Author Topic: Is this homemade enough?  (Read 16099 times)
skaterdudz02
« on: March 06, 2010, 09:11:10 PM »
I couldn't see spending 25 dollars for a damn return feed on my turbo so I got creative. Heater hose nipple cost three dollars.
P.S. I'm open for criticism.
BTW, it doesn't leak.
clwtwizted
  • Fuck You!!!
Re: Is this homemade enough?
« Reply #1 on: March 06, 2010, 09:25:46 PM »
Why hasnt this been done before? I think its a great  O0 idea.
« Reply #2 on: March 06, 2010, 09:26:02 PM »
Great job
El Beefo
  • tongue punch my fart box
« Reply #3 on: March 06, 2010, 09:35:43 PM »
skaterdudz02
« Reply #4 on: March 06, 2010, 09:43:57 PM »
I figured this was an "easy way to save" 25 dollars. Also, I used the same fitting on the oil pan side and put 5/8 hose to butt them together. It turned out well.
Eggylshatch
  • Pen15 Club President
« Reply #5 on: March 06, 2010, 09:51:55 PM »
look at you all high tech n shit with that real welding.  true  O0 use jb weld on their drain fittings
El Beefo
« Reply #6 on: March 06, 2010, 10:05:38 PM »
« Reply #7 on: March 06, 2010, 10:13:39 PM »
The opening on that feed may be a little large and give you more flow than you'll need, but it could only mean another 3 cent fix I'm sure.
« Reply #8 on: March 07, 2010, 01:07:56 AM »
is there a such thing as a return line being too big?
No, but then, that's not what I said either.  ???
« Reply #9 on: March 07, 2010, 01:11:09 AM »
lol
was wondering why it wasn't jb welded either.  the only concern I'd have, and it probably wouldn't ever happen, is damaging the bearing in the chra if the arc jumped across it.  unlikely for sure, but i've talked to industral gear box manufacturers who warned of the same thing
« Reply #10 on: March 07, 2010, 01:15:24 AM »
Eh, it isn't a baller bearing CHRA, and if the ground clamp is close to the weld area with little resistance, then i doubt the chances of arcing across the bearings is much to worry about.
Great idea!
« Reply #11 on: March 07, 2010, 01:34:50 AM »
he said it was a return line
Practically, yes. Technically?
No. Technically, he isn't making it all that clear, so I can award you no points, or hotpocket proofs of purchase.
« Reply #12 on: March 07, 2010, 01:50:44 AM »
Your right. You should start an oil line business.
« Reply #13 on: March 07, 2010, 02:15:15 AM »
you actually spent money.
the baller way to do it is like me, weld on scrap pipe that was laying around
« Reply #14 on: March 07, 2010, 03:20:27 AM »
not enough money in it for me. plus i don't want to take money away from you.
If I was pulling Johnnys money too, I'd agree.
d16forlife
« Reply #15 on: March 08, 2010, 12:51:05 AM »
Why does every one always talk about Jhonnys money? Is he balling now? Did he buy clean clothes? ???
Eggylshatch
« Reply #16 on: March 08, 2010, 12:55:40 AM »
It's referring to Johnny's constant whining about the government and everyone on some kind of social welfare/assistance program stealing all his money.  And no, I don't think he's bought any clean clothing.
« Reply #17 on: March 08, 2010, 12:56:04 AM »
you aren't in the loop you dirty beaner, go take a shower and get a new shirt you wetback
« Reply #18 on: March 08, 2010, 12:58:16 AM »
Fuck welding, this is RHMT we use jb weld
« Reply #19 on: March 08, 2010, 12:58:40 AM »
i got a system.
white = good
yellow = good
brown = good
gray = good
light black = good
black = change underwear
« Reply #20 on: March 08, 2010, 01:26:56 AM »
not many people run their feed hose to the oil pan
Well I did, and the return is under the manifold. But I screwed it up and it always flows backwards. :'(
« Reply #21 on: March 08, 2010, 01:47:47 AM »
nope, but he's almost got enough saved for another family towel
Adam Lofton
« Reply #22 on: March 08, 2010, 03:42:59 AM »
Since when did turbos "return" oil? Drain back is hard enough, let alone pushing it back.
stealthiskey
« Reply #23 on: March 08, 2010, 10:56:56 AM »
gravity sucka. it does things.
Adam Lofton
« Reply #24 on: March 08, 2010, 12:25:29 PM »
« Reply #25 on: March 09, 2010, 07:53:42 PM »
lol
2slow
« Reply #26 on: March 10, 2010, 10:59:30 AM »
the turbo isnt returning it gravity is. the oil is returning from the turbo back into engine circulation so i think its ok to call it a return line.
Adam Lofton
« Reply #27 on: March 10, 2010, 07:23:42 PM »
i agree that it's ok to call it a return line. after all, it is returning oil to the oil pan
Drain back, and hot pockets.
AbaZ
  • Out of retirement
    • R-HMT
« Reply #28 on: March 10, 2010, 11:01:16 PM »
I love it, in fact alot of those retarded 25 dollar fittings (even though I never paid for them, thanks craig) leak. I don't know what the deal is. Sometimes they would chase the threads, sometimes its the flange gasket.
thats so hot, its almost front page material.
« Reply #29 on: March 11, 2010, 01:42:58 AM »
I guess I didn't notice at first, but this is a "test mule", right?
Cause nobody in their right mind here would rock a 50trim t3 anymore. HX40 or go home.
