Author Topic: tuning dry shoot  (Read 13856 times)
fuse
tuning dry shoot
« on: October 31, 2011, 11:10:55 AM »
Ok the set up
lsv
e85
750cc injectors
turbo 8 psi
40 shot dry
Tuned out fine with out the shot. When I activate the shot it just brakes up. Have tried changing timing and fuel with no effect. It ether brakes up bad or back fires. Was told maybe I need different spark plugs with spray? Any other ideas?
Re: tuning dry shoot
« Reply #1 on: October 31, 2011, 11:14:36 AM »
Well Mister Rabuck, that depends on what plugs are in the car, doesn't it?
What are your plugs gapped to?  China/OEM/aftermarket ignition?  What wires?
« Reply #2 on: October 31, 2011, 11:31:33 AM »
« Reply #3 on: October 31, 2011, 12:23:39 PM »
E85 and only 8psi, I would figure 7's would be plenty. Then again, if it has a shitty ignitor or coil, no amount of Plug changing will fix that.
fuse
« Reply #4 on: October 31, 2011, 03:00:19 PM »
All stock and ngk stuff. Still on an heat range 6 gaped at .030 they are reading ok dont look to be over heating but should I go with a shorter ground strap? The shot holds for about 2 seconds pulls hard then brakes up no matter what I do.
Could be ignition system but it holds up 8 pounds fine. We start the spray out of boost 3600 rpms, tp 85% or above. We get to about 2 pounds before shit hits the fan.
« Last Edit: October 31, 2011, 03:02:33 PM by fuse »
« Reply #5 on: October 31, 2011, 03:29:54 PM »
Get 7's and gap to .022"-.025"
I bet that fixes it
« Reply #6 on: October 31, 2011, 03:43:32 PM »
I bet that fixes it
I'd do 22 out the gate.
fuse
« Reply #7 on: October 31, 2011, 04:10:21 PM »
K will do.
« Reply #8 on: November 05, 2011, 11:03:54 PM »
I run .020 on 7's on my miata, worked fine with a 100 shot N/A, works fine with with 15-20lbs. Idles smoother with .040 gap though, but won't boost past like 3 psi....
fuse
« Reply #9 on: November 09, 2011, 02:04:10 AM »
Ya the plugs fixed it know I know....
« Reply #10 on: November 09, 2011, 02:11:59 AM »
I was thinking of a dual-gap plug the other day. Maybe that will be the next invention once turbos are on every small econobox. That or rediculous ignition systems.
