Author Topic: looking for a how to (rebuild)  (Read 19156 times)
toyolla86
« on: November 11, 2009, 02:28:12 AM »
is there a step by step how to rebuild a turbo thread yet.
twin50 son. get some
and stop acting like a muslim
Re: looking for a how to (rebuild)
« Reply #1 on: November 11, 2009, 09:50:32 AM »
There was on OHMT, but more or less just take shit apart and put it back together as clean and well oiled as possible. There arent a whole lot of parts in a turbo, and if you disassemble it yourself, take some pics so you know how it goes back together.  Im sure there are some writeups somewhere, just google "how to rebuild a turbo"
On a side note, I recently had a lengthy conversation with a Borg-Warner research tech, about how quickly turbos will unbalance themselves.  Basically after statically,dynamically, and harmonically balancing one, you can heat/load it up, then recheck the balance after it cools and it will be out.  Not by much, but they attribute it to shaft warpage (cant visibly see it of course).  Interesting tidbit.
toyolla86
« Reply #2 on: November 11, 2009, 11:37:03 AM »
wow that sucks.
well im thinking i better rebuild my cdm turbo.
ive priced them from 50-130. is any one kit better than the next.
« Reply #3 on: November 11, 2009, 11:45:29 AM »
wow that sucks.
I can vouch for G-pop.  I just rebuild a k03 this morning using one of their kits, and they have never done me wrong.
« Reply #4 on: November 11, 2009, 02:26:00 PM »
wow that sucks.
G-pop is where it is at.  :noel:
toyolla86
« Reply #5 on: November 11, 2009, 03:43:34 PM »
yeah their prices are a little higher but they really make ordering the kit much easier.
i feel like they know what theyre talking about
 do they have a coupon code
« Reply #6 on: November 11, 2009, 05:55:42 PM »
Only time I did it, it felt apart. I mark both sides to so I could have a point to line them back up with. Lasted a hole 3 blocks :?:
« Reply #7 on: November 11, 2009, 06:13:23 PM »
wow that sucks.
where can i buy new wheels for a k03s?
toyolla86
« Reply #8 on: November 11, 2009, 07:05:14 PM »
i think gpop has them. ive called them before and priced turbine wheels.
altho i never bought them.
looks like ill be calling that guy back.
i gotta make sure the turbo is rebuild able.
i may just go with a 14b.
what does everyone think rebuild a 16g or buy a real 14b.
the 14b should spool faster for my little 1.6. plus i dont run super high boost. ill probably top out at like 10-12 psi
Avistar23
« Last Edit: November 11, 2009, 07:56:27 PM by Avistar23 »
F250 4x4 7.3 Diesel
International 4900 DT 466E
« Reply #10 on: November 11, 2009, 09:07:46 PM »
http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/303829-td05h-td06-turbo-rebuild-part-2-a.html
hope this helps.
FYI this dude says he torques them back to 100inch/lbs.  Factory spec for TD05 is 16, I see no reason to tighten that much, but its your turbo so whatever.
« Reply #11 on: November 11, 2009, 10:21:24 PM »
16g=10x the turbo of the 14b, but only if you fix the failure internal gate.
toyolla86
« Reply #12 on: November 12, 2009, 01:08:49 PM »
well for right now i found a good 14b locally for 70 bucks.
that should take care of the oil leaking into my intake.
we'll see if its a good rebuild job or not.
last time i drove it, it was making noises at full boost. (unhealthy sounding noises)
kinda sounded like a nice spool ssssssssss then to a scraping shhhhhhhh
so like ssssssssssssssshhhhhhhhhhhhhhhh
toyolla86
« Reply #13 on: November 13, 2009, 01:42:39 AM »
just picked up the 14b. looks like its in great shape.
zero shaft play.
« Reply #14 on: November 15, 2009, 10:48:05 PM »
wicked fun turbo for a street car
