Author Topic: Turbo blanket?  (Read 16577 times)
ptil4
Turbo blanket?
« on: November 02, 2009, 09:46:40 AM »
Hey guys wondering if this is worth it. Anyone have any experience. I can see the benefits but I'm not too sure if they outweigh the cost.
Re: Turbo blanket?
« Reply #1 on: November 02, 2009, 01:17:28 PM »
Just grab a stainless pot and cut it to fit.  Looks super clean, too.
Re: Turbo blanket?
« Reply #2 on: November 02, 2009, 01:37:40 PM »
Turbo Blankets REALLY WORK
I think it works!!!
Re: Turbo blanket?
« Reply #3 on: November 02, 2009, 02:07:18 PM »
Oil cooler required with one of these thangs?
Yes, but with one of these you can completely block the radiator with your IC.
Re: Turbo blanket?
« Reply #4 on: November 02, 2009, 02:08:25 PM »
No rad fan needed either...
Re: Turbo blanket?
« Reply #5 on: November 02, 2009, 02:47:00 PM »
zingggggggggggggggggggggggggggg.....eh?
Re: Turbo blanket?
« Reply #6 on: November 02, 2009, 03:06:28 PM »
cold turbos need blankets
Pootie
Re: Turbo blanket?
« Reply #7 on: November 02, 2009, 03:23:56 PM »
waste of $$ really!! they are only good for tight engine bays with things to burn!! (ie: VR6 turbo,FD Hondas,etc)
In most Honda bays you have tons of room and the turbo is nowhere near the firewall (unless you are log manifold on a K-seriese)..
Save ya $$ and get something that you can actually use!
Tuned by you know who! ;-)
Re: Turbo blanket?
« Reply #8 on: November 02, 2009, 03:36:12 PM »
or you could just forgo the rad and do direct circulation.
Not need for the coolant to get warm with the tstat anymore
Re: Turbo blanket?
« Reply #9 on: November 02, 2009, 04:13:20 PM »
Better yet have the coolant hose dump directly on the blanket to really keep it cool.
You are so stale... the coolant is hot, sir.  Best to dump it on the ground and get all that heat out of the engine.
Re: Turbo blanket?
« Reply #10 on: November 02, 2009, 04:42:40 PM »
IDEA
can we get a rad blanket? We need to keep that heat inside the rad so it stays warm, or else it might get
Re: Turbo blanket?
« Reply #11 on: November 02, 2009, 06:15:50 PM »
Thermostat?
Re: Turbo blanket?
« Reply #12 on: November 02, 2009, 08:11:41 PM »
merkurcolin needs to post his $6.33 stainless walmart pot turbo shield in here
I remember that!  It was baller...
ptil4
Re: Turbo blanket?
« Reply #13 on: November 04, 2009, 01:19:28 AM »
so i guess a turbo blanket is a waste. thanks for the laughs guys. i think i might try that coolant trick.  ;)
Re: Turbo blanket?
« Reply #14 on: November 04, 2009, 02:31:26 AM »
i am buying a turbo blanket
lets you work on the car when it is hot
Re: Turbo blanket?
« Reply #15 on: November 05, 2009, 11:18:03 AM »
My elephant mani is basicly a top mount, and covering the turbo helps tons. My old manifold was covered with an inch of ceramic insulation, and it was about 90*F after 3 dyno pulls.
ATM i'm running no cover over the turbine, but the entire manifold and DP are covered with a 1/16" ceramic insulation (1800F), then a 2nd fiberglass wrap (1200F). Stock radiator & fan, and never goes above 202*F in the summer.
The $15 pot is probably a better idea in terms of value, but for a car on the street, a blanket would help loads.
Re: Turbo blanket?
« Reply #16 on: November 05, 2009, 06:27:18 PM »
anyone have the writeup on that?
Re: Turbo blanket?
« Reply #17 on: November 05, 2009, 09:30:11 PM »
rudebwoy
  • tripple OG
Re: Turbo blanket?
« Reply #18 on: November 06, 2009, 03:16:47 PM »
turbo blanket is worth every dime, even at $150 each, I am on my second one in 2 years I can drive the car 2.5 hours and still can put my hands on the blanket, downside they dont stay pretty for long if the silver color will burn off if its touching the manifold. but its worth it use to burn through my hood on my old car now I have the coolest engine bay.
my old one from ebay
my new one from T1 different styles
bot cost 150 each
« Last Edit: November 06, 2009, 03:21:05 PM by rudebwoy »
2000 civic SI daily driver
