Pages: [1] 2 3   Go Down
Author Topic: vitaras in a d15?  (Read 60458 times)
gooseman
vitaras in a d15?
« on: January 03, 2010, 07:18:35 PM »
The search engine on the site suck major balls.
Can one put vitaras in a d15? I got a mini-me and I'm finally turboing that shit. I would like to make it last.
Re: vitaras in a d15?
« Reply #1 on: January 03, 2010, 07:22:59 PM »
Stop posting and SEARCH
« Reply #2 on: January 03, 2010, 08:09:36 PM »
YES
« Reply #3 on: January 03, 2010, 09:08:35 PM »
get a good tune then
« Reply #4 on: January 03, 2010, 09:38:37 PM »
B16 rodzzz
« Reply #5 on: January 03, 2010, 11:34:41 PM »
« Reply #6 on: January 03, 2010, 11:36:23 PM »
Nonsense, that extra 5mm can be occupied by a couple slices of bologna.
« Reply #7 on: January 03, 2010, 11:43:15 PM »
« Reply #8 on: January 03, 2010, 11:44:20 PM »
jdm d15b vtec block
SOHCKLR657
« Reply #10 on: January 04, 2010, 01:36:48 PM »
Search like this.
www.google.com
why am I such a dumb ass noob site:realhomemadeturbo.com
« Reply #11 on: January 04, 2010, 04:50:47 PM »
Fjt is working on a set of rods for the us d15.
« Reply #12 on: January 04, 2010, 05:12:49 PM »
I was quoted that 2-3 years ago. In this economy I highly doubt its actually going to happen.
Nothing against him atleast he is trying but I highly doubt it will ever happen.
gooseman
« Reply #13 on: January 04, 2010, 05:55:35 PM »
hmmm, I was just thinking of using pistons. I didn't think of rods.
 So b16 rods work? Or are you fuckig around? How about LS rods?
« Reply #14 on: January 04, 2010, 06:29:55 PM »
oczc as a set for the usdm. They hold 600 hp and are 99 shipped.
« Reply #15 on: January 04, 2010, 06:33:13 PM »
hungary.
now search ya puss pumper
« Reply #16 on: January 04, 2010, 06:38:37 PM »
Last set in stock? I just sold the motor I built with OCZC rods, that thing took a beating and kept on going. Best $100 I ever spent.
« Reply #17 on: January 04, 2010, 07:56:30 PM »
He makes them to your specs. What a rip off what other people are charging for rods.
gooseman
« Reply #20 on: January 05, 2010, 06:34:52 PM »
A d16 is all of $100 for a block - less if you find one with some issues that your build will fix. They'll be cheaper, make more power, spool faster, the works. If you're spending any money on a rhmt kit worth a damn, a built d15 (non-d15b) just doesn't make sense.
gooseman
« Reply #21 on: January 05, 2010, 07:06:39 PM »
so far this is what i got.
ihi turbo of probe-free with stock down pipe
hf manifold with t/3 flange-40
manual boost controller-10
safcII-50
oem svo intercooler-15
blow off valve-free
still need feed lines, piping, 440's, arp h/s,good head gasket,flange adapter,clutch and boost guage not bad for 115 into it
« Reply #22 on: January 05, 2010, 07:45:35 PM »
no safc.
chip the ecu.
« Reply #23 on: January 05, 2010, 08:29:52 PM »
safcII so I can blow up my motor like a dumbass-50
blow off valve-free
Interesting!
« Reply #24 on: January 05, 2010, 09:50:59 PM »
why do so many people still buy those things for hondas? 30 seconds of google searching on 56k dial-up will tell you that chipping is the only way. i just dont get it.
« Reply #25 on: January 06, 2010, 03:40:13 AM »
Because dialing in a few limited, poorly-named settings > "fucking up" via every conceivable option availible. Basicly if they're given less options, they think they have a lesser chance of blowing it up... :evil:
I'd rather spend $50 on a decent burner & rock a basic step retard, and have to "eyeball" the afr's. Actually that was my first setup, and was awsome.
« Reply #26 on: January 06, 2010, 05:20:50 AM »
Vitaras in a D15B VTEC with be .018" out of the hole.
gooseman
« Reply #27 on: January 06, 2010, 11:03:21 AM »
As far as the safc goes, I got it from a friend. He needed money, and I was just gonna be out 50 bones, so he gave this up. People have been doing it for years, I really don't see the problem.
It's like you telling me that a chipped ecu is the only way because its better than the safc. So is a "real turbo manifold" (log/ram) the only way, because its better then the HF manifold with adapter?
Ass Clown.
ok, sweet. What rods are you using? Seems like the OCZC rods are the preferd option.
Can the tops of the pistons be taken down on a surface grinder. Wouldn't that allow more clearance and lower compression?
« Reply #28 on: January 06, 2010, 11:15:19 AM »
That's because you're a fucking idiot.
Enjoy advancing timing under boost.
« Reply #29 on: January 06, 2010, 11:16:23 AM »
When you blow your shit because your timing is fucked from using the SAFC, don't come here fucking crying.
It's solid advice. A chipped ECU IS better, because you can actually tune the timing, fuel, etc.
A SAFC is a hack, nothing more.
Pages: [1] 2 3   Go Up
