Cut srpings really that bad?
Of course /yourself
HHH
CRX / FAKLAD
JD&ESAP
OP is gay for involving in VW faggotry
No cut springs is da shit dawg
Author Topic: Suspension KNowledge.  (Read 36794 times)
Re: Suspension KNowledge.
« Reply #30 on: June 26, 2009, 06:09:02 PM »
Where do you get them revalved and how much does it run you, JD?
look up fat cat motorsports.  he does a ton of blistein revalveing.
yeah, for 1000$+ for a set though?
bryantaylor
« Reply #31 on: June 26, 2009, 06:17:14 PM »
$650
90 miata - t3 and megasquirt
95 mark VIII
06 GSX-R 600
 i changed my sig as per Robb
« Reply #32 on: June 26, 2009, 06:17:40 PM »
Haha, call bilstein and see how much they charge.
« Reply #33 on: June 26, 2009, 06:25:29 PM »
what i was getting at is that i can buy new ones for less than that without having to wait on turnaround time, that's all. i don't know much about the subject so i will clam up now.
« Reply #34 on: June 26, 2009, 07:25:37 PM »
You can buy new ones, but they won't be custom valved, unless you pay more.
JD, which shocks can be revalved?
« Reply #35 on: June 26, 2009, 07:39:39 PM »
Most anything can be valved.  Stock Honda ones can.
bryantaylor
« Reply #36 on: June 26, 2009, 07:45:27 PM »
95 mark VIII
06 GSX-R 600
« Reply #37 on: June 26, 2009, 10:54:34 PM »
If your willing to cut and weld.
« Reply #38 on: June 26, 2009, 11:01:22 PM »
i am talking about FCM
http://www.fatcatmotorsports.com/FCM_Bilstein_shock_revalve_core.htm
I am talking about Bilstein.  They have centers in Cali and NC.
« Reply #39 on: June 27, 2009, 12:09:17 AM »
JD did you say you built a shock dyno?
« Reply #40 on: June 30, 2009, 01:31:36 AM »
Paging Brine04 to the Ebay coils thread, brine04 ebay coil thread.
Lol
« Reply #41 on: June 30, 2009, 11:12:25 AM »
Lol
Tell the story ebay coils story.
Zarcorp
  • RAWR #2
« Reply #42 on: June 30, 2009, 05:50:58 PM »
A shorter spring is a stiffer spring, and you are a faggot.
Right.
That's the actual length of the coiled rod not free height of the spring, the way it was described last time was with an analogy about leverage, trying to bend a 1ft iron rod versus trying to bend a 4ft iron rod.
That's with a linear spring though, as said before if you cut off the "dead" coils or the ones wound tighter/ with a different diameter on a progressive spring you'd have to work out what your spring rate would be from that point on.
d-rail
« Reply #43 on: July 02, 2009, 04:51:21 AM »
Cut spring give the best ride ever............ In a porn van
