Author Topic: RHMT boost controlers.... lets see them!  (Read 20944 times)
« on: September 06, 2009, 03:35:56 PM »
doing some research on a boost controller for my new setup, and have realized that im fuckin cheap (ok, i knew that to begin with) and dont feel like buying a baller boost controller...
i thought i remember there being a couple writeups on some dual stage setups, but i bet they are on the other site...  :-\
SO, lets fill this thread with some controller info!!! (try to keep the crap to a min please?)
lets call this the RHMT boost controller [aka "Home Depot MBC"]
baller'ish dual stage
soleniod to start a controller? found it on another search. looks to be the same as the VW one above, along with the one used in a AVCR/AEM/etc baller controller... sure it can be used to replace those, maybe to be used for eCtune...
Re: RHMT boost controlers.... lets see them!
« Reply #1 on: September 06, 2009, 03:42:59 PM »
I came up with this, but never tried it. I'm pretty sure it would work well though.
http://www.realhomemadeturbo.com/forum/index.php?topic=4173.0
« Reply #2 on: September 06, 2009, 06:09:58 PM »
It's the same as the "VW" one which is the same as the Perrin one for Subarus which is the same as: http://airinc.thomasnet.com/viewitems/air-valves/humphrey-direct-acting-310-410-series?&forward=1
Cycle at 20-25Hz.  Your welcome.
« Reply #3 on: September 06, 2009, 07:12:55 PM »
thats the exact one i bought, from that same site as well. good shit
« Reply #4 on: September 06, 2009, 07:18:15 PM »
I leaked that site to three people.  Which of them do I have to kneecap?  The Canadian?
« Reply #5 on: September 06, 2009, 07:29:39 PM »
none
i searched Grainger looking for a valve of that sort, then googled the part number to find the original manufacturer. then googled the latter part number to find a cheap source. where i ended up is the Air INC website
its been in my bookmarks for almost a year
« Reply #6 on: September 06, 2009, 07:38:00 PM »
Good, because I kind of like the Canadian and don't want him to die yet.   :P
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #7 on: September 06, 2009, 09:46:56 PM »
7808
« Reply #8 on: September 06, 2009, 10:59:56 PM »
caged
« Reply #9 on: September 07, 2009, 03:53:00 AM »
I used a "home depot" style boost controler on both my cars. One holds rock solid 18psi and the other holds rock solid 15psi with a 16g small and a standard unported down pipe. I highly rate these unless you want differant boost to differant gears.
« Reply #10 on: September 07, 2009, 12:45:51 PM »
http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=90590&CategoryName=&SubCategoryName=
hook it up like a turbonetics one and your done.
i bought one to do exactly that...but the inlet/outlet ports are a different size, as well as even when its backed all the way off there is still a shit-ton of resistance through the thing. i doubt it would work worth a shit
« Reply #11 on: September 07, 2009, 04:55:51 PM »
I use the ectune EBC, but as a side project I made a "manual EBC". Basicly just any solenoid (MAC, honda evap, misc brands, etc), and a PWM circuit that pulses the solenoid just like a regular EBC. Except you control boost via potentiometer knob put anywhere in your interior. The only problem is I fried the circuit using it for my injector cleaner/pulser...
I also have tried a variant on that home depot style so you don't need wrenches. Where the bolt goes in, you use a compression fitting, o-ring, and lock tite. You then use a bolt w/o threads near the head, and seals at the o-ring. Then you can turn it by hand rather than with 2 wrenches.
« Last Edit: September 07, 2009, 05:01:35 PM by HiProfile »
« Reply #12 on: September 11, 2009, 12:09:29 PM »
wonder is abaz still has his write up with the kia parts?
« Reply #13 on: September 11, 2009, 12:31:16 PM »
Canadian men make me happy in the pants    :P
« Reply #14 on: September 11, 2009, 01:04:05 PM »
I bought a dual stage turbo-xs from rudenig on the cheap  :-\
« Reply #15 on: September 11, 2009, 01:54:48 PM »
Real men dont run boost controllers.  They limit the boost with the size of the turbo.  :evil:
« Reply #16 on: September 11, 2009, 10:04:05 PM »
This is a proven method of setting FTOD at the local auto-x.
biscuit
  • 300HP D In the Works
