Author Topic: ATV clutch problem. HALP!  (Read 6230 times)
« on: December 10, 2009, 07:06:03 PM »
2000 or so Honda 300EX.
Since I bough the thing the clutch does weird, never fully disengages.  i.e. If it's in gear and I've got the clutch in, the quad still wants to move forward a bit.  No amount of adjusting helped.
So, I bought a new set of friction/metal plates, springs and installed them.  Same fucking problem.
Any ideas?
Re: ATV clutch problem. HALP!
« Reply #1 on: December 10, 2009, 07:07:01 PM »
streched clutch cable......
Whitey
« Reply #2 on: December 10, 2009, 07:17:51 PM »
Is the basket grooved?
« Reply #3 on: December 10, 2009, 07:47:34 PM »
its not the clutch cable.  I hooked up some vice grips for leverage and even as far as it'll go, clutch still grabs.
Whitey- checked when I changed the discs and no, no grooves. :/
« Reply #4 on: December 10, 2009, 07:48:43 PM »
Make sure its fully warmed up, when the oil is cold and thick they like to still move
« Reply #5 on: December 10, 2009, 08:11:38 PM »
right now there's no oil in the crank case.  I put the cover on with like 3 bolts to test it in case shit was still fucked up I wouldnt have to drain the oil and shit again.
Whitey
« Reply #6 on: December 10, 2009, 10:32:43 PM »
Are you trying to adjust the clutch by just the cable, or did you try adjusting the clutch by the adjuster on the center of actual clutch?
« Reply #7 on: December 11, 2009, 09:15:14 AM »
Both.  It's not a problem with the cable but something in the clutch assembly.  I put a vice-grip on the thing that the clutch cable attaches to so I could be sure I was moving it as far as it would go.
I think I need to look up how these clutches work so I can have a good understanding of how they work.
« Reply #8 on: December 11, 2009, 02:37:46 PM »
my quad kinda kicks forward when its put into gear even with the clutch fully disenaged but it wont move or anything just kinda feels like its n ot fully disengaged when you go from neutral to 1st gear
« Reply #9 on: December 11, 2009, 02:55:32 PM »
what your describing is exactly how all bikes/atvs act when you ride them. you got to remember most clutches have like 5+ plates and it just barely releases the disks when you engage the clutch.
« Reply #10 on: December 11, 2009, 03:46:53 PM »
Well I've had a few quads and wet-clutch dirtbikes before and I know what you're sayin but this one in particular is a bit ridiculous.  i.e. It'll pull me up-hill with the clutch fully disengaged in 1st gear.
Maybe it is a little better now and I won't realize it until everything is buttoned back up and I warm the thing up.
Whitey
« Reply #11 on: December 11, 2009, 05:12:35 PM »
This happened to me when I put heavy ass springs in once.  If you tried both adjustments and you think it isn't right then you have the springs on too tight.
« Reply #12 on: December 11, 2009, 08:55:19 PM »
hrmm...I bottomed out the spring retainer bolts.  wrong move?
« Last Edit: December 11, 2009, 08:58:44 PM by SloS13 »
