Author Topic: Chips in sleeve?  (Read 11248 times)
fishinfool88
Chips in sleeve?
« on: June 06, 2009, 03:00:12 AM »
I just received a b18a block from a friend for free minus an oilpan.  I removed the crank, rods, and pistons to a god awful smell of burnt oil.  So i figure it more than likely spun a bearing.  Main caps look good, crank looks fine, so I figure for free, I don't care if I throw it in and boost it til it blows.  The thing concerning me, is that it has a few chips out of the outer sleeve walls up top.  No apparent cracks anywhere else, a quick hone and everything eyeballed out to look good, but what would cause cracks on the outside of the sleeve where the coolant flows?  If it weren't for this, I would have no problem buying some bearings, and see what it's capable of.  I just don't want this goofy sleeve taking my freshly rebuilt head with it. I'll get pics as soon as I'm able to borrow a cam.
esi42
Re: Chips in sleeve?
« Reply #1 on: June 06, 2009, 03:13:32 AM »
Pics?
civiceggturbo
« Reply #2 on: June 06, 2009, 01:21:09 PM »
by outer sleeve do you mean the aluminum block :?:? also do you have a way to check the bore?
caged
« Reply #3 on: June 06, 2009, 11:43:47 PM »
You pulled the crank out and suspected a spun bearing because of a burnt oil smell?? ??? Burnt oil smell isn't uncommon when disassembling an engine. I haven't had a b18a apart, but are the "chips" on the outside of the bore just clearance marks for the head studs?
fishinfool88
« Reply #4 on: June 07, 2009, 04:43:19 PM »
« Reply #5 on: June 07, 2009, 04:52:52 PM »
id rock that
« Reply #6 on: June 07, 2009, 05:01:16 PM »
id run it for sure
« Reply #7 on: June 07, 2009, 11:52:08 PM »
Looks like the coolant was never maintained, but I'd run it.
fishinfool88
« Reply #8 on: June 08, 2009, 07:14:19 AM »
Deal, looks like onward to some acl race bearings, arp rod bolts, cheap ass autozone rings, and a boosted motor on the CHEAP!!!!   And carnage pics if the shtf.
esi42
« Reply #9 on: June 08, 2009, 07:19:20 AM »
If you are on the cheap, NPR rings can be had on ebay for $30 or so.
fishinfool88
« Reply #10 on: June 08, 2009, 04:21:07 PM »
Sounds good, thanks.  Any insight into bearings?   Fuck the OEM vs Race.  How bout king/acl?  I believe I can get main/rod/thrust for 105 for king, to 110 for acl.  Anyone got any input, cause I could honestly give a shit less about checking spec on some bearings and ordering by colors and numbers and shit.
« Reply #11 on: June 08, 2009, 06:21:22 PM »
+1 on NPR rings.
as for bearings. they all seem to work. ACL/King/Clievite77/...there was another one too...
« Reply #12 on: June 08, 2009, 06:50:35 PM »
sewell and JD were talking about what big name manufactures made the bearings different china auto parts stores sold and which ones were good.  I don't remember if it was on this site or the other place before the move.
« Reply #13 on: June 09, 2009, 10:45:10 PM »
That's the best looking B18A block I've ever seen, those things are ragged pieces of shit.
« Reply #14 on: June 09, 2009, 11:12:28 PM »
B18A1 or just B18A?
« Reply #15 on: June 10, 2009, 02:29:25 AM »
Who the fuck put the word filter up?
« Last Edit: June 10, 2009, 07:41:40 AM by Joseph Davis »
fishinfool88
« Reply #16 on: June 10, 2009, 04:03:01 AM »
A1, this is the only reason the dude gave me the block free, thought it was fried.
