Author Topic: someone made a RHMT piston ring filer?  (Read 15366 times)
walter
« on: August 06, 2010, 07:48:06 AM »
what title says, im looking for one piston ring grinder for good prices but shipiping to Europe are crazy (ive find even the shipping cost for pistons!) so i was wondering if someone make a realhomemade piston ring grinder for gap rings.
another question is what gap i should give to new piston rings to my new setup (vitara/eagle on Z6) i'd use it for drag and road racing.
any help?
Thanks
« Last Edit: August 06, 2010, 08:13:58 AM by walter »
Re: someone made a RHMT piston ring filer?
« Reply #1 on: August 06, 2010, 08:31:01 AM »
I just use a little file for like $1.00usd   :yes:
Its easy on most honda ring. Usually I only have to file a little just make sure you file in both directions and in small increments at a time.
« Reply #2 on: August 06, 2010, 10:40:22 AM »
any help?
Walter I have what you need but I have a problem, I asked you for some help with getting a vti tach or whole cluster. You told me to basically fuck off because you couldn't be bothered. well guess what princess.
« Reply #3 on: August 06, 2010, 10:43:06 AM »
any help?
One hand washes the other.... But not this time....   :evil:
« Reply #4 on: August 06, 2010, 10:43:45 AM »
any help?
Thanks
If my memory serve me right I have 0.018 top and 0.020 second. For my 0.5mm o/s vitaras.  ;D
« Reply #5 on: August 06, 2010, 12:45:19 PM »
any help?
I believe Chris M had the same problem with mr Euro to.
« Reply #6 on: August 06, 2010, 01:12:28 PM »
File in a vice and do it by hand
walter
« Reply #7 on: August 06, 2010, 08:04:08 PM »
any help?
what? where? i can try to find one for you but it's expensive.  i even sold vti tach of my crashed VTI to a american guy.
thanks for "help".
« Reply #8 on: August 07, 2010, 03:11:36 AM »
any help?
Thanks
Shit I have the same, motor is about to run in the next few days. Walter cheap file and do it by hand, not to much at a time!!!
« Reply #9 on: August 07, 2010, 03:19:00 AM »
any help?
Be the bigger man, and also help a RHMT brother. Kindness comes back to you man.
« Reply #10 on: August 09, 2010, 01:56:37 AM »
A dremel works just fine.
« Reply #11 on: August 09, 2010, 07:19:16 AM »
Just make sure to deburr all 4 edges, to file it straight, and don't chip the ring edges. You could take a larger c-channel or 2 angle iron chunks, drill holes in them, weld them to a plate, and insert a arbor adapter for a thin grinding disc. Since it's such a small job, it's really not worth it. Instead I spent $25 on a Summit piece of junk that got the job done cleanly & quickly. Looks like they aren't so cheap now, so I'd suggest using a small needle file.
