Pages: 1 [2] 3   Go Down
Author Topic: Building a garage!  (Read 38257 times)
Re: Building a garage!
« Reply #30 on: November 16, 2011, 12:47:42 PM »
perhaps, but it's awful pimp .. About the same cost as a good Epoxy setup
superdaveosbourne
« Reply #31 on: November 16, 2011, 02:37:39 PM »
Fuck your euro trash mouth, Jon.  Epoxy it and call it a day.
« Reply #32 on: November 16, 2011, 08:59:06 PM »
Lol.  Spending some time over at the gatagejournal forums I see.
 :P
« Reply #33 on: November 16, 2011, 10:59:30 PM »
Stealthmode,
any impressions of this?
  No. The only thing I have an impression of is what I've used. I don't have a Masters in all garage flooring + carpet degree.
« Reply #34 on: November 17, 2011, 06:33:15 AM »
Stealthmode,
You have fallen from god to mere mortal in my eyes, Steve.
« Reply #35 on: November 17, 2011, 09:43:44 AM »
Why is there a kitchen in the garage? Is it a women garage???
superdaveosbourne
« Reply #36 on: November 17, 2011, 10:12:09 AM »
Perhaps it's so the bitch can make the man a sammich while he looks at the Porsche.
« Reply #37 on: November 17, 2011, 10:24:04 AM »
He sure as hell doesn't work on it in there. There is barely room to get in it.
This is mine. Excuse the car on the pos trailer. It was a test run to make sure the trailer would work before putting a lot of work into it
stealthiskey
« Reply #38 on: November 17, 2011, 11:23:57 AM »
Gay.  Just called the local Sherwin Williams, they said they couldn't get the tile-clad in anymore because of VOC regulations.   Recommended shieldcrete instead, but it doesn't sound as bulletproof, and only comes in slate or beige not white...
stealthiskey
« Reply #39 on: November 17, 2011, 07:46:38 PM »
Can't get the tile clad in MD or PA.  Gonna check DE and VA.
They recommended the shield-crete, which is basically some weak ass homeowner bull shit, according to the datasheet.  Oh, and it doesn't come in white.
Another option is the Armor Seal 1000.  It's pretty good, but not as good as the Tile Clad.  At least it has ASTM tests performed.
adhesion rated at 350 psi instead of 1050,
hardness at 58 in lb instead of 95,
temp rated at 180F instead of 200,
etc etc.
If I can't get the tile clad I guess I'll do the Armor Seal + Rexthane...  unless you want to ship me some Tile clad, for a nominal fee, of course...
« Reply #40 on: November 17, 2011, 09:51:59 PM »
Yeah, I can ship it.
stealthiskey
« Reply #41 on: November 19, 2011, 09:51:55 AM »
AWWW YEEEAAHHH west virginia dont give a shit about VOCs or the environment, or a lot of things...   :?:
JACER63
  • well shit..
« Reply #42 on: November 19, 2011, 06:23:57 PM »
fuck that is like a 10in slump they poured in the slab.. hope it doesnt crack on you like ralston purina. did they even trowel the floor or just pour it, slick it and leave?
« Reply #43 on: November 19, 2011, 07:51:54 PM »
What is a slump, and what does troweling do?
bluerex
« Reply #44 on: November 20, 2011, 01:06:13 AM »
http://www.lmcc.com/concrete_news/0801/five_minute_classroom_slump.asp
fuck you poured that wet  :?:  Did you use a 4000 mix?
« Reply #45 on: November 20, 2011, 07:56:28 AM »
So, unless there's some sort of voodou plasticizing element taking place here, Jacer's saying they added too much water to make it pour easy at the expense of quality?
Alright, what does troweling do for you?
bluerex
« Reply #46 on: November 20, 2011, 10:49:35 AM »
Exactly.  Troweling it would give the slab a smooth finish.  Typically you wait till the mud is somewhat set up and then trowel it to give it a glass like finish.
mandrel-bends
« Reply #47 on: November 21, 2011, 02:39:08 AM »
The power trowells are the way to go. Last 2 slabs we poured (about 6000 sq ft), they ran those on it every half hour till it cured. Leaves an almost flawless surface.
http://www.mandrelbends.com
« Reply #48 on: November 21, 2011, 01:02:43 PM »
What work did you need to put into it?  Looks perfect to me :mexi:
« Reply #49 on: November 21, 2011, 01:53:29 PM »
It needs tires and I was going to put 2x6's on it to make a deck. Luckily before I dumped any money into it, a guy asked me about storing his car trailer in trade for being able to use it. It sits behind that building where I can't even see it and I use it at least once a month, he uses it about once every 4 months.
« Reply #50 on: November 21, 2011, 03:22:09 PM »
Got mine primed and painted on the weekend
stealthiskey
« Reply #51 on: November 22, 2011, 02:51:54 PM »
Looking good.
Yea it was about a 5" slump, and they troweled it for me.  You might be seeing a lot of water from the truck washout, and the fact there is 36" deep of concrete down there, not just a 4" slab.
Didn't use the power trowel because the area is relatively small.
stealthiskey
« Reply #52 on: December 26, 2011, 10:33:13 AM »
Merry Christmas bitches!
« Reply #53 on: December 26, 2011, 11:26:46 AM »
I have just one thing to say to you.
FUCK YOU!
That looks like it is gonna be a nice space to get some shit done.
« Reply #54 on: December 26, 2011, 02:18:43 PM »
Looking good. I like it
« Reply #55 on: December 26, 2011, 06:00:37 PM »
Looks good. But I would have moved the beam back 1.5" so you could have ran another stud along side of it to create a pocket for it to sit in like it is on the other side. If you were to add another one now it will protrude outward, Meh plenty strong the way it sits though. I imagine your gona use some sort of strap/tie to hold it from kicking out anyways though. Looks good. I only wish I had a garage that big.
jeremy_nash
« Reply #56 on: December 28, 2011, 02:34:22 AM »
What program/software did you use for your rendering?  I like that it has the materials needed listed to help figure out the price.
stealthiskey
« Reply #57 on: December 29, 2011, 08:47:59 AM »
That rendering was done with the free version of google sketchup.  It's not the greatest program, but it is free.  I added the material list in somewhat manually, although it will count the number of "objects" (such as 2x4s) for you.  My biggest gripe is that you can't set a dimension, everything is click and drag something as long as you want, which can screw you if you need different levels of precision.
Turns out I'm no structural engineer either.  I can draw stuff up according to common practice (16" OC etc), but I can't calculate wind loads, and beam strength.  Had to hire one to actually draw up the real plans for permit approval.  The overall dimensions are still the same, but there are some critical alterations.
But to their credit, I was able to view google maps, take a screenshot of my property, measure out the dimensions, rotate and crop it to just my lot, save as jpeg.  Then using sketchup create a rectangle the size of my lot, and import the jpeg image as a texture, thereby pasting in the google maps image right on to the ground.  Helped visualize where everything would go, and how it would fit around the pool and trees.
mandrel-bends
« Reply #58 on: December 29, 2011, 08:06:06 PM »
Why didnt you go another 10 feet wider? Shop space > back yard appeal.
stealthiskey
« Reply #59 on: January 03, 2012, 11:27:23 PM »
Gotta plant some trees in that bare spot, or something.  Good compromise between what I want and what I can afford.
Made some good progress:
View from across my baller status pool
Tyvek and wall sheathing.  May not be what you're used to because I'm using t111 not vinyl siding.
Putting some of the roof up.  No trusses here.  Putting those first beams up was terrifying, also happened to be one of the windiest days this winter.
This one running across is about 16' in the air, and that's a 12 ft ladder.  Put them up with clamps until we could get the first set of rafters into position.
Looking good
Pages: 1 [2] 3   Go Up
