Pages: 1 ... 5 6 [7] 8 9 ... 24   Go Down
Author Topic: oh boy.... MOST POWAR EVERZ  (Read 310206 times)
Aaron CupCake
Re: oh boy.... MOST POWAR EVERZ
« Reply #180 on: November 16, 2009, 05:30:10 PM »
« Reply #181 on: November 16, 2009, 05:33:13 PM »
Good shit.
« Reply #182 on: November 16, 2009, 05:53:02 PM »
Question:
Those that have ran the Bisimoto Turbo cam's with crappy results, did you degree in the cams as listed?
« Reply #183 on: November 16, 2009, 06:26:07 PM »
Question:
After seeing danz results(w/the colt cam) and who he took his stuff to, I'm sure they tried a number of settings before deciding the cam was junk...
« Reply #184 on: November 16, 2009, 07:15:57 PM »
« Reply #185 on: November 16, 2009, 07:24:22 PM »
go fuck yourself for trying to give bisi a bad rep
bisi is giving himself a bad rep by claiming he will do things and does do things, that he doesnt do.  im quite sad actually.
why say you help customers with different cam profiles, then not help them?  its weird, thats for sure
Question:
JFK did mess around with the cam timing, it helped carry torque a little better but nothing to write home about.  i also emailed bisimoto about the cam needed to be degreed and was told it might make minor differences but it wouldnt cure my torque falling off like the niagra falls...
and just to LOL at... intake .007 exhaust .009  :)
i cant speak for JFK, but the impression i got from him was that he thought my setup was bottled necked by either my exhaust manifold, turbo choice, or my non-vtec head... i dont think he thought the cam was the problem.... and to be honest i didnt think the cam was the problem either.... UNTIL i tried a Colt cam and the car started to move like a mother fucker.
« Last Edit: November 17, 2009, 02:42:51 AM by danz »
« Reply #186 on: November 16, 2009, 07:33:13 PM »
The video between the 2 cams looks like a whole new motor build.
« Reply #187 on: November 16, 2009, 07:38:49 PM »
B4 Deleted
Quote from: ATYPR;40656316
WTF?!?! read more hate less.
Quote from: extralargenog;40656470
No Hate.
Fact..
The manifold is thinwall (16 Guage-as I thought)...I asked way back (post deleted) what it was made of due to the WG setup hanging precariously of of what appeared to be thinwall stuff.
However... The answer has just come. If the DP is braced on the back of the motor there is NO additional stress. At all, in fact there would be LESS. The ONLY thing that comes into play is that the thermal expansion and contraction  of the manifold. That being said, if the DP is braced at the rear of the block and the flex is located in the "sheepy" location, the stress point isnt further up at the turbo where it is now. The maniofold and the turbo will have to take more of the stress out of the longer (heavier) exhaust swinging off of it. Being as you cant reallyu brace it since the flex is so far forward and high...  Well it doesnt take an engineer to figure it out...
 He stated its 321...  Do you know what that means??? My bet is no.  It is a titanium alloy more friendly to such thermal  happenings. Im sure thats why he picked it... Still another FACT is that the exhaust being longer creates more stress on the flex joint than if the DP was braced at the rear of the block in the "sheepy" location.
Im not going to get into the manifold material, as I know others are thinking the same as I.
Its funny how anything thats not nutswinging is automatically construed as "hating"
The build is cool, the goal... well Im curious to see if he makes it. I wouldnt call Pump and Meth "pump" but whatever. I hope he makes it, however clowns like you are just as bad as the people that badmouthed him earlier here.
Ride on... I have Compressor wheels to break and Fluxcore to spatter...
« Last Edit: November 16, 2009, 07:42:37 PM by bigdaddyvtec »
« Reply #188 on: November 16, 2009, 07:44:10 PM »
Hey tubby, you did you fail to realize that his use of the word "sheepy" was to address the user Sheepey originally...
« Reply #189 on: November 16, 2009, 07:47:23 PM »
si   :mexi:
Am
 I the only one convinced that that WG setup is fucking garbage, that manifold is going to crack even though its "braced to the teeth"  (none of which I can see in any pics), the flex pipe where it is is not helping stress at all on the manifold like he claims and that pump gas with meth is not "pump gas"
Jesus fucking christ
« Reply #190 on: November 16, 2009, 07:52:55 PM »
What a pussy.  Real men dont run wastegates.  They size their turbos for the amount of boost they need to run.   :?:
Wastegates = Pussy.
hatchbox90
    • Dream Builders Homes
« Reply #191 on: November 16, 2009, 08:03:12 PM »
Don come back
 :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi: :mexi:
« Reply #192 on: November 16, 2009, 08:04:38 PM »
si   :mexi:
Am
I'm with you on the manifold being  :?:. i don't understand why he wouldn't brace those joints where the wastegates tee off the collector. the wastegate will most certainly fall off with the vibration from a d series being pushed that hard.
and also i almost posted on his retarded flex location and how it serves no purpose there if the down pipe is braced/mounted in the back like it appears it is. also i have never seen a stepped header on a turbo car unless it was a log manifold. I have always heard you want to keep as much velocity or pressure as you can before the turbine. As in run the smallest diameter you can for the engine.
there is so much wrong with that build it just doesn't look like an "engineer" is building it. there doesn't seem to be real thought put into the components of the build.
« Reply #193 on: November 16, 2009, 08:07:25 PM »
...also i have never seen a stepped header on a turbo car unless it was a log manifold. I have always heard you want to keep as much velocity or pressure as you can before the turbine. As in run the smallest diameter you can for the engine...
With a given density, velocity and pressure have an inverse relationship...
SOHCinWA
« Reply #194 on: November 16, 2009, 08:10:52 PM »
Don come back
Thats awesome! Too bad I am holding a Wally. Not mine though. Damn proud to have been there to accept it for my dad though...
Bisimoto tuned and Sponsored 1.5L Single cam
13.96 @96mph
QikEnuF
« Reply #195 on: November 16, 2009, 08:12:32 PM »
That's you? Dude, you do kind of look like you might take a dick in the ass from time to time.
« Reply #196 on: November 16, 2009, 08:13:10 PM »
your dad would be upset with you for wearing such a faggoty shirt to accept an award in his name
« Reply #197 on: November 16, 2009, 08:14:24 PM »
NHRA ruined Honda racing notice the decline and total loss of interest once they got there greedy hands on it.
Once they got done ruining it they threw it out like a 50 dollar whore. Thanks NHRA.
Oh fuck wally
« Reply #198 on: November 16, 2009, 08:18:03 PM »
si   :mexi:
Am
Holy shit did we just actua;;u agree???    O0
hahahah
hatchbox90
« Reply #199 on: November 16, 2009, 08:26:24 PM »
SOHCinWA
« Reply #200 on: November 16, 2009, 08:32:27 PM »
If you are going to do it. At least do it right....
13.96 @96mph
« Reply #201 on: November 16, 2009, 08:33:56 PM »
Man you look way more gay in that picture....  :o
SOHCinWA
« Reply #202 on: November 16, 2009, 08:37:58 PM »
Yeah you would look pretty gay too if you had to wear this thing... Oh well it was my birthday and we were smashed
13.96 @96mph
« Reply #203 on: November 16, 2009, 08:38:40 PM »
does your dad know you're a fruitbooting poofter who takes pictures of himself?
« Reply #204 on: November 16, 2009, 08:43:26 PM »
This thread makes me proud to be a flux coring compressor wheel breaking 4 door mobbing cheeseburger inhaling American
« Reply #205 on: November 16, 2009, 08:44:52 PM »
your nose looks a lot smaller in that picture... musta cleaned off all of bisi shit before hand
SOHCinWA
« Reply #206 on: November 16, 2009, 08:52:01 PM »
Thanks for the kind words.
13.96 @96mph
1fasthf
  • RHMT resident Bruce Buffer
« Reply #207 on: November 16, 2009, 08:52:19 PM »
^^^^^^ BWAHAHAHAHAHHAHAHAHAAHHA^^^^^^
QikEnuF
« Reply #208 on: November 16, 2009, 09:28:57 PM »
This thread makes me proud to be a cheeseburger inhaling American
At least you got some of that right
« Reply #209 on: November 16, 2009, 09:48:10 PM »
Mmmmmmmmmmmmmmmmmmmmmmmm  Ch33zeburg3rzzzzzzzzzz
NOM NOM NOM NOM NOM
Pages: 1 ... 5 6 [7] 8 9 ... 24   Go Up
