Pages: 1 [2] 3   Go Down
Author Topic: Suggestions for donor car drivetrain, give your input!  (Read 35180 times)
kgx
  • MR2fag
Re: Suggestions for donor car drivetrain, give your input!
« Reply #30 on: November 18, 2009, 07:50:46 PM »
my votes:
- 4.3L V6T syclone/typhoon motor.
- jag or BMW V12 if you want a 'holy shit' factor when you pop the hood. or the toyota 1GZ V12 if you can find one. though, for the bimmers at least, they breathe so poorly you'd need boost to make much above 300. not really an ideal performance setup, but would make for some nice "when you see it, you will shit bricks" posters.
- northstars are pretty cheap and easy nowadays.
TunerToys
« Reply #31 on: November 18, 2009, 08:00:40 PM »
SC300 drivetrain are cheap as fuck + lots of aftermarket for 2JZ.
If I go with the SC400...
Curb Weight: 3,604 lb (1,635 kg) (1992 SC 400)
Power: 280 hp (209 kW)/300 lb·ft (407 N·m)
...I'll have close to the stock power levels that I want, and potentially a complete suspension to transfer over.
The GS400 may be even better, although I'll need to bump to a newer car to get the drive train I want...
GS 400 was equipped with a UZ-series V8 that produced 300 hp (224 kW) and 310 ft·lbf (420 N·m)
Hmmm
bryantaylor
« Reply #32 on: November 18, 2009, 08:52:12 PM »
I'm going to toss in my vote for Lincoln Mk8, but one caveat: they may be a 4V, but they aren't the Cobra 4V.  Some corners were cut and if you want to breathe on it you'll have to replace a few things.
same block, but non-forged internals, and the intake mani flows slightly worse.  they will still hold 400+whp just fine.  if you want to boost a bunch just toss in some pistons and rods and you should be good to go.
90 miata - t3 and megasquirt
95 mark VIII
06 GSX-R 600
 i changed my sig as per Robb
« Reply #33 on: November 19, 2009, 02:12:30 AM »
Jag XJS.  You can grab them for only a couple grand, and if you are rewiring everything, you escape the problems that all British made cars had in that era.
TheMadScientist
  • I'm like Batman and Shit
« Reply #34 on: November 19, 2009, 02:14:27 AM »
How about All wheel Drive. You can pick up a wrecked WRX for cheap. I've seen wrecked STI's go for 10K or less and the drive train was mostly intact. A million things you can do to it also. Plus in a truck frame that motor would not be as much of a bitch to work on either. The auto wrx boxes are pretty stout from what i understand as well. Maybe a flat six out of an outback.
The LS1 Fbodys are not too bad of an idea but pretty common to see.
The mk3 supras are cheap and plentiful and have decent aftermarket support.
As far as the BMW the 850i V12 would be cool too see in a truck.
To be really unique the porsche 908 racing flat 8 would be cool to see but not practical in a truck cool none the less
Audi S4's in the A5 chassis like 1997-2001 can be had for 10k or less AWD Twin turbo V6 with aftermarket support
Just a few ideas not all had the 300hp from the factory but most can easily get there with very minor mods. My vote is something all wheel drive.
« Reply #35 on: November 19, 2009, 08:55:40 AM »
Hmmm
I like 1UZ, but you need to get an early big rod motor and brethe on it.  Check the SC-oriented forums, the actual power to the wheels isn't that great.  If the vehicle the drivetrain goes into sheds a few hundred lbs then it'd probably be really zippy, just FYI.
« Reply #36 on: November 19, 2009, 09:25:36 AM »
Hmmm
Damn JD beat me to it.  Yeah UZ are only good stock in the early forms with big rods -92. The 2UZ is a waste of time with its pencil thin rods that break on stock tundras.
Vote is still for a 2JZ-GE.  Hone it out for the turbo P2W clearance, turbo pistons for $40 each and make a shitload of power for pocket change.
TunerToys
« Reply #37 on: November 19, 2009, 10:18:52 AM »
Yep, but the only way to get a complete donor car in rear wheel drive is with the Cadillac cars, and then only 2004 and up cars...
Year           Model     Power                                   Torque
2004–   Cadillac SRX     320 hp (239 kW) @ 6400 rpm   315 lb·ft (427 N·m) @ 4400 rpm
2004–   Cadillac XLR     320 hp (239 kW) @ 6400 rpm   310 lb·ft (420 N·m) @ 4400 rpm
2004–   Cadillac STS  320 hp (239 kW) @ 6400 rpm   315 lb·ft (427 N·m) @ 4400 rpm
Any of these is putting me into the $14K range.
It's important for me to get a rear wheel drive platform, so I can take as much from the donor as possible.
TunerToys
« Reply #38 on: November 19, 2009, 10:53:22 AM »
Intriguing!
HP to Weight is not too bad, a few hundred pounds heavier for the truck.  Wheel base is close.  My only concern is the stock hp rating of the EJ motors. If I pick up a later EJ255 I can get 230Hp factory hp, but that will be further weakened by the additional vehicle weight.  I could end up 30% off from my hp target when it's all together.
I really love the sound of the boxer engine tho.  It would really turn some heads just on the distinctive sound alone...
« Reply #39 on: November 19, 2009, 10:56:40 AM »
Intriguing!
The question is, how are you gonna stuff that wide ass engine between the rails of a ladder frame?
Anything can be done, but it just seems like a far less than ideal situation.
« Reply #40 on: November 19, 2009, 10:57:03 AM »
If you pick up any EJ25, welcome to cracked ring lands when bone stock.
TunerToys
« Reply #41 on: November 19, 2009, 11:16:01 AM »
If the donor car is complete enough, I may forgo the frame, and just graft the body of the truck onto the donor vehicle.  That way, other than wheelbase / track changes of a few inches, the fab work is minimal.
AstroVannin
« Reply #42 on: November 19, 2009, 01:00:57 PM »
What about an Infinity M45 ?
superdaveosbourne
« Reply #43 on: November 19, 2009, 02:00:44 PM »
If you want AWD and lots of aftermarket support, go with an RB26.  You can pick up a wrecked R32 GTR with the powertrain in perfect condition from up north for around 6k CAN.  Import as parts car and call it done.
TunerToys
« Reply #44 on: November 19, 2009, 02:04:02 PM »
Initial look is promising.  Better power than the equivalent LS430 for the same year and mileage, as well as being about 30% cheaper.
toyolla86
« Reply #45 on: November 19, 2009, 02:17:28 PM »
the lt1 would be easy and theres probably someone thats already done it.
the 2jz would be legendary and i doubt anyones done it.
be a pioneer. and then do a "how to" write up.
twin50 son. get some
and stop acting like a muslim
« Reply #46 on: November 19, 2009, 02:30:10 PM »
03/04 cobra
find one totaled with no drive train damage
« Last Edit: November 19, 2009, 02:43:42 PM by random-strike »
« Reply #47 on: November 19, 2009, 02:40:56 PM »
H6 POWA!
An H6 could be really cool.  Open up the exhaust, and it will sound like a porsche:
Subaru Outback H6 - No exhaust
Should be really fun with boost, and in a truck there might be enough room to change the spark plugs without removing the engine.
« Reply #48 on: November 19, 2009, 02:44:57 PM »
fysh
« Reply #49 on: November 19, 2009, 02:56:14 PM »
I know you said Car donor only but the '03+ Ford Expedition comes with a 5.4L and IRS.
http://cgi.ebay.com/ebaymotors/2004-FORD-EXPEDITION_W0QQitemZ250532591268QQcmdZViewItemQQptZUS_Cars_Trucks?hash=item3a54e7f6a4
Bet one would be super cheap if you could source one from a Salvage yard.
« Reply #50 on: November 19, 2009, 04:22:58 PM »
Who in their right mind would want a 3 valve 5.4?
fysh
« Reply #51 on: November 19, 2009, 04:36:21 PM »
Its a 2v SOHC, dumbshit. Same as in my Lightning.
« Reply #52 on: November 19, 2009, 05:07:44 PM »
Ok.
Didn't click the link, and I am pretty sure that 03+ includes 05+.
« Last Edit: November 19, 2009, 05:10:48 PM by snm95ls »
« Reply #53 on: November 19, 2009, 10:43:42 PM »
R32 RB26 = oil pump failure.  $1200 plus labor to fit a later oil pump that doesn't suck.
« Reply #54 on: November 19, 2009, 10:48:13 PM »
I drove a RWD WRX this week and, the car was a fucking blast to drive they should have been that way from the factory  :yes:
superdaveosbourne
« Reply #55 on: November 20, 2009, 09:40:23 AM »
Or get a crank out of an R33 for 500 bucks and not worry about machining.
« Reply #56 on: November 20, 2009, 09:57:48 AM »
Or get an engine you can actually get parts for here in the US, like a 2JZ, and not worry about silly things like oil pump failure, whilst making more hp and torque for significantly less money.
superdaveosbourne
« Reply #57 on: November 20, 2009, 10:03:32 AM »
He wanted to be different, so it's different and AWD.
And parts are readily available in the US for RB engines, where do you think I get mine?
« Reply #58 on: November 20, 2009, 10:42:36 AM »
i still say BMW V12 if different is the goal with power being 2nd. power being 1st, 2jz sounds pretty good. ls1 doesnt sound too bad if different doesnt matter at all
« Reply #59 on: November 20, 2009, 10:56:13 AM »
VZ and JZ bellhousings interchange.  I can get parts for 2JZ over the counter at O'reillys and auto zone.
I agree with you the RB is different, but IMO the 2JZ is the better engine.
Pages: 1 [2] 3   Go Up
