Author Topic: why is my spark plug well filling up with oil  (Read 11828 times)
toyolla86
« on: October 18, 2009, 11:55:34 AM »
ok so i  was checking stuff on my engine and i see that theres
oil almost covering my #4 spark plug completely. its a 4ag so
it sits an angle. i dont see any traces of oil as to where its
coming from.
anyone have any ideas. ill post pics whenever i get home.
twin50 son. get some
and stop acting like a muslim
Re: why is my spark plug well filling up with oil
« Reply #1 on: October 18, 2009, 12:00:54 PM »
If it was a honda I would say valve cover gasket....
QikEnuF
« Reply #2 on: October 18, 2009, 12:01:15 PM »
VC Gasket.  Had the same issue with my Kawasaki..
« Reply #3 on: October 18, 2009, 12:02:42 PM »
you know the little oil seals that go in the top of the VC that seal to the top of the spark plug tube?  I'd check there if they are build like honduhs
« Reply #4 on: October 18, 2009, 01:51:11 PM »
with older no-tec sohc Honda motors, the LMA actaully is part of the spark plug tube. so there are also o-rings lower on the head as well as at the top of the tube in the VC
Patrick
« Reply #5 on: October 18, 2009, 03:55:27 PM »
most of the time with the toyota's depending on the motor, the spark plug tube actully screws into the head, you have to remove, apply a thread sealant and re install the spark plug tube, also their are seals in top of the valve cover two that are prone to leaking, look up the repair manual on the net for your year to make sure the tubes screw out, some motors/year are pressed in, and some are threaded, their is a tool to remove the threaded tubes without distoring them, i think snap on makes a version of it, usually its the lower part of the tube that causes leakage, if pressed in you can removed the valve cover and place a peice of wood on top of the tube and give it a couple gentle taps with a hammer to help re seat it, or clean it up really good around the base of the tube and apply a sealant
« Last Edit: October 18, 2009, 03:57:58 PM by Patrick »
« Reply #6 on: October 18, 2009, 07:11:04 PM »
look like this except not with the extra bung hole
« Reply #8 on: October 18, 2009, 08:46:39 PM »
4a plugs go straight into the head. Check the 17mm allen plugs that are visible in the top of the head, if your sure its not the VC gasket.
toyolla86
« Reply #9 on: October 18, 2009, 09:12:39 PM »
this is what im leaning towards. but i was looking at those huge things, and thinking how could those be leaking.
ill check them.
sorry but this is the only pic i had of the swine flu, leaky, infected area.
toyolla86
« Reply #10 on: October 19, 2009, 01:01:07 AM »
yeah i mean i just take the spark plug out and poor oil in right????????
 8)
« Reply #11 on: October 21, 2009, 02:00:51 PM »
well, whats the issue?
toyolla86
« Reply #12 on: October 21, 2009, 02:56:43 PM »
behind the #4 spark plug oil builds up. and it will keep building up unto a big puddle.
