Author Topic: 220v mig power source?  (Read 28198 times)
NoPistons!
« on: January 12, 2010, 12:43:27 AM »
Just pull my washing machine/dryer from the wall and run an extention cord?
Going to borrow a mig from a friend so i can do mounts and shit for my piston powered rx7 to piss rx7 club off......  Well, pretty much to have a cool chassis around a motor that makes some fucking torque.......
Yes.  I've seen the light.  Fuck a rotary.  I'm probably using 1/8"/3/16" plate and some box tubing to weld the stock KA engine mount brackets to some hacked up 13b subframe  mounts.   Reinforced with the box tubing and plate......
Need to know because there's no point in getting my parts car dropped off at my house if i can't do the job at my house.
220v ac is what our shit to wash our clothes runs off of iirc so i should be all good?   Could i get away with 110v flux core?
« Last Edit: January 12, 2010, 12:46:27 AM by NoPistons! »
Re: 220v mig power source?
« Reply #1 on: January 12, 2010, 12:51:11 AM »
yeah plug into your dryer or stove. You can also wire it into your fuse panel for darwin goodness.
« Reply #2 on: January 12, 2010, 01:06:44 AM »
It is not that Darwin... :P
NoPistons!
« Reply #3 on: January 12, 2010, 01:44:56 AM »
2 for 2 i could do this really close to my house with the engine bay fuel lines uncapped.....
Would make a hell of a www.darwinawards.com story.  Murphy's motherfucking law.
Alright, washer/dryer 220v socket ok yes?
THE SOCKET.  Smartasses.....
SgtB
« Reply #4 on: January 12, 2010, 02:38:48 AM »
There are different styles. Draw a picture, go to fucking HD.
« Reply #5 on: January 12, 2010, 03:02:47 AM »
most welders can run off of 110 im pretty sure, you just have to double your power settings
7808
« Reply #6 on: January 12, 2010, 05:10:35 AM »
he probly doesnt want to cut up his friends cord on his nic,e welder thought, unless he made an adapter...
most welders take a socket that looks like a standard outlet but much larger,  2 parallel blades one is larger, and a ground below/above
some dryer ones have a up and down blade and side ways blade or other wierd shit
its differnt depending on the amps the circuit is rated for i think
you can probly go buy a receptical for the welder cut power to the dryer and swap it out while u use it.  dont kill your self dont even do it if your not familiar with high voltage wiring
« Reply #7 on: January 12, 2010, 12:42:20 PM »
you don't need a plug. Just strip the insulation off the extension cord and plug the wires into the holes. Like this
« Reply #8 on: January 12, 2010, 06:30:18 PM »
Sweet!! Safety First!  Hope you rent.
« Reply #9 on: January 12, 2010, 09:05:38 PM »
LOL, well it was rented, but I rented it from my folks. So if it would have burned down I might as well have owned it... Did it lots of times never had an issue.  :mexi:
« Reply #10 on: January 12, 2010, 09:44:47 PM »
FRONT PAGE
« Reply #11 on: January 12, 2010, 11:27:54 PM »
Oh fuck now thats bad, as in not safe......
7808
« Reply #12 on: January 12, 2010, 11:54:09 PM »
thats really not even that dangerous, whats gona happen?  wires gona fall out and you stop welding?
« Reply #13 on: January 12, 2010, 11:59:13 PM »
The wire actually held in there pretty good, I was impressed. Not gonna lie I have done it since then. There is a member on this board, that has an aluminum BOV flange tig'd on to his charge pipe that I used that.  :D
NoPistons!
« Reply #14 on: January 13, 2010, 04:11:53 AM »
This is the type of shit i like to see.
Home fucking made ghetto fabulous.
Yeah, i'm not an electrician, which is why i asked.
I know positive, negative and ground.
I also know what i'll be welding will be close to a 1/4" thick so i dont think a 110 will cut it.
So i could swap the 220v male plug for a 110v male plug on the machine and be good to go pretty much or is that too much current going through much resistance?
Fuck.  Sorting through google is fucking lame.   I've ran alot of shit off a single 110v socket so yeah, it should work fine, right?
I dunno.  My friend has his washer/dryer shit running off 110 power.  Hardwired OUTDOORS at that.  If his dodgey wiring works out then me switching a plug on a machine.......  Whatever.  Just yay or nay on that shit?   I'm not ripping the wall socket out and hard wiring shit if i dont have to.
NoPistons!
« Reply #15 on: January 13, 2010, 04:21:05 AM »
I think i may have to tap into the dryer socket, like it or not or find a friend who's an electrician to help me out.  Really, i do not want to get zapped or light shit on fire that i dont want on fire.....
Running a 220v machine off a 110v outlet will fuck it up from what i'm reading....not that i believe EVERYTHING i read on the internet.  Just seems to be the common thing i'm finding.
This is the cheap china piece of shit i'm doing my motor mounts and tranny mounts with.  If it lasts though that without burning out.....and i'll be surprised, it's paid for itself.
http://cgi.ebay.com/NEW-Clarke-190EN-Mig-Fluxcore-Welder-220V-Gas-No-Gas_W0QQitemZ310191101143QQcmdZViewItemQQptZBI_Welders?hash=item4838d494d7#ht_630wt_940
« Last Edit: January 13, 2010, 04:24:46 AM by NoPistons! »
caged
« Reply #16 on: January 13, 2010, 04:43:01 AM »
We have all  240v through the whole house, I just assumed the rest of the world did too. apparantly not lol ???
NoPistons!
« Reply #17 on: January 13, 2010, 04:58:01 AM »
Ok.
Here's what i've read.
It's the amps that matter, not the volts.
I have 2 60 amp breakers, 2 40 amp breakers and the rest are 20/15 amp......  No outlets on a 30 amp breaker even remotely close to where i'd like them to be......
Reading that, something would definately fuck up trying to draw that much current (especially on a high duty cycle welder) on a 110v socket wired to a 20 amp breaker.  I'm calling an electrician and getting ready for butt rape fees.
Some things i find are NOT DIY.  I could cut power but i dont trust the asshat that built the house.
Edit:  No wonder my fucking bathroom and kitchen lights keep blowing. *angry face*
Here's the jank i need to make.
No way that's 1/4" thick.....  Not even close.
It's been holding up fine on his car.  Pretty much stock engine brackets welded to the rotary engine mounts.  There is no added shit there.
That and a tranny mount doesn't have to be cock diesel in a car not expected to EVER make over 350wtq?
I have problems.  Upstairs problems.  Well aware of that.
« Last Edit: January 13, 2010, 05:41:26 AM by NoPistons! »
Kain
« Reply #18 on: January 13, 2010, 12:45:22 PM »
wtf are you doing?
NoPistons!
« Reply #19 on: January 13, 2010, 04:09:46 PM »
Doing one more thing for people to talk shit about......
I like drifting.  1 strike against me.
I'm putting a piston engine in a rotary car.  2 strikes
Talking to my landlord trying to figure out how the fuck we're going to fix this problem.  probably 3 strike.
« Reply #20 on: January 13, 2010, 08:44:32 PM »
just go to home depot and get some 10/3 or 8/3 wire, get a male plug that fits your washer/dryer/stove and get a female outlet that fits the welder plug. make extension cord and weld away. think of it as a jumper harness for an obd0 honda. the welders plug and your appliances have diff plugs.
Hotrodlincoln
« Reply #21 on: January 13, 2010, 09:10:25 PM »
This
my brothers been building demo derby cars this way for years and he has a big lincoln welder.
kill yourself piss face
SgtB
« Reply #22 on: January 14, 2010, 04:40:12 AM »
Red and black are hot, green is ground.  Show me your dryer socket and the welder plug and I'll draw you a diagram.
NoPistons!
« Reply #23 on: January 14, 2010, 08:01:25 PM »
COREY, YOU ARE THE FUCKING MAN!
Straight up.
I thought green, and red were hot and black was the ground.
I'll pull the shit out when my welder gets here and i get some gas and take pics.  It should be sometime towards the end of the month when uncle sam gives me the $3000 i'm entitled to.
Kain, you should be excited.  Town told me i COULD NOT do this after i asked my landlord if i could run my shit under the house and have an outside outlet.  He told me "get ready to pay a $2500 fine and additional fines every 15 days you have that car on the property.  New town ordinance.  I can get the motor but i can't have my car on jackstands overnight.....which really fucking slows some shit down.  I'm stuck with the timebomb.....for now.  The rotary WILL not win.
I'm still getting my fucking welder though.  The city and my landlord haven't said shit about me welding in my front yard.
trevor72
  • trevwhore
« Reply #24 on: January 21, 2010, 03:50:23 PM »
diagram - this is what mine looks like
1fasthf
  • RHMT resident Bruce Buffer
« Reply #25 on: January 21, 2010, 08:51:42 PM »
^^^front page^^^^ i love this site
7808
« Reply #26 on: January 24, 2010, 11:48:03 PM »
shit i recognize that floor, i just installed 600sq ft of that shit in my house lol
« Reply #27 on: January 28, 2010, 04:48:05 AM »
More like:
Drifting -1
Piston conversion on an RX7 +2
Current total +1
You're doing okay so far, carry on.
SgtB
« Reply #28 on: January 29, 2010, 12:59:46 AM »
Watch it sticking wires in sockets like that. We refer to that as a hot spot. It's a giant resistor and can possibly melt the socket.
gsx750r93
  • N00B *Read Intro Sticky*
« Reply #29 on: February 02, 2010, 08:54:28 PM »
[/quote] shit i recognize that floor, i just installed 600sq ft of that shit in my house lol
[/quote]
I would not do it like this... If one of those legs were to fall out then there is a good chance you could fry your welder. Just go buy a 220v cord cap from home depot. Its easy to install and take only 5 min of your time.
