Pages: 1 ... 5 6 [7] 8 9 ... 13   Go Down
Author Topic: The Turbo Chevelle. It lives!  (Read 465926 times)
JACER63
  • well shit..
Re: The Turbo Chevelle. Uh ohhhhhh
« Reply #180 on: February 06, 2010, 03:18:26 AM »
love this build...updates?  come on!
by the way the tial wg u sold me works flawless...thanks again
Fuck yea, that was the black one correct?
yes sir!
Re: The Turbo Chevelle. I got my lashing :)
« Reply #181 on: February 06, 2010, 11:02:11 AM »
Your just sick! Make me want to turbo my 03 yukon :yes:
DO ET!
« Reply #182 on: February 06, 2010, 12:03:04 PM »
DO ET!
She has 123k on her right now. I think a Hx-55 would be sweet and tons of flux cord :evil: Just not sure what injectors  or what ems to use?
« Reply #183 on: February 06, 2010, 12:15:19 PM »
I bet JD knows what EMS to use.
« Reply #184 on: February 06, 2010, 10:00:26 PM »
Where is that niggerface how he lovenly call me over a text :P
bouncinofftherevlimiter
« Reply #185 on: February 06, 2010, 11:10:20 PM »
there was another text not long ago he was talking about using EFI live, and how well it worked, even compared to LSx standalones such as BS3 and what not..
http://www.realhomemadeturbo.com/forum/index.php?topic=12318.0
i may not post alot... but i do read and suprisingly remember... alot
No longer own a turbo car...
HX35 18lb 486hp/391tq
lsone_chevelle
« Reply #186 on: February 06, 2010, 11:56:03 PM »
honestly efi llive or hp tuners for anything under 1000rwhp.
motron 60lb injectors. 400 beans. Plug and playISH. 40 bucks for ls1 car injector plugs and some 3/8" hard line to space the fuel rails 1/2" up.
« Reply #187 on: February 07, 2010, 08:23:41 PM »
There are ways to rescale the MAF in order to make more than 1000 whp.
lsone_chevelle
« Reply #188 on: February 07, 2010, 09:08:53 PM »
yea IE run speed density O0 sy/ty IAT sensor wired into factory maf wiring. 2 bar / 3 bar map up top. Done.
Thats what I did. Thats what many guys do aswell. I follow what works well.
« Reply #189 on: February 08, 2010, 12:38:54 AM »
Hum you have me thinking now :evil:. What you think the stock 4wd trans is good for hp/tq wise?
« Reply #190 on: February 08, 2010, 11:03:45 AM »
Operating from a Ford-based perspective, and having no GM experience beyond OBD1, that's not what I was thinking.  But it is probably the best method for that application.
lsone_chevelle
« Reply #191 on: February 08, 2010, 09:14:12 PM »
We ls guys up in Canada like tuning SD more so then MAF. Yes you can get away with the MAF but it is soo much simpler. 2 less clamps, easier piping, etc etc. Along with MAF can act up. Even N/A I had issues with my MAF getting wet in rain and making the car run like shit. (I run no inner fenders)
lsone_chevelle
« Reply #192 on: February 08, 2010, 09:16:17 PM »
the 4l60 isn't much of a tranny to be honest. I would put a transgo HD2 kit in it before I drove it boosted. Thats the downfall. 4l60s are expensive to build to handle abuse aswell. :(
« Reply #193 on: February 08, 2010, 09:17:23 PM »
I was wondering if it was a 4L60.
Throw an upgraded sun shell in it as well.
« Reply #194 on: February 17, 2010, 05:13:47 PM »
I guess I never heard of the GM sensors working well. Working, but not well. I guess it doesn't matter when you can just throw displacement at the problem :P
lsone_chevelle
« Reply #195 on: February 23, 2010, 01:13:20 AM »
You are hanging out with the wrong people then. Never once had an issue with a GM Cobalt SS 2 bar Map. GM 3 bar map. Syclone IAT sensor, etc etc. Not once.
lsone_chevelle
« Reply #196 on: February 23, 2010, 01:15:56 AM »
Got the rear end out. Gonna wash it, weld the axle tubes, cut the ends off, put c clip elims on. get those pressed onto the moser axles. Put new 5/8 wheel studs in, paint it. Slam it back in. Wait for brakes to sell then buy new ones.
Got my rims back from powder coat. Mounting new drag radials 275/60/15.
Also got a new RCI fuel cell. Foam, baffled, sumped, and has a fuel level sender.
Also bought a Aeromotive A1000 fuel pump and filter.
Acestainless order is in the mail.
Re: The Turbo Chevelle. Some new parts
« Reply #197 on: February 23, 2010, 10:07:36 AM »
275?  seems small for all you got going on aren't those deep rims?  Id try to stuff as much rubber as you can under neath that thing lol.
« Reply #198 on: February 23, 2010, 12:44:40 PM »
Should put real slicks and do some wheelies :evil:
« Reply #199 on: February 23, 2010, 01:00:55 PM »
Should put real slicks and do some wheelies and barrel rolls :evil:
« Reply #200 on: February 23, 2010, 02:40:00 PM »
Should put real slicks and do some wheelies and twist the windows out of it :evil:
lsone_chevelle
« Reply #201 on: February 23, 2010, 08:34:55 PM »
275/60/25 on a 15x10 wheel is going deep 7's now. Full tubbed, big tire, Big block carbed junk times are gone. This is the new era of racing boys.
lsone_chevelle
« Reply #202 on: February 23, 2010, 08:35:48 PM »
anti roll bar in the rear will prevent this :) if it hangs them, it will hang them dead even.
« Reply #203 on: February 23, 2010, 09:08:03 PM »
All this shinny new shit and v-band everything makes my pee pee hard and drippy!
« Reply #204 on: February 24, 2010, 10:38:35 AM »
Right on.  why a 10 wide rim?  You said you had to sacrifice brakes for it could you have gotten away with an 8?
« Reply #205 on: February 24, 2010, 01:09:44 PM »
Shhhhhh... Dont tell Johnny.
lsone_chevelle
« Reply #206 on: February 24, 2010, 08:33:30 PM »
Sounds slightly hypocritical but it isn't. A 10" wide rim allows the widest possible footprint available when running a 275/60/15 tire. 8" Works, and it works well but you gain more contact patch with the added 2 inches.
lsone_chevelle
« Reply #207 on: February 24, 2010, 08:33:56 PM »
Its the truffs!
« Reply #208 on: February 24, 2010, 08:47:01 PM »
why would a wider rim make a wider contact patch? would that be all on the tire? a 275 is 275 mm wide regarless of what rim its one isnt it?   Not trying to argue just tryin to understand.
98redcavz24
  • NE Crew
« Reply #209 on: February 24, 2010, 08:55:19 PM »
I think what he MIGHT be saying is that the wider rims allows for more surface footprint where as a less diameter rim would cause the tire to lose that X mm amount due to slack that is left around the sidewall. In other words, just because the tire measures xxx mm in diameter, you are not necessarily taking advantage of the size unless you have the rim width to do so
Pages: 1 ... 5 6 [7] 8 9 ... 13   Go Up
