Author Topic: Adding a bead to intake pipes - How to.  (Read 20431 times)
Re: Adding a bead to intake pipes - How to.
« Reply #1 on: November 06, 2009, 10:43:58 AM »
That's nice! It looks like it was done by a machine.
Did you try to brass your intercooler pipe finally?
ktown powder coating
  • Noob of the month Oct 09
« Reply #2 on: November 06, 2009, 10:44:10 AM »
We need to make one!
« Reply #3 on: November 06, 2009, 11:06:12 AM »
Did you try to braze your intercooler pipe finally?
Got the Aluma-loy  2 days ago. Going to try it and test it tomorrow...will post thread.
« Reply #4 on: November 06, 2009, 11:11:12 AM »
I've seen this before. Going to try it sometime.
« Reply #5 on: November 06, 2009, 12:08:14 PM »
I already have tool to do this a fencing pliers/cuters.
similar to this:
Mine is a little bigger and only has one crimp on it. ;D
« Reply #6 on: November 07, 2009, 05:37:25 AM »
I've seen ppl use a vise grips with welded lumps and a valley ground on the other side, but this is freakin awsome. Next time I have some tubing, I'll give it a shot, except it will be way overbuilt. I want to do stainless next...
trevor72
  • trevwhore
« Reply #7 on: December 07, 2009, 03:16:12 PM »
not only a good idea but the end result looks clean, impressive
Vagitarian
  • Panik Mekanik
« Reply #8 on: December 07, 2009, 06:19:15 PM »
I tried building this today, couldnt get the washers to weld to my vice grips for shit
klyph
  • Proletariat for Life!
« Reply #9 on: December 07, 2009, 06:23:46 PM »
You'll want to grind the galvanization off the washers. Or be a real man, use fluxcore, and breath those fumes in deep.
Vagitarian
  • Panik Mekanik
« Reply #10 on: December 07, 2009, 09:06:25 PM »
I just went and grabbed a thicker stainless steel washer and it welded perfect
Hope it works good
mandrel-bends
« Reply #11 on: December 07, 2009, 10:10:18 PM »
This wont work on stainless.
http://www.mandrelbends.com
Vagitarian
  • Panik Mekanik
« Reply #12 on: December 08, 2009, 03:51:57 AM »
I said stainless washer, not Im planning on doing this to stainless pipe. Big difference, get glasses
mandrel-bends
« Reply #13 on: December 08, 2009, 04:49:30 PM »
klyph
« Reply #14 on: December 08, 2009, 05:57:47 PM »
This won't work with an aluminum washer, dumbass!
« Reply #15 on: December 08, 2009, 09:11:56 PM »
what a retard trying to do this on stainless....
« Reply #16 on: December 08, 2009, 10:08:46 PM »
I just wrap the pipe with a peice of Filler rod, and tack it in a few places>
civiceggturbo
« Reply #17 on: December 09, 2009, 02:08:02 AM »
or just add a fat bead like every other  O0
