Author Topic: 3bar map sensor in stock map case?  (Read 35230 times)
« on: December 31, 2009, 03:07:10 AM »
ok i know it has been done to death in the obd-1 cases. but can this be done to a obd-0 case?
I want to keep the oem obd-0 case for looks.
lmk
Re: 3bar map sensor in stock map case?
« Reply #1 on: December 31, 2009, 03:33:07 AM »
I think the problem is that most of them are a 1-pc w/epoxy case. The obd1's are nice because they are 2-pc, with goo & plastic ribbing inside that is ground away easy enough. It's been forever since I looked at my spare, and I don't even know where it got stashed.
AFAIK you'd have to cut it like a brain surgeon, grind out the sensor (will probably be in the way), grind a path to the electrical tabs, and "stitch" it back up with epoxy afterwards. So in terms of looks, it will look hacked anyways. :-\
Also, nothing will help hold it together like the rivets & bolts on the obd1 cases.
« Reply #2 on: December 31, 2009, 03:45:27 AM »
damn thats not what i was looking to hear.
« Reply #3 on: December 31, 2009, 03:50:49 AM »
Just use the obd1 case and run a vacuum line off the bottom and mount it to the firewall.
« Reply #4 on: December 31, 2009, 04:01:03 AM »
well mise well get a gm 3 bar at that rate.   :-\
« Reply #5 on: December 31, 2009, 04:25:06 AM »
You should be able to source a obd1 map for under 10 bucks shipped. Im sure I have some extras laying around in my bin of sensors.
« Reply #6 on: December 31, 2009, 04:28:25 AM »
oh i have plenty of parts, just not really into mixing obd1 with obd0.
« Reply #7 on: December 31, 2009, 05:04:10 AM »
Might as well play "pin the tale on the high vacuum cell" with the GM pos while you're at it. Same for "pin the tale on the 3rd party manufacturer's true voltage/pressure graph". :P
One thing I did think up a while back is to make a bracket/base the obd1 sensor bolts to, with a bigger nipple threaded into it. You can bolt it up where ever (firewall, steering knuckle, trunk?), and even have some bling if you polish it up nice. I'll post some mspaint pics once I finish faxing some chit tomorrow.
BTW the ideal solution is to run it obd1 from the intake gasket backwards to the MAP sensor...most obd1 IM's tend to be better for power anyways.
« Reply #8 on: December 31, 2009, 08:36:18 PM »
What the MAP sensor reads, approximately, is irrelevant.  That it has sufficient span is all that matters.
« Reply #9 on: December 31, 2009, 08:42:38 PM »
gm 3 bars are only 36 bux
« Reply #10 on: December 31, 2009, 10:59:31 PM »
For the obd0 just dake a dremmel and cut away on the backside. Ive done it 2 times, works good for me. Then I had some left over window weld after some mounts I did, and I just filled it up and smoothed it out. There is a bing of rubbery shit inside the case once you getr into it. So dont wear anything you care about whne your using the dremmel.
« Reply #11 on: January 01, 2010, 05:36:23 PM »
Really? nice. Can you shed some light on the wiring, is it the same as the obd1 process?
« Reply #12 on: January 01, 2010, 05:47:00 PM »
Well as far as the wiring, I just looked on xenofraud's site. And used the wiring diagram he had, and used my feescale 3 bar and called it a day.
FreshDA9
« Reply #13 on: January 01, 2010, 07:26:29 PM »
a little off topic but i was searching around for Motorola Map Distributors and came across this.
http://www.made-in-china.com/products-search/hot-china-products/MAP_Sensor.html
an actual website called Made In China figured someone might benefit from the ChinaDM
« Reply #14 on: January 01, 2010, 11:31:04 PM »
That, alibaba, and twenty other sites will put you in touch with chinaman who demands $10K up front no prototypes.
« Reply #15 on: January 01, 2010, 11:41:54 PM »
What is with people thread jacking my shit lately. dumb niggers  ???
« Reply #16 on: January 02, 2010, 12:26:59 AM »
Because you only make top notch threads, sir.  If the thread is not quality then there is nothing to defile, you see.
« Reply #17 on: January 02, 2010, 12:57:32 AM »
true, haha
« Reply #18 on: January 25, 2010, 03:23:35 AM »
Well i started working on the map sensor finally. All in all it wasn't that bad, took about 20-30 min. Next one i could do in about 10 min but i was flying blind here and didn't want to ruin the case.
Here is the top of the case, where you need to remove the sealant and cut open the metel case inside.
Here is the bottom of the case. This is left alone.
This is after i cut open the case and gutted everything out of it. (everything gets removed minus the 3 posts in the center)
Here is the gutted case with the new 3bar map sensor next to it.
And here you can see the map sensor in place. there is an oring that seals the sensor nipple. It fits perfectly in the hole.
Now i will take the map sensor to the local tv repair place to have some wire soldered onto the leads. As i'm uncapable and do not have a good enough soldering gun/iron to do this.
I will update when i finish it up.
« Reply #19 on: January 26, 2010, 01:04:11 AM »
does anyone know a good epoxy or something along that lines that i can use to fill the space after everything is soldered?
« Reply #20 on: January 26, 2010, 02:51:54 AM »
Window weld. Thats what I used.
« Reply #21 on: January 26, 2010, 03:11:33 AM »
Hot glue works.
« Reply #22 on: January 26, 2010, 03:44:00 AM »
I recommend RTV.
1slow91hf
« Reply #23 on: January 27, 2010, 04:30:52 PM »
 O0 rtv then put some JB on it to just finish the sealing
kgx
  • MR2fag
« Reply #24 on: January 27, 2010, 07:52:06 PM »
I recommend RTV.
go to menards/home depot/fleet farm (WI and MN only i think)/lowes, etc and go to the fireplace/heating section. they sell black RTV in a 10oz caulk tube for about $4-6. that's what i use to pot the MAP sensors i make. it's the same as auto RTV, but is way cheaper than the $6/3oz.
also, has anyone found anything that actually removes that GOO inside the housings? i've never found anything that can dissolve it.
« Reply #25 on: January 27, 2010, 09:08:36 PM »
I havent found anything realy that gets rid of it eather. It fucking sucks because it gets metal shavings in it and then if your using a dremmal like I do it flings that shit everywre and your gona get metal slivers for sure.....lol
kgx
  • MR2fag
« Reply #26 on: January 27, 2010, 10:44:37 PM »
it's like indestructable snot.
brake fluid was slightly effective at getting it not to stick to the plastic so i could ball it up. carb cleaner had no effect. acetone had no effect. denatured alcohol had no effect. mineral spirits, goo gone, brake cleaner, trichloroethane, none of it worked. aircraft remover/paint stripper ate away the housing before it did anything to the goo.
shit is nasty.
« Reply #27 on: January 28, 2010, 07:10:08 AM »
i just used a pick out of my tool box and an old needle nose pliers to smash up the board and removed most goo in 10 min. wasn't to big of a deal. But then again i didn't use a cut off wheel on my dremel, i use a metal cutting bit, and destroyed it in the process.
Yeah we have fleet farm here in fargo, nd. good prices there.
« Reply #28 on: February 06, 2010, 04:46:32 AM »
Well i just got this finished up and i think it turned out pretty nice.
well the tv repair guy soldered it up nice.
Here i filled it up with black rtv.
Thanks guys for the help.  :noel:
« Reply #29 on: February 06, 2010, 08:13:37 AM »
i think i would have just painted a gm sensor black, looks close enough  to the stock one.
looks good though, does it work?
