Author Topic: Turbo LEAKING oil  (Read 69161 times)
b20beast
Turbo LEAKING oil
« on: March 25, 2009, 09:29:31 PM »
When my car is switched off, oil LEAKS out my garrett t3 t4, by the turbine side where you clock the turbo thru a bolt.
What the hell could be the cause
Re: Turbo LEAKING oil
« Reply #1 on: March 25, 2009, 09:41:28 PM »
Seals could be going? Rip off the compressor housing and take a took.
b20beast
« Reply #2 on: March 25, 2009, 09:43:51 PM »
new bearings and seals
but why would it leak when car is off?
« Reply #3 on: March 25, 2009, 09:45:07 PM »
Im sure it leaks when it is on. Obviously it is leaking on the cold side
b20beast
« Reply #4 on: March 25, 2009, 09:49:06 PM »
i meant to say leaks on exhaust side
where to clock the exhaust bolts sorry.
only in and out play, no left to right
« Reply #5 on: March 25, 2009, 09:49:54 PM »
Your car isn't smoking like a crack whore?
b20beast
« Reply #6 on: March 25, 2009, 09:50:56 PM »
fuck yeah
like a house is on fire
what is the cause??
new seals and bearings
« Reply #7 on: March 25, 2009, 09:53:06 PM »
what turbo is this?  what size oil line? restrictor?
b20beast
« Reply #8 on: March 25, 2009, 09:55:02 PM »
garrett t3 t4 60trim/ .63
-3an feed
1/2" oil drain
drain wasnt too good, so i clocked turbo about 45* and let it drain downhill.
not sure why oil will leak with car off and thru the bolt.
« Reply #9 on: March 25, 2009, 10:08:38 PM »
your shit got blaasted didnt it
b20beast
« Reply #10 on: March 25, 2009, 10:10:03 PM »
not sure what you mean but i rebuilt it
how would oil be leaking when no oil is feeding inside the turbo?
b20beast
« Reply #11 on: March 25, 2009, 10:11:35 PM »
dont think i nneed a restrictor
line is -3an and its a journal bearing turbo
car has not been boosted
b20beast
« Reply #12 on: March 25, 2009, 10:17:21 PM »
what size restrictor ?
b20beast
« Reply #13 on: March 25, 2009, 10:18:41 PM »
why would it leak oil without any pressure?
with car off
b20beast
« Reply #14 on: March 25, 2009, 10:26:41 PM »
i am not missing a bolt
bolt is tight
and how likely is it that the seals blew in 5 minutes of driving?
b20beast
« Reply #15 on: March 25, 2009, 10:34:43 PM »
hmmm
anyone with a good answer? :o
« Reply #16 on: March 25, 2009, 11:12:40 PM »
1/16 th is too big. Run a 1/32
« Reply #17 on: March 25, 2009, 11:21:50 PM »
with car off
dynamic seal
« Reply #18 on: March 25, 2009, 11:26:16 PM »
picures of drain angle
b20beast
« Reply #19 on: March 26, 2009, 08:22:39 AM »
with car off
dynamic seal
thanks
but it leaks only on the hot side
birdley42008
« Reply #20 on: March 26, 2009, 09:31:51 AM »
poorly clocked? If it smokes its the seals. What kind of oil are you using, also you need a restrictor unless you have a MASSIVE turbo to feed. Does your turbo sit very low? Pictures would help.
« Reply #21 on: March 26, 2009, 10:32:32 AM »
« Reply #22 on: March 26, 2009, 10:36:28 AM »
b20beast
« Reply #23 on: March 26, 2009, 11:02:22 AM »
oil is 10w30 castrol
but im not sure its a restrictor because when the engine is off there is no oil pressure
so why would it drop out the middle part of the turbing housing?
b20beast
« Reply #24 on: March 26, 2009, 12:09:57 PM »
« Reply #25 on: March 26, 2009, 03:32:17 PM »
Its fuckked, dont run it anymore unless you want it to eat the turbine, and compressor wheels up  Pull it off and have it rebuilt.
boosted 00 black si
« Reply #26 on: March 26, 2009, 11:39:30 PM »
UR SEALS are BLOWN get it rebuilt  :somb:
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
b20beast
« Reply #27 on: March 26, 2009, 11:40:26 PM »
new bearings and seals!!
snarf
« Reply #28 on: March 27, 2009, 01:42:02 AM »
I agree with this.  Same thing hapened to me my turbo was leaking out of the hot side but had no shaft play, 500 miles later it has all kinds of play.  the oil is leaking out of your turbine when its spinning but only pores out of the center section wen it stops moving.  Get it!
theres no seals on the hot side just the shaft piston ring.
It looks like this
b20beast
« Reply #29 on: March 27, 2009, 07:55:13 AM »
It looks like this
thanks bro
i replaced that as well...
what did you do to fix yours?
