Author Topic: < $100 turbo truck build  (Read 52086 times)
AJxr
  • i aint ur buddy pal
Re: < $100 turbo truck build
« Reply #30 on: July 30, 2009, 09:37:34 PM »
holy shit that is a tree...
90 hatch
« Reply #31 on: July 30, 2009, 09:39:41 PM »
- describe where you got vacuum from? Brake booster?
- carb hat need pics of
- pics of your piping(exhaust & intake)
- you thinking of making a IC or meth set-up perhaps?
I want to start getting parts for my truck. I was thinking a pair of HX35's and flipped exhaust manifolds.
« Reply #32 on: July 31, 2009, 12:06:51 AM »
depending on the motor two hx35s will be too big
vacuum comes from the full vacuum port on the carb (usually goes to modulator on trans with an automatic)
carb had is 5" pipe, that i used a ball peen hammer to expand to the size of the carb inlet which is 5.050, then i roughly cut out a top out of a flat piece of metal and then welded it on the top, then used a grinder to smooth it out. then used a hole saw to cut two 2.5" holes in it, welded two 3" pipes to that.
the exhaust is just a bend off the upside down lt1 corvette manifolds
the intake on the passenger side is just the bov and the pipe it came on, the driver's side is a slight bend that was in the exhaust that was on the truck before
i won't make an ic or do any injection with these turbos, when/if i do a single turbo setup i'll add an intercooler
« Reply #33 on: July 31, 2009, 01:36:49 AM »
sick
« Reply #34 on: July 31, 2009, 06:09:38 AM »
Looks awesome Johnny. Nice work. Does it blow fuel out of the carb anywhere? We always use purpose build blow through carbs but I figure stockers would work.
« Reply #35 on: July 31, 2009, 12:04:22 PM »
no, you had to do a little modification to make the carb work but not very much.
« Reply #36 on: July 31, 2009, 11:44:46 PM »
its a 76 chevy so the hell with emissions
caged
« Reply #37 on: August 01, 2009, 01:21:44 AM »
Thats a cool build. keep up the good work.
« Reply #38 on: August 01, 2009, 11:19:53 PM »
was wondering what happened to the shit brown bomber
Perfek360
« Reply #39 on: August 02, 2009, 07:44:13 PM »
i want to go for a ride  :mexi: :yes:
i want to see some pics of you jeep too
E-b0la
« Reply #40 on: August 02, 2009, 09:42:57 PM »
awesome.
only thing left is a ripper video.
biscuit
  • 300HP D In the Works
« Reply #41 on: August 02, 2009, 10:10:26 PM »
Sweet low buck setup!  I'm picking up an 82 C10 in 2 weeks.  What carb are you using?  Is that a 305?
jarebear667
« Reply #42 on: August 03, 2009, 01:16:13 PM »
ace hardware FTW
midwest HMT!
« Reply #43 on: August 03, 2009, 03:15:38 PM »
ace hardware FTW
+1  8)
jarebear667
« Reply #44 on: August 03, 2009, 04:16:51 PM »
i work there and it comes in way handy all the time especially 1 am trips wince i have keys  :yes:
midwest HMT!
« Reply #45 on: August 04, 2009, 09:57:35 PM »
- Sorry I meant some t3/t4's or a single hx35.
- I was thinking a muffler hat would work the same as the pipe carb hat( since i have a spare flat muffler)
- Not sure on the aspect since its a $100 build but since there is only 1 bov is that enough for both intake runners? or since its only at 6psi it really shouldnt affect it that much? ( IF one were to build it with this in mind would it make a difference to run both intakes into 1 Y or T pipe and attach bov there?) or is this extraneous?
- plans for intakes for turbos?
- btw my truck is on propane( and motor has a million miles on it), planning to rock it as is, then get a higher comp motor later
« Last Edit: August 04, 2009, 10:28:16 PM by Urban Indian »
« Reply #46 on: August 05, 2009, 01:00:34 PM »
however you can nigger rig the intake charge into the carb without it leaking or exploding will work. there are some carb hats that are really cheap < $100
i wanted to put the bov on the carb hat but there wasn't enough room. seems to work fine just on one intake but i would rather have it somewhere symmetrical. just my opinion
no takes, but you could put filters on them
« Reply #47 on: August 06, 2009, 08:02:16 PM »
year/make/model/ engine so I can add it to the rest of the builds! Pm me thanks!
« Reply #48 on: August 06, 2009, 08:48:17 PM »
Burnout video?
« Reply #49 on: August 06, 2009, 08:52:41 PM »
1976 chevy cheyenne
sbc 350
42/48 t3s
529 lift cam
fuelie heads
rpm air gap intake
holly 650 double pumper
« Reply #50 on: August 06, 2009, 08:54:00 PM »
« Reply #51 on: August 06, 2009, 08:59:27 PM »
Those are Dodge/Garrett turbos, baby 50trim t3's. At most they'll give you 400whp on a motor WITH intercooling. Regardless, I bet it's still a handful. Does it spool practically at idle??
I'd suggest you get a HX40 or HX50 with a divided housing. Both are cheap, would fit well between the block and radiator (w/electric fans), will aim right for the tophat if you don't intercool it - and support 65-99lbs/min of air. Those 50trim's can barely do 30lbs/min each, and taht doesn't factor in the tiny turbines.
If you are worried about spool, my friend's LS1 Mustang (yes) hits 5psi around 3500 with a T78. And that's a much larger turbo than even a HX50. It can flow something like 1500cfm, vs twin HX35's at 550cfm each, or 1000 from a single HX50.
« Reply #52 on: August 06, 2009, 09:06:55 PM »
thanks for the advice..... lol
no it doesn't build boost at idle
« Reply #53 on: August 06, 2009, 10:19:02 PM »
That totally ruins my tiny turbo fantasy.
« Reply #54 on: August 06, 2009, 10:50:17 PM »
only a piece of shit subu with a walnut sized turbo will do that.
« Reply #55 on: August 07, 2009, 02:47:34 AM »
where did you get pressurized oil for turbos from?
« Reply #56 on: August 07, 2009, 02:54:39 AM »
you can get it from the oil galley in front above the timing cover or in the back where the oil pressure sender is
i got mine from the front
Loki
« Reply #57 on: August 08, 2009, 01:11:14 AM »
Badass, makes me want to turbo my truck even more.
dive_miguel
« Reply #58 on: August 08, 2009, 11:36:56 AM »
Love the setup.  I am surprised more people don't do this.  Seems like if you spent $500 it would still be the best bang for the buck and relatively smooth at idle.
