Author Topic: 92 galant build ***NWS*** new motor  (Read 24340 times)
fastspec2
« on: July 17, 2010, 10:39:07 PM »
Here is my marginaly dsm queer galant. I wanted 4 doors, awd, turbo and I didn't have the stomach for a lgacy sport sedan. I had posted my samurai turbo and my el-cheepo sentra build before, but then the site changed, and I kind of fell out of the hobby for a while. Hopefully this is goin to be a good return for me.
My goal is around 500 with a good dirt road suspension.
When I picked it up it barely made boost, leaked anything it wasn't supposed to and generaly made me feel like I fucked up. But the last 3 day has really turned it around. I cleaned it up, stuck on a not totally beet to shit 14b, and hacked a maf translater into it.
So fgar so good
Hopefully there will be a ton more to come.
http://www.glowfoto.com/static_image/17-192629L/9015/jpg/07/2010/img6/glowfoto
http://www.glowfoto.com/static_image/17-190340L/7716/jpg/07/2010/img5/glowfoto
http://www.glowfoto.com/static_image/17-190413L/5318/jpg/07/2010/img5/glowfoto
http://www.glowfoto.com/static_image/17-190525L/8010/jpg/07/2010/img5/glowfoto
http://www.glowfoto.com/static_image/17-192939L/6271/jpg/07/2010/img6/glowfoto
http://www.glowfoto.com/static_image/17-190658L/3357/jpg/07/2010/img5/glowfoto
« Last Edit: August 29, 2010, 11:49:10 PM by fastspec2 »
Re: 92 galant build
« Reply #1 on: July 18, 2010, 12:33:15 PM »
Solid post!
Re: 92 galant build
« Reply #2 on: July 18, 2010, 12:36:13 PM »
fastspec2
Re: 92 galant build
« Reply #3 on: July 18, 2010, 12:39:29 PM »
I have got the car togethr well enough to drive it, but the brakes were horrible. I looked into new rotors and pads and for this car they were pretty steep. So I went to the u-pull and found a set of turbo 3000gt calipers. So 30 bucks later and I got some good calipers.
I got the new rebuild kits for the calipers, rebuilt them and painted them black.
I I got some new axi ceramic pads and brembo rotors, wich were only 26 bucks a peice.
I pulled the knuckles off and removed the factory heat sheilds and washed hem up so I can start building the adapter mount.
after getting the mount and the caliper sorted out I had just enough clearence behind the wheels to work.
I will post how they work when I get a few miles on them. The piston area on the new calipers is only about 10% bigger then factory, and the sweep area ofthe pads is about 25% larger.
So far it seems to work very well.
« Last Edit: July 18, 2010, 12:41:17 PM by fastspec2 »
SiFlyBy
Re: 92 galant build
« Reply #4 on: July 18, 2010, 02:24:30 PM »
I have always wanted a GVR4. Looks like you got a clean one. Nice project, I'm in for updates
Re: 92 galant build
« Reply #5 on: July 18, 2010, 05:13:53 PM »
You wont reach 500whp reliably (lol) on pump gas.  You'll need e85 for that.
Ditch that maf translator fail and look here http://forums.ds-map.net/
fastspec2
Re: 92 galant build
« Reply #6 on: July 18, 2010, 05:18:36 PM »
Thanx.
The translater was a freebe. I plan on rocking it till I get a real plan.
fastspec2
Re: 92 galant build
« Reply #7 on: July 20, 2010, 02:01:59 AM »
More stuff done,
I bought a barely used evo3 16g
a used obx manifold I cut open and ground all the birdshit out of and welded back together
an obx o2 houseing
I got 6' of 3"
3 u bends, 3" for the exhasut
A chicomm intercooler from my last aborted sentra fail,
and some 2.5 plumbing for the ic system.
I am also trying to buy a set of used comp "264" cams, 630cc injectors, and a good act plate. Will let you know how I do.
I also am looking at a minty fresh 4bolt rear end out of a 10K mile college training car.
it may take me a few days, but I'm hoping to get there sooner then later.
SiFlyBy
Re: 92 galant build
« Reply #8 on: July 20, 2010, 06:59:50 AM »
The force is strong with this one... :yes:
MAJORAHOLE
  • fuckin C-unt
Re: 92 galant build
« Reply #9 on: July 20, 2010, 08:34:31 AM »
in for the clean galant
Re: 92 galant build
« Reply #10 on: July 20, 2010, 08:06:45 PM »
I love those things but loathe the idea of working on one.
fastspec2
Re: 92 galant build
« Reply #11 on: July 20, 2010, 09:35:18 PM »
I don't mind it too much. Everything so far has been pretty easy. Its not as simple as alot of cars though, that is a fact.
fastspec2
Re: 92 galant build
« Reply #12 on: August 01, 2010, 11:01:23 PM »
So now that I'm back in town, the chump car race is over and I got a chance to work on my car, this is what i was able to make happen.
I broke the peice of shit 3 bolt rear axle last weak, so I yarded it all out. Then installed the 4 bolt I got out of the university test car. Its got a whopping 2300 miles on it. So it was a stupid score.
I also built a new front mount, and a new 3" exhaust. I also took a pic of my poor old pos band saw I traded some deisel parts for .
I also picked up a sureflow pump and a few other parts for a methenal setup I will be trying out. I havn't had much time to finish sorting it out. But I'm slowly geting there..
fastspec2
Re: 92 galant build
« Reply #13 on: August 01, 2010, 11:03:28 PM »
Oh, and I also pulled the suspension control arms out and boxed them all in. Also ditched the aws system and capped off all the lines/hoses when I went 4 bolt. I gotta say, after an alighnment I am happy with how it drives/turns and stops with the new parts.
Re: 92 galant build
« Reply #14 on: August 02, 2010, 12:31:01 AM »
Thankfully you're not still running the sidemount...that charge pipe must get HOT. Any plans to wrap it?
Other than that...looks pretty good. I'm just a bit surprised a 4dr doesn't have extra room between the rad & engine vs a DSM.
fastspec2
Re: 92 galant build
« Reply #15 on: August 02, 2010, 02:25:48 PM »
Its wrapped now. Used the black dei sruff.
There is a bit more room so I'm told then a dsm, but obviusly not lots.
Re: 92 galant build
« Reply #16 on: August 02, 2010, 04:10:07 PM »
This is a rhmt build 4 sho! I like!
Re: 92 galant build
« Reply #17 on: August 03, 2010, 10:32:26 AM »
Op no more small pic's!
Re: 92 galant build
« Reply #18 on: August 03, 2010, 10:46:05 AM »
jarebear667
Re: 92 galant build
« Reply #19 on: August 03, 2010, 11:11:37 AM »
i miss mine! i had a gsx with a turbo swap and 5 bolt hubs and 4 bolt lsd rear.  garret 60/63 it was a damn good car to me except transsss! ahah
looking greatr!
midwest HMT!
fastspec2
Re: 92 galant build ***NWS***
« Reply #20 on: August 06, 2010, 01:24:55 AM »
So some more shit done. I swapped in all the urathane bushings, and I started installeing my meth setup. I also took a pic or 2 of all te shit you take off when you dith the home rws. I also welded up the rear tow knuckles so they are not just flopping around.
I also installed a 91 talon shifter, its a tighter ratio.
I also scored a super jammy yakima ski rack that is OG mitsu. Complete with locks, keys and trim. Its pretty fuckin hot. I'll post pics when its installed.
Uploaded with ImageShack.us
« Last Edit: August 06, 2010, 01:37:32 AM by fastspec2 »
fastspec2
Re: 92 galant build ***NWS*** new motor
« Reply #21 on: August 29, 2010, 11:45:27 PM »
New motor time
100mm crank
wiesco's
manly rods
mls gasket
272's
new oil pump
switching over to air/oil cooler.
I also ported a evo3 exh manifold in prep fro the new turbo.
boosted 00 black si
« Reply #22 on: August 29, 2010, 11:51:31 PM »
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
shogun
« Reply #23 on: August 30, 2010, 10:13:06 AM »
sorry about the newb question, what engine originally has the 100mm crank and what rods can be used to make it work on a evo 3 block?
fastspec2
« Reply #24 on: August 30, 2010, 10:36:19 AM »
4g64 crank, 4g63 rods, custom pistons.
Avistar23
« Reply #25 on: August 30, 2010, 03:16:18 PM »
Evo 3 block is no different dimensionally than a 7 bolt, same combo he stated above.
F250 4x4 7.3 Diesel
International 4900 DT 466E
