Author Topic: FUCK YOU HAYNES  (Read 13425 times)
FUCK YOU HAYNES
« on: February 24, 2010, 09:38:37 PM »
I know this is basically common knowledge, but as a reminder: don't use the fucking torque specs from Haynes manuals.
The transmission-to-engine bolt torque should supposedly be 85ft-lbs according to them for an Integra.  I thought it sounded a bit too high but said fuck it and went for it anyway.  Stripped one of the bolt holes out.  They said 65ft-lbs for Civic/CRV so I negotiated and torqued them all to 70ft-lbs.
Looked at the FAQ on another Honda forum and it listed 45ft-lbs!  Must undo tomorrow.
I should have known better since the first time I did a car repair and the dizzy diagram had the dizzy-to-cylinder numbers off...
Also if anyone remembers a long, long time ago when my CRX wouldn't go into gear once the engine was running after the night before where it POPPED trying to put it in reverse, then drove fine...tore it apart today and the metal around the springs on the pressure plate had shattered in a few places.
Re: FUCK YOU HAYNES
« Reply #1 on: February 24, 2010, 09:45:33 PM »
who the hell torques bell housing bolts???
with your crx, maybe the imput shaft wasnt fuly lined up when you tightened up the bell housing bolts
Re: FUCK YOU HAYNES
« Reply #2 on: February 24, 2010, 09:50:18 PM »
Ehhhhh?  I typically check the torque specs so I don't overtorque :P  Snapped too many bolts.
The fucked threads and fucked pressure plate had nothing to do with the CRX.  Pressure plate was on the stock engine and ate itself 7 months go.  Bell housing is on the new engine, and I didn't torque it until the housing was mated with the block so the input shaft is fine.  It fucked up because I listened to haynes and he's a fucking liar.
Re: FUCK YOU HAYNES
« Reply #3 on: February 24, 2010, 09:53:53 PM »
just keep tightening until you feel the threads slip, then back off 1 quarter turn  :mexi:
Re: FUCK YOU HAYNES
« Reply #4 on: February 24, 2010, 10:09:47 PM »
only thing I have ever torqued were headstuds, and I always end up cranking them down more after releasing some excess pressure through the hg in a few miles anyway
Re: FUCK YOU HAYNES
« Reply #5 on: February 24, 2010, 10:12:58 PM »
I only torque drivetrain related shit, as I'm usually too lazy and just turn the wrench til it's nice and toight.
The other bolts should be enough for the transmission to stay on without that one.  I don't know why I even bothered, it's not like there's much force that would cause them to come loose.
Re: FUCK YOU HAYNES
« Reply #6 on: February 24, 2010, 10:14:00 PM »
I got pretty much ever manual for a honda I have ever needed @ hondahookup.com
Re: FUCK YOU HAYNES
« Reply #7 on: February 24, 2010, 10:14:31 PM »
i shouldve done a few hour stopover in ATL and done science with you in the parking lot, no homo
Re: FUCK YOU HAYNES
« Reply #8 on: February 24, 2010, 11:02:45 PM »
Go until the impact is done or my older days get as many bolts that arent hard to get too.
TTC
Re: FUCK YOU HAYNES
« Reply #9 on: February 24, 2010, 11:48:00 PM »
Some people just don' t have that "feel" of when to back off.
Kain
Re: FUCK YOU HAYNES
« Reply #10 on: February 24, 2010, 11:48:16 PM »
who is in atl?
Re: FUCK YOU HAYNES
« Reply #11 on: February 25, 2010, 12:02:25 AM »
Honda Factory service manual = technical drawings
haynes, chiltons = comic book
Re: FUCK YOU HAYNES
« Reply #12 on: February 25, 2010, 12:10:22 AM »
I can "feel" it just fine when it's not a long, sturdy bolt in a long threaded hole trying to torque to 85lbs with a 16-20" torque wrench...  Tighter...tighter...tighter...snap...there was no point where it was starting to "give" :P
Indeed.  Will be sure to use specs from service manuals instead of trusting Haynes ever again, this was just the breaking point :P
Re: FUCK YOU HAYNES
« Reply #13 on: February 25, 2010, 01:12:58 AM »
43 ft/lbs is the correct value.
Re: FUCK YOU HAYNES
« Reply #14 on: February 25, 2010, 01:37:53 AM »
The only thing that I torque is
Pressure plate
Flywheel
Internal motor things
arsenio
Re: FUCK YOU HAYNES
« Reply #15 on: February 25, 2010, 01:50:07 AM »
Better to be* too tight than to loose.
« Last Edit: February 25, 2010, 02:15:23 AM by arsenio »
Will you miss me?
Re: FUCK YOU HAYNES
« Reply #16 on: February 25, 2010, 02:11:43 AM »
torque specs are negotiable in everything but wheels and head bolts  8)
Re: FUCK YOU HAYNES
« Reply #17 on: February 25, 2010, 03:38:18 AM »
exactly, Fuck torquing anything, i torque to scott spec, hit it once or twice with the impact gun and its good.  Only torque down the head with a torque wrench and the rod bolts and main's.  Everything else go by feel.
Re: FUCK YOU HAYNES
« Reply #18 on: February 25, 2010, 03:38:47 AM »
Pressure plate
Flywheel
fixed
TTC
Re: FUCK YOU HAYNES
« Reply #19 on: February 25, 2010, 12:04:46 PM »
Then why you snappin shit, then again 85lbs is alot of torque.
Re: FUCK YOU HAYNES
« Reply #20 on: February 25, 2010, 12:07:18 PM »
Pressure plate
Flywheel
fixed
x2 and even then, it's pretty much rod bolts, mains and headstuds.
Everything else get tightened by feel. I do like to use 1/4 stuff when working with smaller nuts/bolts though, just as a precaution.
TTC
Re: FUCK YOU HAYNES
« Reply #21 on: February 25, 2010, 09:11:20 PM »
I use scottspec on my dads delivery cars.
Re: FUCK YOU HAYNES
« Reply #22 on: February 25, 2010, 09:15:45 PM »
my favorite haynes manual line:
installation is reverse of removal
Ravage70
Re: FUCK YOU HAYNES
« Reply #23 on: February 25, 2010, 09:20:47 PM »
I <3 my Hanes.
Re: FUCK YOU HAYNES
« Reply #24 on: February 25, 2010, 11:09:21 PM »
Pressure plate
Flywheel
fixed
I do torque the lug nuts, but I leave my torque wrench on 85 ft/lbs for this.
darkelvis
  • RHMT King of Rice
Re: FUCK YOU HAYNES
« Reply #25 on: February 25, 2010, 11:22:35 PM »
85...fuck that noise...cars/suv's/small pickups 110....big pickups....140....large equipment (huge cube vans,semis..etc..) 1/2" impact torque.....this is all assuming I don't have a torque stick that fits the lugs.  If I do then it's torque it to whatever torque stick fits on it.
Re: FUCK YOU HAYNES
« Reply #26 on: February 26, 2010, 12:19:41 AM »
110 on a Honda = replacing broken studs
Re: FUCK YOU HAYNES
« Reply #27 on: February 26, 2010, 12:36:44 AM »
might take a time or two for the stretched stud to break, but yea, that is a bit high
darkelvis
  • RHMT King of Rice
Re: FUCK YOU HAYNES
« Reply #28 on: February 26, 2010, 12:47:35 AM »
110 on a honda=something i do approx 5-6 times a week at work.  Only studs I've ever broken were when I was takin lugs off of cars where fucktards crossed them going on or they have been rusted on for the last 10 years.
