Pages: 1 [2] 3   Go Down
Author Topic: Turbo 91' civic 4door build.  (Read 48873 times)
Re: Turbo 91' civic 4door build.
« Reply #30 on: December 24, 2009, 11:21:06 PM »
Updates?
« Reply #31 on: December 25, 2009, 12:07:01 AM »
It's Christmas, and I'm packing all my sisters shit sense she is moving half way across the country. No time for the car. We have a 28" semi trailer in the driveway and 8-12" of snow coming down.
LAME!!!!
« Reply #32 on: December 26, 2009, 01:59:09 AM »
LAME!!!!
that is possibly the shortest semi trailer in the world
« Reply #33 on: December 26, 2009, 02:32:49 AM »
yeah they hook up 2 of them, it's way cheaper on our end, as they can't mix other orders in with our stuff. but $1000-1200 for 5 day delivery to Charlotte, NC not bad.
« Reply #34 on: December 31, 2009, 07:44:16 AM »
Well here is my little update.
Obd 0 d16a6 intake manifold that i clean up the ports on and polished the throttle plate. I cleaned it and assembled with my 680cc injectors.
TPS removed from old IM and added with SS hardware.
Here is the turbo outlet that i welded up. I made the 3 bolt flange and used an outlet tube of a 1g dsm smic. (btw hardest thing i ever welded as it was 3/8 plate to 16g with no room to spare for the bolts)
here is the srt4 intercooler core i made new end tanks for. It has 2" outlets and mounts to the radiator support. still fits the oem power steering cooler.
Here is a little shot of the welds.
As far as i got on the engine before i screwed up a oil control ring. I'm retarded.
« Last Edit: January 25, 2010, 03:12:44 AM by turbob16hatch »
DelSlow
  • Ass to Mouth
    • FargoStreet
« Reply #35 on: December 31, 2009, 08:19:16 AM »
Spanish-rice
« Reply #36 on: December 31, 2009, 11:18:44 AM »
might be a stupid question but are the arrows supposed to face the back of the engine with vitaras?
« Reply #37 on: December 31, 2009, 01:26:34 PM »
I always heard the vitara's spun backwards and thats the way it's done properly.
« Reply #38 on: December 31, 2009, 01:32:22 PM »
Thats how I have mine.  ;D
Spanish-rice
« Reply #39 on: December 31, 2009, 02:03:14 PM »
alright just making sure it looked funky at first
« Reply #40 on: January 02, 2010, 08:03:24 PM »
mine point toward the rear as well.  do some searching and you might learn something useful
« Reply #41 on: January 02, 2010, 08:16:50 PM »
Yes.
Pin offset is correct for Honduhs this way, and keeps them from souding like a diesel.
I read that on the internet somewhere....
« Reply #42 on: January 08, 2010, 07:26:47 PM »
Yes.
True but either way it will work, it will just sound louder the other way.
« Reply #43 on: January 15, 2010, 04:39:03 AM »
So now that you're back home, when you are going to finish this pile?
« Reply #44 on: February 20, 2010, 05:47:15 PM »
Well not much of an update on the car itself but i did find my turbo i will be running on the "summer" turbo kit.  My long search is over for the little guy.
Stock 300zx T3 60 trim, stg1 turbine .63 a/r housing.
I'm still unsure if i'm going to run the .48 a/r or the .63 a/r hot side. Goal here is for a nice fat powerband with a 7000-7200 rpm redline.
Before this goes on the car i will rebuild it and get it all cleaned up. Also i will get a wet center housing to add some longevity.
« Reply #45 on: March 02, 2010, 03:52:55 AM »
what a piece of shit.
buk9tp
  • i know nuthin bout nuthin
« Reply #46 on: March 02, 2010, 10:57:01 AM »
speedjunky01
« Reply #47 on: March 03, 2010, 12:27:50 AM »
work on the mini ram looks amazing!
with how its of set you plan on keeping ac?
« Reply #48 on: March 03, 2010, 12:44:19 PM »
I'm building it a/c compatable. I removed my a/c as it had a leak and stopped working mid summer. I will get it back in this summer and get the p/s cooler replaced with a more conventional "radiator" style core that will replace the heat sink tube thing thats in the way.
speedjunky01
« Reply #49 on: March 03, 2010, 01:41:55 PM »
nice!
90turboteg
  • Rebuildin turbos
« Reply #50 on: March 06, 2010, 06:17:12 AM »
any updates nog. looks like a fun dd, i need to get my crx done so i can stop driving my pos subaru wagon. i ran one of those Nissan turbos on my old integra. looks like a fun setup
« Reply #51 on: March 06, 2010, 06:49:02 AM »
No i have some work stuff i'm needing to finish first. So it's going to be a bit before i update it.
« Reply #52 on: April 13, 2010, 08:14:46 PM »
well i forgot my camera so no pictures. But i got the bottom end assembled and now i just need to get the acc. bolted up and it is ready to drop in.
All in all it went together fine, even though i was quite nervous.
« Reply #53 on: April 13, 2010, 09:15:20 PM »
my vitaras pointed towards the t-belt.  didnt sound like a diesel.  honestly, it sounded stock even with super sloppy p2w
SDRAWKCAB
  • D series BALLA!
  • Rhino
« Reply #54 on: April 13, 2010, 09:29:37 PM »
I did a right up on oHMT about the how the arrows on vitaras should face the flywheel because of the pin offset.
If you look up a vitara pdf the arrows should point to there crank pully which is on the left side of the engine.
vitata clockwise
d16 counter clock.
I like your build BTW, the mani got my pants all tight.  ;)
« Reply #55 on: August 22, 2010, 03:16:04 PM »
UPDATE:
Ok so i finally got around to working on my car. Here is some progress shots. Now i just need to finish my dp and get the car on the ground. then it's time to start it and tune.
engine:
Engine in car:
freshly powder coated vc:
Vx wheels before powder coating:
I will have another update later this week.
« Reply #56 on: August 22, 2010, 07:53:49 PM »
Looks good, just get a z6 intakemani.
« Reply #57 on: August 23, 2010, 06:56:03 AM »
I used to have one, i decided to go back to the old school a6 one. Has nothing to do with performance i just thought it fit the car better.
« Reply #58 on: August 23, 2010, 04:04:03 PM »
Paint that IC black
You get your LS rods modified at a machine shop local to you?
« Reply #59 on: August 23, 2010, 05:59:48 PM »
Paint that IC black
You know i had thought about painting it, but I'm unsure if it will just chip and look like shit it a week. Any experience with them painted?
Yes, there is a really laid back machine shop in town that builds all the dirt track car engines (just don't expect anything to be done a few months before racing starts). It was $140 out the door for them.
Pages: 1 [2] 3   Go Up
