Author Topic: what temp do exhaust manifolds and turbo's get to .  (Read 25483 times)
toyolla86
« on: October 12, 2009, 02:52:07 PM »
i have a slightly warped flange that the turbo bolts to. so when i took our the turbo and looked at the
metal gasket i could see where exhaust trails were left from leaks.
i am thinking about just flowing some solder onto the gasket to thicken it in certain spots. solder melts
around 700-750 degrees. i would use a mill if i had one.
anybody know the temps of the exhaust manifold and turbo itself.
twin50 son. get some
and stop acting like a muslim
Re: what temp do exhaust manifolds and turbo's get to .
« Reply #1 on: October 12, 2009, 03:05:22 PM »
Sand paper and a block of wood............Get it done!
« Reply #2 on: October 12, 2009, 03:32:27 PM »
Sand paper and some surface that's dead flat, like a thick chunk of granite, glaass, etc. Get both surfaces flat (manifold and turbo) and then apply a thin coat of heavy grease and assembly with no gasket. Torque bolts to 10-15 ft*lbs and wire them together. Will never leak and bolts will never stretch or back out.
« Reply #3 on: October 12, 2009, 03:39:07 PM »
Belt sander.  /Thread.
800 to 1200
GF's bro's Duramax sits at 900F cruising.
Diesels run cooler exhaust temps than gas motors, fyi.
accordepicenter
« Reply #4 on: October 12, 2009, 08:58:10 PM »
solder is gonna melt on a turbo mani, throw a belt sander on it, just get it flat somehow.
toyolla86
« Reply #5 on: October 12, 2009, 09:10:41 PM »
damnit i was trying to avoid any manual labor. looks like im stuck. any suggestions on type of sandpaper. metal type and grit.
« Reply #6 on: October 12, 2009, 10:02:06 PM »
i've used a POS black&decker belt sander from walmart, and then returned it ftw.
solder? are you fucking serious? solder melts around 200*C
toyolla86
« Reply #7 on: October 12, 2009, 11:14:10 PM »
actually 400c and 700 f. give or take a bit. haha.
i was thinking exhausts dont get hotter than 700.
dont some people powder coat them. powder cannot withstand
much more than 450-500 f.
klyph
  • Proletariat for Life!
« Reply #8 on: October 12, 2009, 11:16:30 PM »
you mean ceramic coat?
toyolla86
« Reply #9 on: October 13, 2009, 12:44:11 AM »
no i meant powder coat.
ceramic coating is ok for exhaust right.
« Reply #10 on: October 13, 2009, 01:07:58 AM »
yeah i have seen some atv exhaust stuff that was high temp powder coated. it looked liek shit and was falling off from the heat. didn't last long at all.
ceramic coating is what works, kinda....
« Reply #11 on: October 13, 2009, 09:19:18 PM »
1600 degrees inside the turbo manifold
I have seen it
caged
« Reply #12 on: October 15, 2009, 02:30:17 AM »
I have used the grease technique on several cars since you suggested it, works so fucken well. :yes:
« Reply #13 on: October 15, 2009, 05:09:37 AM »
sorry
*turbine housing* on turbo
not manifold..........
Aero
    • Turbotalk.org
« Reply #14 on: October 15, 2009, 07:51:17 AM »
Yep. Been doing the same for about 4-5 years since a local showed me the trick.  I don't see any reason to use anything else, works better than OEM gaskets.
ktown powder coating
  • Noob of the month Oct 09
« Reply #15 on: October 15, 2009, 08:35:39 AM »
I have high temp powder that is good to 1200F,  normal powder is good to about 500F
« Reply #16 on: October 15, 2009, 09:00:35 AM »
Post an intro with Pron and your Locost / Sti / Junk  Faggot.
« Reply #17 on: October 15, 2009, 09:12:16 AM »
I will Jon I am at work and cannot do the porn part :(
« Reply #18 on: October 15, 2009, 09:25:04 AM »
no the problem is I have people all around me that woud see :(
I will try and get the intro done tonight...
« Reply #19 on: October 21, 2009, 07:13:39 PM »
800 to 1200
[/quote]
A little generalized...  :P
« Reply #20 on: October 21, 2009, 08:11:11 PM »
800 to 1200
[/quote]
Yeah, but he's stale so it doesnt matter.  :P
« Reply #21 on: October 21, 2009, 08:30:43 PM »
There isn't any need for gaskets or sealants if the surfaces are actually flat, belt sanders are the cheap weapon of choice.
toyolla86
« Reply #22 on: October 22, 2009, 12:47:00 AM »
i put high temp disc brake grease in there.
hope it doesnt burn off.
« Reply #23 on: October 22, 2009, 02:24:46 AM »
my egt's are from 98.6f all the way to 250f depending on how much sriracha i've consumed the day before. hope that helps.
toyolla86
« Reply #24 on: October 22, 2009, 11:30:38 AM »
im gonna sprinkle some powder on my turbo just to see what it does.
« Reply #25 on: October 23, 2009, 04:02:27 AM »
800 to 1200
Diesels run cooler exhaust temps than gas motors, fy -fucking- i.
