Pages: 1 2 [3]   Go Down
Author Topic: 1995 geo metro build log NSFW  (Read 160258 times)
jeremy_nash
Re: 1995 geo metro build log NSFW
« Reply #60 on: September 13, 2015, 10:02:01 AM »
so 5th gear is toast, have a new set of gears and synchro from a trans at the junkyard. gonna swap it in soon.
otherwise, no progress, been driving the hell out of it.  since you clicked here, I might as well post some porn.
« Last Edit: September 13, 2015, 10:04:15 AM by jeremy_nash »
nig nog
  • rhmt equalizer
« Reply #61 on: January 19, 2017, 06:00:45 PM »
bump
1991 F-150 351W E-cam hedders
1988 Merkur XR4ti .50 T3/T4
2003 S2000
jeremy_nash
« Reply #62 on: December 11, 2019, 09:57:53 PM »
So the damn thing is sitting in the field, won't start, have fuel pressure, megasquirt is telling the injectors to fire, it is running batch fire, and checked for voltage while cranking, and it is pulsing power to the injectors, but won't start.  Spray carb cleaner in it, and it will start, but dies when it runs out of carb cleaner. What are the odds all four injectors died/stopped up at the same time?  The gas in it is a few years old, it had been started about a month ago.
« Reply #63 on: December 12, 2019, 12:29:25 AM »
Local dirt car had same issue.
Swap in some fresh fuel.
jeremy_nash
« Reply #64 on: June 05, 2023, 09:18:30 PM »
so I got around to swapping in the 550cc injectors I had bought when i decided that I would end up being E85 friendly.  it started right up, ran about 10 seconds, and died.  I was so happy for like 9 seconds.  turns out it was just running on the fuel I spilled while swapping the injectors.  I'm pretty sure that mice chewed on some wires somewhere in the harness.
« Reply #65 on: June 06, 2023, 11:10:02 AM »
Oh shit! So are you going to fix?  :noel:
jeremy_nash
« Reply #66 on: June 06, 2023, 12:08:20 PM »
Eventually I will be, but not a huge priority ATM.
jeremy_nash
« Reply #67 on: May 21, 2024, 07:43:06 PM »
So I still haven't worked on it at all.
I hope you are all as disappointed with the lack of progress as I have been.
MTZ
  • Webadmin
« Reply #68 on: May 23, 2024, 10:55:34 PM »
« Last Edit: May 23, 2024, 10:57:36 PM by MTZ »
its called toering
jeremy_nash
« Reply #69 on: May 25, 2024, 07:07:16 PM »
« Reply #70 on: May 29, 2024, 11:43:02 AM »
listen fat
Pages: 1 2 [3]   Go Up
