 [2] 3   Go Down
Author Topic: EJ8 build thread. the never ending flip flopper project  (Read 51345 times)
Re: EJ8 build thread. Holset, sinktrap, etc.
« Reply #30 on: June 12, 2009, 12:41:22 PM »
Dude, just go to the jy and steal some of those fuel rail studs to replace your broken one.
I pulled some off a spare motor.. i'm just being slow about the repair because i'm so damn busy.
« Reply #31 on: June 12, 2009, 12:45:12 PM »
well, I went from the mini ram using a T3/T04E which had almost instant spool, to the sink trap using 3" up to the HX35 12cm housing, and then 2.5" down pipe.. yeah definitely a decrease in spool time, but it hauls a lot more ass after 5k rpm.
How do you distinguish between manifold and turbine/turbine housing spool characteristics in that comparison?
« Reply #32 on: June 12, 2009, 12:54:35 PM »
that was my point.. I cannot make an accurate assumption, but the bigger turbine house/wheel of the holset was obviously the biggest factor here. I would guess less than 500rpm of spool time was lost due to the J bend.
AJxr
  • i aint ur buddy pal
« Reply #33 on: June 12, 2009, 05:31:37 PM »
not daily driving. i barely drive the thing just to the track and out ripping on people on the weekend.  idk ive just always wanted to make a sinktrap.
90 hatch
« Reply #34 on: June 12, 2009, 08:40:57 PM »
friend gave me this 2row aluminum radiator today for free.. doesn't fit in the oem spot but who cares?
injectors fit nicely
waiting on my ostrich to get here
AJxr
« Reply #35 on: June 13, 2009, 10:41:04 AM »
doesnt fit because of the down pipe? i always seemed to have cooling issues with the radiator not as far front and straight in the engine bay as can be. also though i always run half damaged single core junkers that i fixed with 2 part and a small a/c fan from an eg.... haha.
90 hatch
« Reply #36 on: June 13, 2009, 01:02:16 PM »
No.. it's a custom made radiator; was a full length for an integra or something, and my buddy cut it down to half size for a customer, and it ended up not fitting right (go figure).. so he let me have it.. I believe it's a fluidyne.
I'm pretty fed up with the whole fuel injectors leaking.. I'm replacing all of the studs,nuts and upgrading to an OBD1 or 2 fuel rail. The rail i'm using is OBD0 from my CRX HF project 7 years ago. I'm not in a major rush to get it back on the road since my clutch isn't here yet any way.
« Last Edit: June 13, 2009, 01:23:53 PM by marcj »
« Reply #37 on: June 13, 2009, 09:51:15 PM »
Time to upgrade to a obd1 or 2 b16 mani ported by Chris M and a 70mm tb from him as well.
« Reply #38 on: June 13, 2009, 09:57:36 PM »
Victor X would be nice.. I've seen some huge gains from just making the switch.
my throttle body is off an S2000 (63mm) and the intake is port matched to it..
« Reply #39 on: June 14, 2009, 12:50:32 PM »
I don't think you're making enough power to justify a victor x just yet.
« Reply #40 on: June 14, 2009, 04:36:50 PM »
made a little bracket for the PLX with pipe strap, painted it flat black.. still waiting on my parts to come in to fix the fuel rail.
ostrich, dragger clutch and spool valve should be here sometime next week.
trying to sell my backdoor evo intercooler so I can go bigger.
« Reply #41 on: June 14, 2009, 06:12:50 PM »
good score on the injectors.
what brand?  they look like delphi/precision low imps
« Reply #42 on: June 14, 2009, 07:11:20 PM »
2ohm delphi.. yeah it was an awesome price. Holly sells them for 150 + shipping usually, but they had a sale going on which knocked them down a lot. I should have bought as many to resell.
« Reply #43 on: June 14, 2009, 08:26:01 PM »
toying with this idea.. notice the a/c condenser in front of the radiator.. need to find a place that does custom lines
got this full 3" thermal exhaust.. 90 bucks! now I just need a flexpipe
« Reply #44 on: June 14, 2009, 09:04:56 PM »
Vickie-X's are sexy.  It doesn't matter whether or not you *need* one.
« Reply #45 on: June 14, 2009, 11:23:13 PM »
Are you suggesting that he get a manifold because it looks sexy?
« Reply #46 on: June 15, 2009, 01:20:15 AM »
being sexy, and looking sexy, two different things.
especially when beer is involved.   :mexi:
« Reply #47 on: June 17, 2009, 06:50:41 PM »
minor updates:
LSD's dragger clutch ftw
sending this back for a Demon RTP instead  :evil:
Finally got my replacement fuel rail studs from Honda, got them in and wa-la, no more fuel leakage. so I take off hoping to see what a 15psi pull feels like, then I realize my TPS shows 0% constantly, and is causing a horrible idle surge/throttle response/etc. so I bring it back home :(
something is keeping me from getting the proper voltage. hopefully I'll get it working tomorrow; for now i've had enough.
« Reply #48 on: June 18, 2009, 12:38:55 PM »
of course it rains all day my day off, which I had planned to tune my car.. everything is setup for 15psi, might go tune part throttle any way.  >:(
btw, I used one of JD's tunes for an 880cc T70 setup, spools my turbo 1k rpm sooner! not sure why my tune was bunk. maybe the old wideband wasn't working 100% with freelog. using PLX m300 now. love it!
AJxr
« Reply #49 on: June 18, 2009, 01:06:58 PM »
damn dude... 1000 rpms earlier just from a tune? damn. our setups are going to be similar in a few months.
forged b16, 880s, holset, hah. liking this car.
90 hatch
« Reply #50 on: June 18, 2009, 01:22:34 PM »
hell yeah, it's a blast to drive  :evil:
Wicked
« Reply #51 on: June 18, 2009, 08:37:38 PM »
nice car, I am interested in the wieght on te turbo
« Reply #52 on: June 18, 2009, 11:06:09 PM »
The tune he used is a log manifold street tune, made 404 at 21 psi off a not so super T70.  A little extra fuel and conservative timing will help anything spool.
« Reply #53 on: June 18, 2009, 11:35:15 PM »
Yep, I figured that out pretty quick while tuning once. Add a little more fuel down low and retard timing and you'll get a faster spool up.
BoostForLife
« Reply #54 on: June 19, 2009, 02:47:46 AM »
I have only tuned my own car so far, so thanks for the tips. I did get my HX35 with around .90AR housing to build 6psi (no MBC, just a 6psi spring) in neutral with crome and it felt like it could do much more with a MBC installed.
At least my HX35 wont be building full boost after 5k if I mess around with the map a little more.
« Reply #55 on: June 19, 2009, 10:49:57 AM »
AR measurements do not apply to non-Garrett turbos.
Goforth should have 30+ psi antilag video off the 62-1 setup.
BoostForLife
« Reply #56 on: June 19, 2009, 11:26:07 AM »
14CM^2 housing doesn't help spool on a stock motor though.
Marcj this is a very nice RHMT setup. Hope you get the problems sorted out quick. Holset FTW.
« Reply #57 on: June 19, 2009, 11:32:00 AM »
Wasn't really a tip for you.
BoostForLife
« Reply #58 on: June 19, 2009, 12:46:39 PM »
LOL
AJxr
« Reply #59 on: June 19, 2009, 06:10:04 PM »
i hate mr. bean
90 hatch
Pages: 1 [2] 3   Go Up
