Author Topic: 2005 WRX need a reflash?  (Read 22956 times)
« on: November 09, 2009, 12:02:58 PM »
I'm picking up an 05 WRX wagon this afternoon. I drove it and asked and the guy said he always put 87 in it. Do I need to bring it back to subaru for a reflash or will the ecu relearn if I put good gas in it again?
Re: 2005 WRX need a reflash?
« Reply #1 on: November 09, 2009, 01:26:55 PM »
The stock program is designed for 92/93 octane, what's to relearn?
You're getting this thing so cheap you can afford to drop an engine into it, right?
« Reply #2 on: November 09, 2009, 02:12:04 PM »
Some old man had the car. I'm sure it pulls timing out with shit gas in it. Ill call the dealer.
« Reply #3 on: November 09, 2009, 02:19:26 PM »
I'm sure it pulls timing out left and right because those are fragile engines.  Not as bad as the 2.5's, but still not ideal.
I'd pull a plug or two, I recommend either cyl 3 or 4 or both on the passenger side, and look at the plugs or the piston surface if you have a borescope.
Also, yank the oil feed line at the turbo and see if the inline filter has been removed or not. The 04-07 WRX/STi had inline filters (as did the STi AVCS aka variable intake cam system) that were prone to getting clogged with shit and killing the turbo and sometimes the engine, TSBs all recommended that they be removed ASAP.  If she blows any oil upon startup or under boost, yes it's the turbo but the engine's probably fucked as well if it's been driven any length of time like that.  All of this is easily verifiable by searching NASIOC.
« Reply #4 on: November 09, 2009, 02:53:06 PM »
Thanks for the info!
« Reply #5 on: November 09, 2009, 02:56:43 PM »
Apparently David is looking at a low mile, looks showroom new, met the mid-50 year old dude who used to own it face to face, stack of dealer service records taller than his penis is long, bone stock cream puff.
« Reply #6 on: November 09, 2009, 04:53:53 PM »
Almost bought an 05 for the wifey, glad we got the VW instead.  <---Never thought id say that.
« Reply #7 on: November 09, 2009, 05:44:54 PM »
Legacy GT's have the filter as well. My old mans needed a turbo due to this awesome design.
« Reply #8 on: November 09, 2009, 10:33:03 PM »
reset the ecu, fill it up with 93, go do a 2600rpm pull and double foot the brake and gas at ~3lbs of boost.  resets your iam lickity split
How exactly do I reset the ECU?
« Reply #9 on: November 09, 2009, 10:38:55 PM »
Convert to RWD ASAP :yes: PPG sells the diff and then these cars are fun to drive.
« Reply #10 on: November 09, 2009, 11:26:06 PM »
Check. Thanks.
« Reply #11 on: November 09, 2009, 11:39:29 PM »
If in doubt, drink two beers.
« Reply #12 on: November 10, 2009, 06:44:34 AM »
Check....I don't drink. :-\
« Reply #13 on: November 10, 2009, 06:51:36 AM »
No, you smoke meth to be up at 5:45.
« Reply #14 on: November 10, 2009, 07:04:33 AM »
LOL I work and have 2 kids that need to be at daycare/preschool. The cream puff has proven not to be already. Im upset. The tire noise is horrible in the car and says lateral belt shift or broken belt all together. Im calling today to see if they will replace the loud tire or maybe a diff bearing is bad. Im a bit pissed.....
« Reply #15 on: November 10, 2009, 07:15:58 AM »
There is no difference between meth addiction and parenting small children with respect to your sleep schedule and mental state.  At least the meth is cheap.
« Reply #16 on: November 10, 2009, 12:48:43 PM »
You are an idiot. A wheel bearing has a certain lifespan on any car.
« Reply #17 on: November 10, 2009, 01:01:22 PM »
what tires are on it? crushed surface roads suck period in a wrx and sound like you are powered by a jet engine with afterburners when you drive on one
might be a wheel bearing, but they rarely go on imprezas
did you get your reset done?
Some shit as goodride tires. I'm sure its the tires. I'm not doing the reset till I run the tank down. I don't know what fuel is in it so ill baby it till its low enough to refill. I'm thinking I should just go buy goiod tires.
« Reply #18 on: November 10, 2009, 01:56:50 PM »
Are all the tires the same size?
« Reply #19 on: November 10, 2009, 06:40:05 PM »
Just looking stock tires but a reasonably quiet ride.
« Reply #20 on: November 11, 2009, 01:33:58 AM »
The Sumitomo HTR are awesome tires, dirty cheap and they hook great.  They are $50/pop for 205/60R13, I plan on rocking a set on my classic Si.
caged
« Reply #21 on: November 11, 2009, 03:54:08 AM »
Iv done a shit load of centre diff bearings, its common as. Iv also done heaps of wheel bearings but usually due to a damaged abs tone wheel from stones. I would also run a can of subaru upper cylinder cleaner if its been run on 87, those cans are worth every cent :yes:
