Author Topic: Which injectors should I run?  (Read 19193 times)
senatorstains
« on: August 22, 2010, 08:55:51 PM »
I was wondering what injectors I should run for my build, it is a D16a6 and I will be running a t3/t4 turbo, and a 45 shot of nitrous, I am new to boost so let me know what I should get. I dont know if that is enough info so let me know if you need more.
Re: Which injectors should I run?
« Reply #1 on: August 22, 2010, 09:01:04 PM »
> 600
800
That Guy
  • Fast and danger
« Reply #2 on: August 22, 2010, 09:01:16 PM »
240cc should be ok until you get the turbo and nitrous on the car, after that, im not too sure  ???
« Reply #3 on: August 22, 2010, 09:11:05 PM »
450's nigga
senatorstains
« Reply #4 on: August 22, 2010, 09:13:07 PM »
I have been told 450s from a few people so 450s it is.
« Reply #5 on: August 22, 2010, 09:14:41 PM »
where is your n00b post and also i want to know the setup you have you :mexi:
« Reply #6 on: August 22, 2010, 09:52:48 PM »
senatorstains
« Reply #7 on: August 22, 2010, 10:20:02 PM »
I posted it earlier today on the general discussions forum.
http://www.realhomemadeturbo.com/forum/index.php?topic=15276.0
as for the exact setup of the motor i am not completely sure because my brother built it and he is Afghanistan right now so I cant ask him. He told me it has Suzuki Vitara rods, new pistons, he had the block sleeved, did some valve work and had the heads ported and polished. I plan on cracking the motor open tomorrow when I can get my tools home from work, but when I find out I will post it with pictures. Im sure there will be a lot of stuff that I dont know what the fuck it is so I will need some help figuring it out. I am completely new to honda engines and boost I am mostly a harley mechanic. I am not trying to fill this forum with worthless thread space or diarrhea from the mouth, I am here to learn and to contribute when I can.
and maybe a video or two of me burning some retarded gangbangers in their fast and the furious civics
« Last Edit: August 22, 2010, 10:44:30 PM by senatorstains »
« Reply #8 on: August 22, 2010, 10:47:36 PM »
Im sure its Suzuki Vitara pistons, not rods.
senatorstains
« Reply #9 on: August 22, 2010, 10:59:10 PM »
Oh ok my bad.
2slow
« Reply #10 on: August 23, 2010, 01:19:11 AM »
With a built motor look for evo injectors and a holeslut
theidealone
« Reply #11 on: August 23, 2010, 01:21:44 AM »
What fuel?
SOHCKLR657
« Reply #12 on: August 23, 2010, 03:21:37 AM »
Precision 580cc's, does just fine fo me O0
« Reply #13 on: August 23, 2010, 08:24:39 AM »
I'm using precision/delphi 75# (788cc @ 45psi) on my s/c'ed d16z6/y8.  ;D
« Reply #14 on: August 23, 2010, 08:51:56 AM »
~800 =
450 =
theidealone
« Reply #15 on: August 23, 2010, 11:40:53 AM »
Fuck that. Im rockin 1000s, and thinking of going to 1200s.
Avistar23
« Reply #16 on: August 23, 2010, 12:31:19 PM »
dsm 450's or evo inj should be fine, espeically if using a wet shot.
F250 4x4 7.3 Diesel
International 4900 DT 466E
« Reply #17 on: August 24, 2010, 03:29:19 AM »
fmu and block off return
« Reply #18 on: August 24, 2010, 11:15:37 AM »
Vice Grips.
But really 450's will not be enough, if you push that turbo even if it is a wet shot. 880's are cheap and give you some overhead. If you have the cash the FIC / ID 1000's are a nice way to go.
« Reply #19 on: August 24, 2010, 02:12:09 PM »
the t3/t4 should be good for 400whp or maybe a bit more.  the nitrous should add a little kick.  dry or wet?
dry, aka zex, i would worry more about the fuel pump, as its going to see some serious pressure at the rail.
788's were good for me up to 450whp.
« Reply #20 on: August 24, 2010, 02:53:19 PM »
Check your pms please  ;D
DasPoop
« Reply #21 on: August 25, 2010, 06:55:59 PM »
~800 =
450 =
this is why i love this forum real world comparisons
