Author Topic: home made setup hit the dyno (updated for 2012)  (Read 81393 times)
« on: August 12, 2010, 04:01:32 PM »
i got my home made setup on the dyno.
turbo is a little baller, but it was worth saving for as it destroys the Holset i was using last year. (lol forgot to mention its a precision 6262 journal bearing ported S cover .81 AR hotside)
449whp on 20psi on 94 oct chevron pump gas.
once again, a bad ass colt cam came to the rescue.  bad ass z6 tri-flow race grind.
ghetto home made water to air intercooler setup
ghetto home made front mount mild steel mig'd manifold
block is on its 3rd rebuild, used ass old SRP pistons.  garage built w/o plasti gauge or any measurements.  haha
DIY port job, of course.
ran 11.2 on a 16psi street tune spinning hard.  cant wait for new slicks a cage and more seat time with this power level.  havent had it to the track yet on 449whp...
no idea how to imbed but heres the vid....
FUCK YOUR MOTHER
« Last Edit: January 05, 2012, 02:14:33 AM by danz »
Re: home made setup hit the dyno
« Reply #1 on: August 12, 2010, 04:12:53 PM »
Fucken SICK!!
mycarslow
« Reply #2 on: August 12, 2010, 05:23:20 PM »
Bad Ass  love the ek
« Reply #3 on: August 12, 2010, 05:33:41 PM »
is there a build thread?
« Reply #4 on: August 12, 2010, 05:56:33 PM »
thanks, the car is fucking bad ass i love it.  haha.  i never thought it would make this much power on pump.
yeah there is a build thread
http://www.d-series.org/forums/showcase/127388-danz-2010-1-4-mile-saga.html
« Reply #5 on: August 12, 2010, 06:14:11 PM »
« Reply #6 on: August 12, 2010, 06:57:03 PM »
Driving is  ;D
narfdanarf
« Reply #7 on: August 12, 2010, 09:53:09 PM »
I'm lovin it.
« Reply #8 on: August 12, 2010, 10:57:41 PM »
Looks like with some cam gear adjustments, you'll make more power and you'll be able to rev higher. Looks like it still wants to rev as it is anyway.
Also, you should talk to the SF guys and see if they'd lend you a Bisi cam to compare to yours. Looks like Colt Cams know what they're doing.
What kind of dyno was this? Never seen that sort of graph before.
« Reply #9 on: August 13, 2010, 12:02:07 AM »
How much do colt cams go for now a days?
« Reply #10 on: August 13, 2010, 12:34:56 AM »
love the 6262. i wish i had one on my shit box
« Reply #11 on: August 13, 2010, 04:18:04 AM »
A mostly stock D-head making power until 9?  Very nice.
« Reply #12 on: August 13, 2010, 06:18:33 AM »
Wash ur car u dirty canadian. Good to see you got it running :yes:
2slow
« Reply #13 on: August 13, 2010, 08:32:32 AM »
D112 iirc he had a bisi cam and it sucked
« Reply #14 on: August 13, 2010, 11:21:23 AM »
Driving is  ;D
thank you sir.  it helps having a tranny that shifts like butter even with the throttle wide open.  i wish it would hook too.  hehe.  now i just need a 74mm TB so i can shoot for 600whp on C16 and hit a 9.   :yes:
ya i think a little retard would do it good but i dont see a reason to.  its running at 0 deg right now and i think i could take it higher.  i just dont see the engine lasting long past 9000rpm.  even as it sits now, i spit an alternator belt at the track last time i ran it.  not really a good sign the dampener is working as well as i need it to.
i might head down to speedfactory over the winter, either bring my car or just bring the cam, so james can compare it to a 3.6.  colt has helped me out a lot so if i can help them sell more of these honda cams im all for it.
the dyno is a dynocom hub dyno, kinda like a dynapack but a little different.
http://www.dynocom.net/Catalog/detail.asp?iPro=113
i think for the same one i got Geoff wants $550.  wait till the canadian dollar falls and go for it.  lol
yep i had a bisi 1.2 cam on my A6 and it was very underwhelming.  but its hard to argue with the numbers the new more aggressive bisi cams are putting down.  like the 3.6 and 2.4.
yep stock valve size, just a 3 angle valve job, extensive DIY port work, and the bad ass cam.  with shimmed LMA's haha.
hah even the dudes at tech tell me to wash the car... had it for about 9 months and its yet to see a bath.
best part was running 11.5 @ 117mph on a stock z6 cam's low cam.  haha.  boy did the car feel like it was rippin when i actually got VTEC working.  sigh...
« Reply #15 on: August 13, 2010, 11:30:37 AM »
make another build thread up here sir.  fucking sick!
« Reply #16 on: August 13, 2010, 12:16:03 PM »
Whats the weight at, with you? Shits gona get heavy once you put that cage in.
« Reply #17 on: August 13, 2010, 12:35:37 PM »
shes about 2030 w/o a driver, and i could get it down to 2000lb easy.  id say at least another 100lb with the cage and im about 180.
« Reply #18 on: August 13, 2010, 12:45:31 PM »
Holy shit, that's a light EK.
« Reply #19 on: August 13, 2010, 12:47:45 PM »
Which is completely offset by chassis rigidity, improved traction, etc.  I <3 driving caged cars, even the ghettofab ones feel better.
narfdanarf
« Reply #20 on: August 13, 2010, 02:06:10 PM »
I heard the bigger cams were redesigned because they sucked donkey balls before and now they are much better due to the inputs from other people. ;)
« Reply #21 on: August 13, 2010, 04:34:52 PM »
Shimmed LMA? more info please.
What are the benefits? ;D
« Reply #22 on: August 13, 2010, 05:00:16 PM »
the cam is a regrind so i needed to shim the LMA's to keep them in contact with the base circle.  its just quieter.
mycarslow
« Reply #23 on: August 13, 2010, 05:44:08 PM »
What's the over all money dumped into the set up
« Reply #24 on: August 13, 2010, 06:27:08 PM »
no clue i used a lot of parts from my old 10 second setup last year, its hard to say.
lsd/zc gears - $1000
pistons and rods - $800
ectune/ostrich - $500
IM - $200
slicks and lensos - $500
Interior stuff - $250
water to air setup - $300ish
valve job/overbore - $500 or less
clutch - $300
waste gate - $200
BOV - $60
Injectors - $200
plus other random shit. consumables, tuning, etc.  im sure theres more but its hard to remember.  right theres around 4k.
still needs decent suspension, 24.5 MT's and a cage.
« Last Edit: August 15, 2010, 03:20:02 PM by danz »
mycarslow
« Reply #25 on: August 13, 2010, 06:38:37 PM »
I'm hoping to get about the same numbers as you . I'm using a y8  with cp pistons still looking for rods on the cheap would like my motor done under 1000 bucks
« Last Edit: August 14, 2010, 04:50:27 AM by mycarslow »
« Reply #26 on: August 14, 2010, 01:00:35 PM »
lol at the shiming. We use to put nickels under ford 2.3 lifters for a little extra lope!!
Gold DA9
  • OG LURKER
« Reply #27 on: August 15, 2010, 07:03:22 PM »
i thought of doing the Water to air setup. How do you like it. I think i was looking at kits from frozen boost or something.
Do you street drive and DD this car?
« Reply #28 on: August 16, 2010, 10:26:28 AM »
Air-water in a street car is an awesome way to get year round 130 deg F IATs.
« Reply #29 on: August 16, 2010, 11:44:17 AM »
i can and do drive the car on the street.  the kirkey seat kinda sucks for that, tho...
it has a reservoir that i fill with ice and water.  so, if i have ice, i can boost on the street.  but usually i just putt around while im on the street and dont pump anything through the core.  IMHO air to air is the way to go for a street car.
Pages: [1] 2 3 ... 5   Go Up
