Author Topic: help!!! i need a p30 jdm pinout  (Read 13554 times)
shogun
« on: June 10, 2009, 08:05:54 PM »
hey, im trying to plug my widband to the ecu so ectune can read afr, but i cant seem to find a pinout diagram, thank you for your help
Re: help!!! i need a p30 jdm pinout
« Reply #1 on: June 10, 2009, 10:19:35 PM »
same as a P28, or anyother OBD1 ECU....
BangBusMaster
« Reply #2 on: June 11, 2009, 01:34:03 AM »
D14
BoostForLife
« Reply #3 on: June 11, 2009, 02:46:28 AM »
D14
Usually its a thicker wire than the rest and it's WHITE at pin as stated in the quote.
« Reply #4 on: June 11, 2009, 08:27:22 AM »
I like using D12 better.
« Reply #5 on: June 11, 2009, 01:35:29 PM »
any reason why?
shogun
« Reply #6 on: June 11, 2009, 01:37:50 PM »
thanks, it doesnt change even if it is a jdm car, its a 95 sir
« Reply #7 on: June 11, 2009, 04:22:18 PM »
any reason why?
Already has a pull down resistor and filter cap, signal is smoother.  Notice EGR lift/ELD/etc don't float high without a signal run to them.
shogun
« Reply #8 on: June 11, 2009, 07:11:37 PM »
found the diagram, thanks jd for the tip d14 it is
« Reply #9 on: June 11, 2009, 07:12:57 PM »
will free log see d12?
