Author Topic: JB Weld entire exhaust?  (Read 24392 times)
Gold DA9
  • OG LURKER
« on: July 28, 2009, 07:16:49 PM »
Has anyone here dont this? Just thinking i may do it to replace a large section of exhaust for free just to get it to pass inspection.
civiceggturbo
Re: JB Weld entire exhaust?
« Reply #1 on: July 28, 2009, 07:29:36 PM »
i highly doubt that would pass, a fluxcore harbor freight welder is what 50 used?
Gold DA9
  • OG LURKER
« Reply #2 on: July 28, 2009, 08:55:53 PM »
i dunno. Was thinking about measuring under the car where its missing. and buying some piping, jb weld, and some clamps.
« Reply #3 on: July 28, 2009, 09:03:20 PM »
This thread needs to take a turn. This is retarded.
Gold DA9
  • OG LURKER
« Reply #4 on: July 28, 2009, 09:41:19 PM »
hahaha. I have been having some dumb moments as of late.
« Reply #5 on: July 28, 2009, 10:48:48 PM »
piss
Ravage70
« Reply #6 on: July 28, 2009, 11:03:01 PM »
guaranteed to work if you use pipe that slips tightly over your existing exhaust line.
Gold DA9
  • OG LURKER
« Reply #7 on: July 29, 2009, 12:20:57 AM »
thats all i really need. Its like the 90 degree bend under the car
stealthiskey
« Reply #8 on: July 29, 2009, 12:27:33 AM »
i accidentally an exhaust.  the whole thing!
Gold DA9
  • OG LURKER
« Reply #9 on: July 29, 2009, 12:58:13 AM »
you make no sense.
« Reply #10 on: July 29, 2009, 02:41:41 AM »
DO IT
« Reply #11 on: July 29, 2009, 03:27:01 AM »
oczc top mounts are jb welded
 :o
« Reply #12 on: July 29, 2009, 04:00:38 AM »
 :o
but the oc sauce makes it cure harder
Toysrme
« Reply #13 on: July 29, 2009, 07:55:17 AM »
if you had a GOOD pipe expander (not a HF POS) you could do it aways after the cat.
remember that epoxies cure & uncure with heat. i would doubt the ability of it to hold the entire thing together with the vibrations once the heat softened it any amount.
« Reply #14 on: July 29, 2009, 12:38:55 PM »
If you want to epoxy an expanded joint, you may as well do what they've done for decades. Use "exhaust clamps". It's a u-bolt with a rounded plate to bolt to, so it clamps all around. Will be close to the price of JB weld per joint, too.
BTW if you go to almost any smaller exhaust shop, they will hydralicly expand you pipes for cheap.
Gold DA9
  • OG LURKER
« Reply #15 on: July 29, 2009, 07:38:27 PM »
i remember alot about oczc. Where the hell is my original post count and og status.
I took another look under the car. The pipe looks like it broke off after the flex pipe, and the next piece to connect to is cracked about 8-10inches. So i got to replace it all. Talking to this guy the has a 2.25 to 2.5in exhaust supposed to connect to stock cat.
« Reply #16 on: July 29, 2009, 09:51:15 PM »
get some of these band style exhaust clamps, they seal super fucking tight yet you can take them off in about 30 sec. it does not deform the pipe like the u-clamps do.
http://cgi.ebay.com/ebaymotors/Dynomax-Performance-33280-Exhaust-Clamp-Band-Style-Bu_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem5ad1b0194eQQitemZ390065035598QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
« Reply #17 on: July 30, 2009, 12:42:14 AM »
fleshlight
« Reply #18 on: July 30, 2009, 02:28:44 AM »
Around here we have exhaust shops that will fix just about anything for like 20-30 dollars.  Dont' you have anything like that around there?
« Reply #19 on: July 30, 2009, 09:50:47 AM »
Mine broke just after the cat. I bought a 6$ (expensive shit) 2" ID to 1" 5/8 OD and push it in the cat with a hammer.
It hold good after 1 month and I didnt weld/JB weld anything.
Just buy a 2" to 2" adapter, put muffler potty, paint it. Voilà!
« Reply #20 on: July 30, 2009, 06:30:55 PM »
These are the best. I bought one of these from summit and it's just awesome. Seals fucking PERFECT and like you said takes 30 seconds to undo. Cheap too.
darksol2005
« Reply #21 on: August 01, 2009, 07:18:26 PM »
Napa actually carries those
« Reply #22 on: August 01, 2009, 10:40:17 PM »
Those are nice and I used the napa one......  It was $11   :'(
« Reply #23 on: August 02, 2009, 06:36:40 PM »
Really? They got 3" ones? Gonna have to check that out. I've known the owner of our NAPA for years so I get a good discount there.
« Reply #24 on: August 02, 2009, 08:12:09 PM »
napa is fucking awesome, the one guy let me open a business account and now i get discounts on everything i buy.
