Author Topic: ripper/flame thrower vid  (Read 35624 times)
speedjunky01
« on: November 03, 2009, 09:24:01 PM »
finaly got a hold of some bkr7e plugs and aped them to .027 and now the car will rev past 4500 and not break up. had to drive an hour to get them but well worth it
tuned in with some ectune goodness, still no motorola 2.5 so i just tuned it using the last column lol
13ish psi running around 11.5-11 filthy rich i know and stock map with 1.25 retard, would like some advice on the map dont know how to post my file though
anyway vids :D
daytime rhmt z6 turbo
ectune antilag goodness
taking it to the track wednesday, hope i can sqeeze out mid 13's this thing is a fucking PIG for a civic lol
think this about says it all lol
« Last Edit: November 04, 2009, 06:29:20 PM by speedjunky01 »
boosted 00 black si
Re: ripper/flame thrower vid
« Reply #1 on: November 04, 2009, 12:10:19 AM »
nice!!!!!!!!
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
speedjunky01
« Reply #2 on: November 04, 2009, 02:09:05 AM »
« Reply #3 on: November 04, 2009, 02:11:12 PM »
sweet
shogun
« Reply #4 on: November 04, 2009, 03:53:41 PM »
nice flame thrower
« Reply #5 on: November 04, 2009, 04:57:34 PM »
Gotta love the anti lag. Even at the the long term expense of the turbo O0
« Reply #6 on: November 04, 2009, 05:59:45 PM »
Thats pimp  :noel:
« Reply #7 on: November 04, 2009, 06:02:10 PM »
You put pressure on me, I have to make a vid as nice as this one ;)
I'm not straight pipe tho, don't know if flames will come out
speedjunky01
« Reply #8 on: November 04, 2009, 06:29:01 PM »
my setup is as fallows
2.5 DP with 5 bolt being help on by 2 bolts others rattleled out lol
3" rc autoworks exhaust tacked together not finish welded, leaking all over the place
3" straight through magnaflow
got a vid during the day where you can actualy see something, will update the 1st post in a minute
rudebwoy
  • tripple OG
« Reply #9 on: November 04, 2009, 06:30:10 PM »
more fuel you add, more flames you see.
2000 civic SI daily driver
speedjunky01
« Reply #10 on: November 04, 2009, 06:32:01 PM »
not in my experience, im using ignition cut
i found if i went too far above 40ish fuel values antilag would bog down from too much fuel
« Reply #11 on: November 04, 2009, 07:44:00 PM »
really? I am using 100% fuel value. I might have to dink around with it to get optimal flames
speedjunky01
« Reply #12 on: November 04, 2009, 07:48:21 PM »
IDK man its whats working for me right now, but since im using ignition cut NOT fuel its whatever the fuel is at that rpm+the fuel value added
if your using fuel cut i could see how you need to dump in a lot more fuel to get some flame
« Reply #13 on: November 06, 2009, 12:58:29 AM »
Tomorrow, I'll give it a new try! Lets get the flame war begin ;)
speedjunky01
« Reply #14 on: November 06, 2009, 01:04:38 AM »
if you top my pic, im gonna get one of my old injectors and stick in in the muffler
« Reply #15 on: November 06, 2009, 01:13:24 AM »
I have so many spare injectors, I could do a flame thrower with them :P
« Reply #16 on: November 06, 2009, 02:54:52 PM »
Really, it doesnt work for me... Maybe the 450cc can put enough fuel?
There are no difference between 45 degree and 1200ms to 50 @ 1300ms
Any value I put, I still don't get more than 3psi of boost  :-\
You win this round, I didn't even made a vid lol I was disapointed...
speedjunky01
« Reply #17 on: November 06, 2009, 02:59:18 PM »
try less fuel, waaaaayyyy less
« Reply #18 on: November 06, 2009, 03:08:48 PM »
I think the first time I tried it I was at like 300-800, but I don't remember about timing tho... Maybe it was the problem. I eat and I go for another try. I have to drive 10 minutes each time lol...
speedjunky01
« Reply #19 on: November 06, 2009, 03:10:04 PM »
start at like 10 and work your way up by 10
« Reply #20 on: November 06, 2009, 04:43:39 PM »
What retard do you recommend? I tried 45 degree retard from 10 to 100ms. Was not better than what is was 2 posts ago.
Maybe the problem is somewhere else like a big leak or something...
I'll have to buy eCtune.... that's sad ;)
« Reply #21 on: November 06, 2009, 07:42:42 PM »
Vids of dirty 3rds outside of the car are a must......
Do work....
speedjunky01
« Reply #22 on: November 07, 2009, 01:03:34 AM »
im at 40, i think the problem is crome uses fuel cut. . . but IDK on come free and my "anti lag" trick it worked just fine and built 8 psi
« Reply #23 on: November 07, 2009, 12:02:30 PM »
Yeah, that's what makes me wonder the problem might be somewhere else. I'll buy eCtune this week and give it a try.
rudebwoy
  • tripple OG
« Reply #24 on: November 07, 2009, 07:44:05 PM »
I use s300 and uses both ignition and fuel cut, and I still gets the 12" flame out the tail. Anti lag set to 5500-6500 rpms. that means it bounces from 5500-6500, and builds 15 psi fuel enrichemnet set at 55, and ignition at -35 popps real fast.
« Last Edit: November 07, 2009, 07:48:11 PM by rudebwoy »
« Reply #25 on: November 17, 2009, 09:16:23 PM »
I got my eCtune license. I don't think I'll have the time to throw flame tonight, but as soon as I have some time and that my car run ok I'll try it.
I'm in my in my car and it's fucking cold outside... Fucking winter's comming...
« Reply #26 on: November 17, 2009, 10:03:46 PM »
Thing is running good now.
Finnally I tried the anti-lag. Was building a lot of boost compared to crome  :o Only problem is that the turbo stopped working after that. I was listening metal to metal friction and no 1 psi of boost.
I said to myself if it wanna blow it's gonna blow so I floor it in third and at 6000rpm the turbo started working fine  :noel:
It was like if the turbo was seized of something... No more anti-lag for now lol Anyway, I did a small burnout yesterday and the clutch is half gone.
speedjunky01
« Reply #27 on: November 17, 2009, 10:42:18 PM »
yeah ectune doesnt fuck around lol glad to hear your linking it, my china man turbo is taking antilag like a champ, blades all look great as of tonight
« Reply #28 on: November 18, 2009, 12:19:39 AM »
bent shaft due to massive amounts of surging perhaps?
I hope it's not that. I don't want to buy another turbo until next summer at least. It was popping nice tho  :noel:
It had also a nice black smoke on the back when I finished lol
speedjunky01
« Reply #29 on: November 18, 2009, 12:25:50 AM »
same with mine, if the exhaust gets hot enough thats how i got the huge flame that black smoke ignites :D :D
im building a new DP, adding the 2.5bar and MBC and upping to manly 15-17psi and see how she likes it.
the DP is all whitey bends so its a PAIN to weld/fit i did it all in 15* segments so there are a BUNCH of bends
