Author Topic: 1984 celica rear diff bearings removal  (Read 11039 times)
buk9tp
« on: July 25, 2009, 02:58:59 AM »
http://forums.celicasupra.com/showthread.php?t=46681
how do i get part number 41301a off the diff?
its 2 bearings on both sides..
tried cutting a beer can and weding between the bearings and plate but no luck
also tried magnet
dont have the proper tools so need to nigger rig it
buk9tp
Re: 1984 celica rear diff bearings removal
« Reply #1 on: July 25, 2009, 03:01:01 AM »
bearing puller hmmm internet stopped being gay and i looked it up will check tomorrow
unless someone can think of a way to nigger rig it
« Reply #2 on: July 25, 2009, 09:15:31 AM »
A bearing splitter is usually the tool of choice, if not break/cut the outer race, take your cut off wheel and cut the inner race as much as you can without getting the carrier, then take a chisel and split the inner race, should slide right off.
« Reply #3 on: July 25, 2009, 10:03:00 AM »
Harbor Freight Lsrge Bearing splitter, $20
E-b0la
« Reply #4 on: July 25, 2009, 01:19:08 PM »
just get the proper tool, a puller or splitter.
buk9tp
« Reply #5 on: July 25, 2009, 11:51:37 PM »
lmao ended up going to the local bumfuck autozone and they suprisingly carriedthe bearings and only had 3 instock  O0
