Author Topic: my junk as set up (nsfw)  (Read 37785 times)
mycarslow
« on: April 06, 2009, 11:30:01 PM »
i just got some junk ass set up going on ..
car is a 97 civic hatch
goals get the shit running sometime but really about 350 hp
motor d16
ems chipped p27 obd1
h beams
 blowen up so looking for new pistons
t4 turbo
window weld mounts turbo rhmt shit right there
said car
car with the said jackass (me)
ar 60 cold ar 81 hot side
my rods and shit
fucked piston after  a boost spike
i put this shit togather outside in the snow and ice
« Last Edit: April 20, 2009, 01:03:23 AM by mycarslow »
mycarslow
Re: my junk as set up
« Reply #1 on: April 06, 2009, 11:35:30 PM »
aslo can i use arp z6 head studs in a d16y block?
junk ebay mani on the small turbo i had that blow it up
« Last Edit: April 06, 2009, 11:57:47 PM by mycarslow »
snarf
« Reply #2 on: April 06, 2009, 11:43:41 PM »
cool car, I like the wheels.  Any pick of the engine bay?
« Reply #3 on: April 06, 2009, 11:47:11 PM »
Did you learn your skillz at UTI?
« Reply #4 on: April 06, 2009, 11:52:21 PM »
You can on all but the two outer intake bolts iirc.
There was a thread on that earlier today that I saw
Nice car.
mycarslow
« Reply #5 on: April 06, 2009, 11:54:07 PM »
that was a sin pic im at uti right now
 this is what i found on the arps
i found this out from another site
"The z6 kit comes with 140mm the y7/y8 with 120mm (actually slightly longer since its a stud not a bolt). "
so i THINK theyll work IF this is right
my block and head are both y7 i got the z6 hella cheap tho so im hoping they work
« Last Edit: April 07, 2009, 12:02:32 AM by mycarslow »
snarf
« Reply #6 on: April 07, 2009, 12:29:05 AM »
Thats the manny made to work with a dsm turdbo right?  Did you have a boost spike because of the
built in wastegate or something?
mycarslow
« Reply #7 on: April 07, 2009, 12:32:18 AM »
yeah .... the spike car from either a hole in the vac line and or the face that it came off the  lol fuck it live and learn
« Reply #8 on: April 07, 2009, 04:03:17 AM »
LISTEN TO ME
R U ready
LOOSE THAT FUCKING MANIFOLD NOW NIGGER
I LEARNED MY LESSONS WITH THAT
ONLY GOOD FOR 300whp and risking cracking
LOG/eville140/homedepot made log is better that that, ports are wayyyyy toooo small.
WITNESS THIS
DMC, DRAIL, BONE"crttaz" all was there to see this, every pull it got red, I was re welding cracks
« Last Edit: April 07, 2009, 04:06:25 AM by widebody93 »
mycarslow
« Reply #9 on: April 07, 2009, 08:24:12 AM »
i alread got rid of that lol my new turbo is t4 anyways lol
« Reply #10 on: April 07, 2009, 10:17:30 AM »
do work.  blown motors are no big setback
on a side note, i've got a set of 75.5mm vitaras and rings i might let go
mycarslow
« Reply #11 on: April 07, 2009, 02:22:44 PM »
how much ?
MantisX
« Reply #12 on: April 07, 2009, 02:31:59 PM »
Shortage of porn, but otherwise, nice setup.
TheMadScientist
  • I'm like Batman and Shit
« Reply #13 on: April 07, 2009, 04:04:59 PM »
+1
You better get this shit on hit ASAP
You better fix that PORN problem too.
« Reply #14 on: April 07, 2009, 04:16:56 PM »
z series studs with not work on a y series.  unless you want to use a crap load of washers
mycarslow
« Reply #15 on: April 07, 2009, 10:11:50 PM »
i need a turbo main still looks like it will have to be a one off mani being a t4 ......... im looking for pistons yet being that big of a turbo i want to
a higher CR to help spool that thing... but i might not have a prob. becuz the holset hc1 that dude ran is bigger around  1. something hot side??
he made with  a set upof  Eagle/Vitara Y7 279 whp 210 tq 11.200@124.5, 1.68 60 ft. they came with a z6 intake mani and i belive he told me 23 psi
« Last Edit: April 07, 2009, 10:28:19 PM by mycarslow »
Re: my junk as set up (nsfw)
« Reply #16 on: April 08, 2009, 11:51:53 AM »
Your right!  That is junk!
J/P  :P
papercuts
« Reply #17 on: April 08, 2009, 09:28:22 PM »
your shit is lame wat the fuck. so ur usin a z6 head on hte y7 block? sounds good there. yea higher compression would be ur friend bing u want a big turbo but at the same time u dont sound like u know wat the fuck ur talkin bout so ur probably better off with the vitara build so u dont blow ur shit up real fast. but hey u live u learn rite.
mycarslow
« Reply #18 on: April 08, 2009, 09:43:00 PM »
what mother fucker... i dont what im talking about?  i want higher cr to spool my turbo and im running that turbo to be able to make high hp.with some 780cc injectors... vitaras are in mind becuz i want to do something cheap and still fun this one will not blow im looking into tuners right now
turbo4life
« Reply #19 on: April 09, 2009, 04:18:28 PM »
your tuner should have set you up with boost cut paremiters!  its added with the extra feathers lc,cel shit light ect and is really good to have !  it looks like your shit went really lean..
End the fake food.
mycarslow
« Reply #20 on: April 09, 2009, 09:42:48 PM »
yeah it did but what do you do lol ... ill suck it up and re do my shit
« Reply #21 on: April 10, 2009, 02:59:20 PM »
I know "Bense" on H-T has a thread about the PROPER way to mix z6/a6 & y7/y8 heads & blocks, concerning head studs. I had a z6 head on a y7 block for a while, the ARP's needed were a "d16y" kit, along with one longer stud for the corner. I actually have the set if you'd want to buy it. Otherwise you just use the y7/y8 bolts and one z6 bolt. It may be two, but do a search for the writeup.
Spool rpm is NOT related to compression. The turbine accellerates based flow induced by a big pressure drop. To do that you feed MASS into the exhaust. Higher compression does NOT draw any more air into the cylinder, it just absorbs more efficiently (to simplify it). Ask Jeff Evans for his dyno graph on the B18 where they did nothing but swap out a stock 9:1 bottom end for a built 10:1 bottom end, both tuned back to back. The *ONLY* change was power created per PSI during boost. Off-boost power was about 2-3hp greater, which is small enough to blame on atmospheric conditions or even fresh oil.
« Reply #22 on: April 11, 2009, 03:19:39 PM »
my first time at the track i didnt even have my internal wastegate boost line hooked up and i didnt ruin any pistsons
internal gates are weak sauce.
you fucked up.
« Reply #23 on: April 11, 2009, 08:05:17 PM »
ust
Close.  :P Turbine is an enthalpy converter. Takes energy from the exhaust and turns it into work. h = U + PdV. U is a function of temperature and density, which is a function of the engine's thermal efficiency. if you could run 4000:1 compression and not detonate, you'd have a 97ish % thermally efficient engine. It would make tons of power N/A, but with less than 3% of the energy going out the exhaust, there would be little left to drive a turbine to drive a compressor.
But "common wizzdom" says lower comp hurts spool.  :?:
mycarslow
« Reply #24 on: April 11, 2009, 08:46:23 PM »
i found some 9:1 wisecos that are 75.5mm
papercuts
« Reply #25 on: April 15, 2009, 11:53:48 AM »
Tell me where they are and if they are cheap I will buy them. U need to get vitaras and a god tuner that won't let u have an adj. Boost controlled cuz u will just blow it up again.
And don't wat mother fucker me u oil pinine bitch. U and ur car are a waste of valueble oxygen. Faggot.
« Reply #26 on: April 15, 2009, 11:55:59 AM »
Learn how to QUOTE
mycarslow
« Reply #27 on: April 15, 2009, 12:53:56 PM »
papercut .. shut your nigger loving ass mouth  tell me what to buy mother fucker go hang yourself from  highest  point in the shit hole town you live in  O0
papercuts
« Reply #28 on: April 15, 2009, 02:44:29 PM »
Fukin whiner with ur shit ass build. Go back to sukin dick on gay porn.
mycarslow
Re: my junk ass set up
« Reply #29 on: April 15, 2009, 09:30:27 PM »
my shit set up? yeah you fucking pos ... i know my shits junk hiints the name dumb fuck now kill your self
