Author Topic: a catch can is a catch can is a catch  (Read 38046 times)
toyolla86
« on: November 27, 2009, 08:49:56 PM »
whats the science behind a catch can. arent they all the same. just venting the valve covers
to prevent blow-by right?
i have a hose to a water bottle right now.
how can i make a "real catch can"
it seems like the catch can designs are flawed. like they're only half engineered. what would happen
if you made a drain from the bottom of your catch can to the oil pan. would that mess things up.
twin50 son. get some
and stop acting like a muslim
Re: a catch can is a catch can is a catch
« Reply #1 on: November 28, 2009, 01:01:01 AM »
I've got my drain going to the oil pan. I guess there's a chance that gas can get into it, but at the same time I don't give a fuck.
1slow91hf
« Reply #2 on: November 28, 2009, 02:02:10 AM »
i think that if your drawing enough oil into the can to require a pan drain line youve got bigger issues  :-*
just do a slash cut into the turbo inlet along with a mani line and put a one way valve in it and youll draw vac when idling and under pressure
« Reply #3 on: November 28, 2009, 01:10:03 PM »
I have no oil in my catch can, only water and gas (well, smell like it)... I know the blow by has a lot of water into it, but... I don't know.
I use the turbo inlet as a vacuum into the catch can and the catch can is hooked to the modded PCV valve.
Now that I look at the drawing, it's more an hybrid between these 2 types
« Last Edit: November 28, 2009, 01:15:25 PM by Teg2boo »
toyolla86
« Reply #4 on: November 28, 2009, 02:20:04 PM »
anybody have pics of one being made.
thanks for the diagram. those are helpful.
i still dont quite understand how this equalizes pressure and stops blowby.
1slow91hf
« Reply #6 on: November 29, 2009, 01:46:02 AM »
In fact, the blow by goes into the catch can. I use a vacuum to get it out of motor, but many people said that you don't need vacuum and it will go in the catch can anyway.
In the pics, the PCV valve is replaced by a L fitting or a modded PCV valve.
This is how I did it. http://www.realhomemadeturbo.com/forum/index.php?topic=5043.msg75161#msg75161
BTW, I never noticed you posted a question about the setup!
There are 2 hoses in the setup. One from the modded PCV to the catch can and one from the catch can to the turbo inlet.
« Reply #7 on: November 29, 2009, 02:42:34 AM »
the idea is to just get the pressure out of the crankcase, it can be executed a bunch of ways. you can do it like frenchie with a line from the back or the block or VC to the intake pipe on the turbo so it sucks out the pressure and have a can in the middle to catch the oil.
best way is to put some fittings on the VC and run them to a can with filter on it. the pressure will find its way out.
smarterchild
« Reply #8 on: November 29, 2009, 02:58:07 AM »
bfour the turbo is not a vacume only after the throttle bodys win its close is.
« Reply #9 on: November 29, 2009, 03:03:16 AM »
Before the turbo is a vacuum if you place the L fitting correctly and under boost.
I didn't really understand what you said btw... yar engrish skillz are 2 mach far me.
smarterchild
« Reply #10 on: November 29, 2009, 03:12:54 AM »
just becuse use change the L dosent makes it for vacume.
mebe you can use for your vacume a pumper from a diesels that dont do vacume because of to throttle bodys
« Reply #11 on: November 29, 2009, 03:17:06 AM »
Bernoulli effect dude. Search for it. BTW, where the fuck is your noob post?
It's "vacuum" not vacume. Maybe you can try to learn how to type and fist yourself with a diesel "vacume" pump?
smarterchild
« Reply #12 on: November 29, 2009, 03:19:58 AM »
mybe your father molesting you and jave you a bad atitude. he made you mouth a vacume arounf his wienis
« Reply #13 on: November 29, 2009, 03:31:04 AM »
You just sound like a troll, just go away. Do it short and sweet.
« Reply #14 on: November 29, 2009, 06:19:27 AM »
retard there is always air being drawn pre turbo. do you think the air in the manifold just magically appears there?
toyolla86
« Reply #15 on: November 29, 2009, 12:15:20 PM »
its like i wanna vent the oil pan hahaha. thats what makes sense. but then you need pressure down there too right.
Patrick
« Reply #16 on: November 29, 2009, 01:54:14 PM »
you can always make a 10 buck air oil sperator like i did....
d3ad1ysp0rk
« Reply #17 on: November 29, 2009, 02:40:16 PM »
Turbo inlet draws a small amount of vacuum (more while in boost). The need for a catch can is so if you're recirculating the air coming from the crankcase, you can eliminate the oil/fuel/etc from it before it goes into the intake tract (whether through the turbo inlet or intake manifold). Principles of a catch can are pretty simple, only differences could be port size, can size, filter material, and looks.
« Reply #18 on: November 29, 2009, 02:59:26 PM »
I have always wanted to set up a catch can but never really got around to it. So i like this thread minus the retards.
Is there a way to run a filter inline to the hose going to the turbo inlet? like a carb fuel filter? to catch some of the shit suspended in the vapor being pulled through the catch can.
« Reply #19 on: November 29, 2009, 03:07:19 PM »
Looks good  :-X
« Reply #20 on: November 29, 2009, 03:58:36 PM »
yes.
back in the day when srt4's came out and before catch cans were a hgonda bandwagon the neon guys would put a water seperator in line like the kind you get at lowes homodepot etc. they call it the $20 catch can
« Last Edit: November 29, 2009, 04:03:22 PM by Corey »
« Reply #21 on: November 29, 2009, 04:58:49 PM »
Corey wouldn't that be the same as building a catch can box? or does it work differently then i'm thinking inside? i do like the createvness.
I was looking more along the lines of after the catch can. having a filter that strickly cleans the air vapor before entering the turbo to keep the turbo clean and oil/dirt free?
« Reply #22 on: November 29, 2009, 05:42:38 PM »
catch can boxes with filters arent recirculated back into the intake anyways. basically what youre talking about doing is running 2 inline catch cans basically.
no matter what you do theres going to be laden oil vapors going back into the turbo if its recirc. its just a matter of how much.
« Reply #23 on: November 29, 2009, 06:08:23 PM »
Tell me if i'm being stupid here but this is what i'm talking about. using a traditional box with 2 inlets from the engine and one going to this filter from summit then to the turbo. i would use a drain back to the block also on the can.
http://www.summitracing.com/parts/MRG-2526/?image=large
kgx
  • MR2fag
« Reply #24 on: November 29, 2009, 08:53:40 PM »
oil vapor seperator from a GM quad4:
$2 at the JY.
« Reply #25 on: November 30, 2009, 12:51:53 AM »
Does anyone know if the carby fuel filter would suck balls or work fine? :noel:
toyolla86
« Reply #26 on: November 30, 2009, 01:02:16 AM »
it seems like if blow-by is being created from excessive pressure from under the pistons, then you would want to vent the area under the pistons (the crankcase).
 why then are we venting the area above the pistons.
fix:
im thinking like a snorkle hose from the oil pan with an air filter on top. it would extend a foot or so up and be high on the oil pan just like the oil drain from the turbo.
« Last Edit: November 30, 2009, 01:04:29 AM by toyolla86 »
« Reply #27 on: November 30, 2009, 01:12:21 AM »
fix:
You do know there are huge oil drain passages that easily transfer the "pressure" up to the head where the vc is. right?
Also alot of b series guys run the vents off the back of the block and vc both.
« Reply #28 on: November 30, 2009, 03:54:50 AM »
LOL sounds like a retard with a lisp on medication trying to talk shit. Oh lord.
FYI one problem people have with that rear vent is that under heavy accelleration, the oil returning to the crank (from head) fills that line. Pressure then pushes tons of oil into the catch can if the other lines aren't big enough. I only recommend that lower port for the drain.
You DEFINATELY would not want to tap right off the crankcase. You'd have shitloads of oil getting into the tube due to oil windage. Given the size of the (usually) 4 ports connecting the crankcase and head on a Honda, there will be no noticable pressure drop between them.
yamaha6611
« Reply #29 on: November 30, 2009, 02:04:34 PM »
blowby causes pressure in the crankcase(oil pan). the oil cooler on the back of the motor (pcv port) runs to the intake mani to pull that pressure out, yea it works to create less than atmospheric pressure inside the case, but your still sucking oil into the intake manifold.  the catch can simply eliminates the pcv valve and sucks air pre turbo (constant vaccum)  with a "can" in between so your not sucking oil into the turbo.  breather on the valve cover, black box to a can, vaccum source to pre turbo and youll be set.
dont waste the money on a fancy one, theyre too simple.
mine.
