Pages: [1] 2 3   Go Down
Author Topic: Unccle Tom sent me giftisisses in teh mail.  (Read 47771 times)
« on: May 29, 2010, 11:18:59 AM »
Flat Black, ScorpioMK and myself took Sewell up on a deal he proposed on som FIC 1100s while he was in the PNW. Im waiting on a 4 BAR from JD and a couple TB gaskets and the slut will be back onthe dyno in a week or so. Once I get ahold of leednog.
The numbers are awesome...  at 55 PSI looking at 1250 CC...  Up around 35 pounds of boost it should be Palenty to get where I want to go.
 I saw them idling on Alexs pile of sht at 15:1-16:1 with no lean popping and heard his part throttle was int the 16s as well... That is a NO GO on the Precisionn 1000s.
Now I will have PLENTY of fuel to max the T04ZR   :noel:  Not sure that will happen, but the plan is to get out of the 6's
 O0
« Last Edit: May 29, 2010, 11:22:02 AM by bigdaddyvtec »
hotrex
Re: Unccle Tom ent me giftisisses in teh mail.
« Reply #1 on: May 29, 2010, 11:21:42 AM »
your 3rd degree fat and stupid
Re: Unccle Tom sent me giftisisses in teh mail.
« Reply #2 on: May 29, 2010, 11:22:59 AM »
Shut the fuck up Herpgobbler, you sport-rape 10 year old boys.  :-*
By the way homosex...
Its fucking you're not your.
Context.
I know youre a supergenius but fuck  (not butt fuck)... you Butt fucker...
« Last Edit: May 29, 2010, 11:24:32 AM by bigdaddyvtec »
« Reply #3 on: May 29, 2010, 11:38:50 AM »
Isn't this like rice boys tackling 200mph downforce with wings before they even mod their engine? If you were going through trannies before, they'll snap like twigs when you even try maxing those out.
« Reply #4 on: May 29, 2010, 11:59:41 AM »
You missed the entire point that is clearly outlined in the post. Why is it that I'm not suprised... being able to make more power is a by-product of the decision to run them based on the point you missed.
Evidently you also have failed on speaking intelligently on the transmission situation in the car. At least you're consistant.
My car has been making power foryears. You act like I'm new to this..... seems as though you may be the one that has less than an educated idea of what's going on here.
Well played. And par for the course.
« Reply #5 on: May 29, 2010, 01:02:17 PM »
Hum BDV it seems like there is a bit of JD in your rips lately :noel:
I guess spending time with the nog rub off on you.
« Reply #6 on: May 29, 2010, 01:14:30 PM »
Zing!
Every time he went to bed and did his beached whale impression, I was rubbing off on him alright.
« Reply #7 on: May 29, 2010, 01:17:49 PM »
I'd like to know why BDV is looking for rt4wd crv drivtrain shit on H-T  :evil:
« Reply #8 on: May 29, 2010, 02:13:26 PM »
Them there squirters be purdy.....
« Reply #9 on: May 29, 2010, 07:36:33 PM »
I never use paper gasket at the throttle body. Thin layer of rtv silcone does the job never had an issue in the 12 years I have been using it.
Pm me if you want paper gaskets for the spacer. One will need to be trimmed to fit the larger side of the spacer since it is tapered 70mm inlet down to 68mm at the plenum to help with reversion. The gaskets are made for the 68mm plate throttle bodies.
The 2mm larger inlet at the spacer vs the throttle body plate size is the same design Honda/Acura use on all their manifolds just the lack of iacv spacing makes porting most manifolds past 68mm impossible. Hence why I came up with the spacer.
So for example an oem h22 throttle body plate is 60mm. The inlet on the intake manifold is 62mm. Just port matching to the throttle plate is not optimal for flow why the spacer made 4 whp over a basic port match on a stock h22a with a 74-68mm tapered throttle body all motor.
« Reply #10 on: May 29, 2010, 08:17:09 PM »
Ya ifd like to have the gaskets in there jus cuz...
Not a big fan of the rtv on the TB
« Reply #11 on: May 30, 2010, 12:16:45 AM »
Chris how much for the gasket? I to would like one on both sides of the spacer.
« Reply #12 on: May 30, 2010, 12:19:13 AM »
You saw that huh???  I need a under the radar SN for HT.  LOL
« Reply #13 on: May 30, 2010, 12:57:00 AM »
will not work for d series since the largest you can make the intake plenum is 65mm on a d16z6 manifold. The paper gaskets I have are 68mm aka wont work. I dont sell enough spacers I sell maybe 2 a month so yeah making gaskets for them is not every going to happen.
You can buy a sheet of gasket material and cut one out yourself or just use rtv.
« Reply #14 on: May 30, 2010, 01:04:01 AM »
I dont care what your SN would be, anyone can tell a bdvt post from 100 miles away, lol.
« Reply #15 on: May 30, 2010, 01:17:40 AM »
HATE HATE HATE HATE HATE HATE HATE HATE HATE HATE HATE HATE is more than just a sig line.  You radiate malice on the internet much like you radiate large and in charge IRL.
« Reply #16 on: May 30, 2010, 02:25:55 PM »
You'd still stick out like a sore thumb rotting whale carcase.
I understand your need for them. You want 50mpg through lean burn mode...on something that uses a gallon per mile at full tilt. Who gives a flying fuck if you have to idle in the low 13's. Your turbo is fucking huge and you don't have much go until at least 3k, so that eliminates any argument for better low-end as well.
« Reply #17 on: May 30, 2010, 02:52:06 PM »
He can't up the fuel pressure - I've been that path with those cores, you completely retune every part of the fuel map and gain 0 whp before you run out of injector.  1600s idle and part throttle like shit.  Who cares if it's a racecar, right?  Spiker's got a streetcar he picks his girlfriend up in so they can have teenage-like backseat sex, or a reasonable facsimile thereof, and it's got to have streetcar manners.  Yes, I have planted my asscheeks somewhere Spiker's gotten laid.  That came out horribly wrong.
The new Bosch cores are the only direction he can go, short of some overly complicated staged setup that would cost more after plumbing and inability to sell the existing injectors is accounted for.
« Reply #18 on: May 30, 2010, 07:35:25 PM »
got a friend of mine i am trying to convince to move to ID injectors.  He wants to use precision 1000's and i about slapped him.  He doesnt want to spend 500 on injectors, but im trying to get him to understand the concept of why i dont want him running those injectors and why he should move to the ID's.  Some people just dont listen.  The smaller precision injectors are pretty nice and i have yet to have a problem with those.  880+ can suck a fucking nutsack tho.
« Reply #19 on: May 30, 2010, 08:16:26 PM »
Like I said he completely missed the point. I dont even have to be a dick in pointing it out...  he did that himself. LOL..
The car behaves OK as it is, actually from what Ive gathered for what I have going on (especially at the base im at) my car behaves very nicely on the street and around town. Its not a track car. Street drivability is more important than WOT. I have had to compromise up till now. Not that idling at 12:8 iS that BIG OF A DEAL, BUT FOR THE DEAL I GOT ONTHE bOSCHES i cant SAY NO. It helps accomplish 3 or more goals for the car.
I cant wait to see the improvements from these... At the same base, I gain 250cc plus... At the BASE... Fair to say ill have plenty to turn the boost up to farther than I plan too, AND get better drivability... I dont give a shit how much it burns full tilt (Closer to 1.2 gallons per mile if my math is correct), as thats not going to change... Its the part throttle behavior and manerisms Im looking forward to. I know how much of a shitpile Alexs teg was before the Bosches... Mine was MUCH better than his, and his is now ROCK SOLID STABLE WITHOUT an IACV...
The 1000s as JD mentioned have reached the point of limiting returns, in additio9n they CANT take an increased base pressure  (as in you turn it up and they idle leaner) as the very design of the injector phrohibits any more help... You turn it up, part throttle gets fucked and you make no more up top as they are just DONE.
Not to mention after selling my 1000s Ill only have 60 bux into these (Thx Tom)  :yes:
 I may have to wait a bit lionger to do the switch, as Ive been in Cali on vacation for over a week, and when I get home tomorrow, it will be two weeks sincew ive worked so I cant affor to miss time to get leed down for a couple weeks... But I have everything I need. Probably take the cams ourt and check the headstuds and do the valves Jus cuz before I hit the dyno.... But its comin. SOon.
I have an option to get some S2 Stage 2 turbo cams DIIIIIRt cheap if I want them, but I dont want the shitty part throttle that comes with them... Think Ill pass and try for the 7 on the stock cams. After talking to Tom in regards top the H heads flow (Andf the fact there are PLENTY of clowns making over 8 on stock port stock JDM cam heads) I dont think it impossible to get 7 with just 5-7 more pounds of boost :mexi:
I already have fuel lines, a 255HP feeding a 044 and a billet filter feeding the rail. The 044s are good to more than enough pressure than Im going to need even running a 55 pound base and 35 ish PSI boost.
Ittle idle at 15:1 not lean pop and flow close to 1450 CC on the top eaving all kinds of headroom injectorwise.
We wont even tyouch the transmission issues (or lack thereof thesedays) as Probably 90 percent of those here have no idea of whats transpired. The tranny hasnt been out of the car since last Sept. It will come out for a looksee soon, but nothing bad is going on in it at all.... Yet.  :P
Capiche?
And yes, I have fucked Brook in the car where JD, Shadow and Russ all sat. LOL...
« Last Edit: May 30, 2010, 08:24:17 PM by bigdaddyvtec »
BangBusMaster
« Reply #20 on: May 31, 2010, 05:29:20 AM »
Dont change cams. Your boat anchor breathes very well for what it is.
« Reply #21 on: May 31, 2010, 12:35:22 PM »
You need to talk to people you know who have hookups on injectorssss....
« Reply #22 on: May 31, 2010, 12:49:01 PM »
Word. See what gets maxxed next? Not the fuel or the MAP sensor... LOL    :yes: Ill hit you up when I get home niggle. Im getting on a train to go back to SF and will be back in the rainy gayness tomorrow.
Ill hit ya up when I gets in....
Snoochies oif the boochies
« Reply #23 on: May 31, 2010, 01:56:21 PM »
Hey can I get a hook up ;)
« Reply #24 on: May 31, 2010, 02:14:11 PM »
lol I was just going to post something similar  :yes:
trevor72
  • trevwhore
« Reply #25 on: May 31, 2010, 03:07:58 PM »
nice pieces.
I love my ID1000's they work well, and tom shipped the injectors fast (even to Canada) and is good shit to deal with.
Looking forward to your results.
« Reply #26 on: May 31, 2010, 03:12:41 PM »
nice pieces.
Thanks for the good word :)
You find another turbo yet??
« Reply #27 on: May 31, 2010, 03:49:30 PM »
nice pieces.
Lucky for Trevor I collect those things...
« Reply #28 on: May 31, 2010, 04:22:35 PM »
Sweet, his car felt pretty damn good on 24lbs, on pump.
« Reply #29 on: May 31, 2010, 06:14:10 PM »
I am still having a hard time wrapping my head around 24lbs on pump.
Pages: [1] 2 3   Go Up
