Author Topic: Extended Strut hats  (Read 20709 times)
Extended Strut hats
« on: April 13, 2009, 09:01:35 AM »
Pretty basic mod. Enjoy...
Riding around like a toolshed with bouncy suspension is not cool. The car I am building will be running  Koni's and coilovers (GC"s) poly...ect..  Primary use will be autocross and track events
Cutting 1" piece of pipe
Welded, ready for finishing
Belt sanding (gotta make it pretty for Powdercoating)
Comparison of stock vs extended
2 done , 2 to go
Next up rear suspension limiters
Re: Extended Strut hats
« Reply #1 on: April 13, 2009, 09:29:02 AM »
interresting  ;D
Curious on rear limiters  ;D
« Reply #2 on: April 13, 2009, 09:52:54 AM »
I am just copying a design on the rear limiters that JD came up with. I had the thread saved from the old site, but it's long gone. Basically use old bump stops and threaded rod. I am going to built them this weekend.
Ground control sells strut hat extenders for  $200, They have speherical bearings in them which is nice, but at $200? I can spend it better elsewhere. (hoosiers)
« Reply #3 on: April 13, 2009, 12:25:53 PM »
I never said threaded rod.  Threaded rod is expensive.  I said cut and weld old shock shafts.
« Reply #4 on: April 13, 2009, 12:32:02 PM »
I am taking the info from an old HMT thread that wasn't yours , but the author gave you credit.
I will try using old shock shafts.  I was going to use cut up old strut hats for the bushing cup's so that the bump stops had somewhere to fit inside.
I need to be able to disconnect these fairly easily.
« Reply #5 on: April 13, 2009, 12:33:48 PM »
Who was the author?
« Reply #6 on: April 13, 2009, 03:07:40 PM »
It's actually sitting on the hood of my corvair which slopes. They are dead  level... I know..I used a level :)
