Pages: 1 2 [3]   Go Down
Author Topic: Engine Oil  (Read 53028 times)
realAgentMurdoc
Re: Engine Oil
« Reply #60 on: March 27, 2009, 01:51:07 PM »
In the benz nothing but Mobil 1.... gonna be running Torco in the Honda now though... might convert the benz over too
helps that I get it at the sicC hook up price  O0
G2 Racer
Re: Engine Oil
« Reply #61 on: March 27, 2009, 02:15:07 PM »
Amsoil 5w30, for what reason I don't know.
Re: Engine Oil
« Reply #62 on: March 27, 2009, 02:19:32 PM »
i put more miles on my turbo g2 then any hmt member that I am aware of in 2 years and i ran whatever was 10$ that week at walmart, usually pennzoil or something else like that.
I ran full synth mobil 1 in my bmw and it needs new pistons, i blame the oil.
So my scientific FIRST HAND analysis of oils is 2$/qt oil = 100k of turbo boost, 5$/qt synth = blow up your engine at 30psi. I will ask bob the oil guy to add this information to his site, and delete all irrelevant "lab faggot" testing.
Re: Engine Oil
« Reply #63 on: March 27, 2009, 02:22:21 PM »
Ziiiiiiiiiiiiiiiiiiiiiiiing  ;D
1Fast68
Re: Engine Oil
« Reply #64 on: March 27, 2009, 06:43:27 PM »
Brad Penn 20W50
Re: Engine Oil
« Reply #65 on: March 27, 2009, 09:48:27 PM »
been running quaker state 5w20 in the wrx, it warms up faster than synthetic does (adsorbs heat better i suppose) and my motor runs quieter over synthetic.  oil filter at oil change revealed LESS metal vs the previous synthetic filter change, too. 2.37/qt at the local store i get it from too :)  changed at 4500-5000mi intervals.  better mpg than synthetic
Heat = friction
royal purple is also good for finding leaks in a motor. if you have oil coming from somewhere but cant figure it out, run royal purple and it will start leaking 10x worse. i dont know why it does it, but it does.
All synthetic oils tend to leak/seep more, the molcules are smaller and therfore can fit through smaller holes, not to mention the solids that conventional oil carries that they don't filter out.
Re: Engine Oil
« Reply #66 on: March 27, 2009, 10:35:19 PM »
Yup. The euro stuff is not the same as the US manufactured stuff (due for one to the USA EPA standards I briefly outlined earlier)...
You get a cookie. For NOT being dumb... (No sarchasm at all... SRSLY)
Sarcasm or not, im taking the fucking cookie.
If I dont like the European knock off shit ill just go back to the diesel oil.
Re: Engine Oil
« Reply #67 on: March 27, 2009, 10:49:43 PM »
and the cookie yummy :yes:
Ive tried so many different oils, none seem to really feel different, or come out any different compared to others when changed.
However, I have noticed mobil 1 synthetic burns faster in my z6, so I no longer use it.
Re: Engine Oil
« Reply #68 on: March 27, 2009, 11:07:10 PM »
Diesel oil has reduced the ZDDP
http://www.zddplus.com/
Re: Engine Oil
« Reply #69 on: March 27, 2009, 11:12:08 PM »
BDV FTW. That article had me return 2 cases of Mobil 1. Im going to run Valvoline Durablend on the daily drivers, and RP on the Turbo civic.
Re: Engine Oil
« Reply #70 on: March 27, 2009, 11:52:04 PM »
No seriously I wasnt being an asshole... You Be right the EU manufactured shit is different. The SYNTH packages are different and in general more robust.
I tied the Mobile 1 without doing alot of research, just jumped on the M1 bandwagon. Glad I jujmped off
« Last Edit: March 27, 2009, 11:59:28 PM by bigdaddyvtec »
Re: Engine Oil
« Reply #71 on: March 27, 2009, 11:59:11 PM »
No one mentioned lucas thats all we run in the nova. Never had a problem
Re: Engine Oil
« Reply #72 on: March 28, 2009, 12:06:01 AM »
Heat = friction
actually friction = heat :-*
Re: Engine Oil
« Reply #73 on: March 28, 2009, 02:29:51 PM »
Heat = friction
Same difference, you got the message
i like running lucas in slopped out engines and as assembly lube.  works good, high oil pressure, quiet motors, etc.
Sometimes I don't use the stuff unless I'm trying to limp some shit a few more miles.
catsman50
  • perpetual noob
  • im a terrorist
Re: Engine Oil
« Reply #74 on: March 28, 2009, 02:45:08 PM »
cheapest shit I can find. I'm jewish :)
FUCK VOLKSWAGEN'#039#039S
Pages: 1 2 [3]   Go Up
