Pages: [1] 2 3   Go Down
Author Topic: 92_eg_c1's build thread UPDATED 2013  (Read 79598 times)
92_eg_c1
« on: January 19, 2012, 12:18:37 AM »
Dont know if i really wanna post my old post but whatever.
As some of you may remember, i posted this build a few months ago before rhmt lost some data. Thought i might share it agian from beginning to start. I started off with a single cam vtec. d16z6 i got for a good deal. Always always wanted to do a hmt setup and then years later i find RHMT so i thought fuck it im gonna slap some shit together and see what happens. enjoy.
OH AND YES I DID MAKE A NEW INTRO THREAD.  8)
I WANTED TO BE BOOSTED ON THE CHEAP CHEAP.
PIECED TOGETHER THE KIT FOR LESS THAN 3OO.OO
D16z6 w/ 80xxxx miles
B16 throttle body
HF manifold
BMR turbo adapter plate
little dinker TD04L wrx turbo
egay ching chong intercooler
egay oil line
craigslist auto meter boost gauge
misubishi DSM 450cc injectors w/ resistor box
HSK SSQV bov
home made turbo piping
2in charge pipe
3in downpipe
chipped & socketed p28 ecu
intec racing basemap
my 1993 eg si
my small ass turbo tdo4l off of a wrx
lowes rubber fittings lol
My pos charge pipe
down pipe pictures
weak ass videos. really short clips..
http://youtu.be/ylJ3RSmOV04
http://youtu.be/StpxVt6NTYA
edit//
This was a fun project to do. but sadly i had to cut it short. im in need of money so now im forced to sell the motor tomorrow and probably throw the full turbo kit on craigslist within a few days. sad to see it go cus even though it doesnt look like much i put alot of bs sweat and tears into this damn project. but anyways i didnt make any new videos when i maxed the turbo at 14psi. that shit was gangster as fuck. full boost at around 3200rpm all the way to redline (7000rpm) shit was a really fucking fun ass street car to drive. welll thats my ghetto nigg build for ya.
My next project will probably be something bigger and better. might throw in the b20 in the hatch and go b20vtec turbo. ill keep this thread updated with bs. thanks for lookin my niggs
About 6 months after i sold the single v turbo i took my stock b20z out of integra and stuck it in the hatch. B20 block, GSR tranny. Needed a head so i asked around and finally found one. Pretty much after that, i bought crower 403's, dual valve springs and tit. retainers, skank2 cam gears, thermo intake manifold gasket, blox intake manifold,67mm STR tb,1000cc precision injectors, HKS bov and other random shit. just picked up an intercooler and piping the other day. mocked everything up and now its pretty much ready to go.
Thermo gasket
Didn’t fit
hard to see the extended studs but its there.
Old setup vs new
 :noel: " i support single moms "
exhaust
intake
pretty much done with the new setup. i have new pictures as soon as it stops snowing. still need a fuel pump, catch can,tap my oil pan and little other misc shittt. let me know what you guys think....
« Last Edit: March 07, 2013, 04:33:32 AM by 92_eg_c1 »
Re: 92_eg_c1's build thread
« Reply #1 on: January 19, 2012, 12:41:35 AM »
DO WORK!
DasPoop
« Reply #2 on: January 19, 2012, 01:00:10 AM »
92_eg_c1
« Reply #3 on: January 19, 2012, 02:05:30 AM »
My goal is 350whp built head stock block. I just hope i dont have too much lag?... kinda scared of my stock b20 rod bolts snapping but that was my mistake to not have the block beef up before i through it together. I should have gotten a smaller turbo but watever. fuck it. lol  :noel:
Im havin mixed emotions on the walbro 255. alot of people are saying ill be fine and others are saying i need to get one.
http://www.hondatuningmagazine.com/features/0206ht_honda_fuel_systems/index.html
^ says i dont need a fuel pump, i know i shouldn't believe everything i read but what do you guys honestly think? Do i really need a fuel pump? even with my 1000s?
« Reply #4 on: January 19, 2012, 02:14:16 AM »
you need to replace and rewire teh pump...
« Reply #5 on: January 19, 2012, 09:31:23 AM »
Yes fuel pump and rewire w/ bigger hot wire.  :noel:
« Reply #6 on: January 19, 2012, 10:20:35 AM »
Don't forget the ground
20 year old spot welded unibody makes a shitty ground.
92_eg_c1
« Reply #7 on: January 19, 2012, 07:05:21 PM »
so get a walbro 255lph fuel pump and rewire like this?
http://www.raktron.com/fuel/rewire1.html
« Last Edit: January 19, 2012, 07:29:27 PM by 92_eg_c1 »
« Reply #8 on: January 19, 2012, 07:39:39 PM »
yep, i have used that write up before too...
you can try the stock pump, but its a waste of time. if i remember right JR (EM1 w/H22) made 250whp and maxed out a DOHC pump. should get more from it if you rewire it (did that to the del sol), basically overclocks it giving it a full 14v...
DasPoop
« Reply #9 on: January 19, 2012, 08:22:20 PM »
only thing i would change about that write up is leave the relay inside the car. As far as the pump its hit or miss. some pumps will flow enough for 300hp some shit out early. what sort of fuel pressure are you going to run?
« Reply #10 on: January 19, 2012, 11:29:48 PM »
I just saw something about injector size vs pump combos. They had a sidebar saying Walbro pumps car vary by 15%, so I can see stockers with greater variance. In any case, get the walbro but don't spend a week rewiring it. If you're maxing your pump out and can tune out higher fuel pressure, then go for it. If you're running high base pressure, then you definitely will want to rewire.
92_eg_c1
« Reply #11 on: January 20, 2012, 08:34:25 PM »
Some random shots i took earlier today.
you guys see my ghetto red oil feed line? LLOLL
But fuckk im broke now lol wheres the cheapest i can find a walbro 255? LOL honda tech from one of the sponsors said 95 shipped but im wondering if any of you guys can get it cheaper?  looks like i need to stop buying beer everyday to save up for a pump lol
« Last Edit: January 20, 2012, 08:45:25 PM by 92_eg_c1 »
« Reply #12 on: January 20, 2012, 11:40:31 PM »
buy a used pump, or i think maybe an EVO pump works?
92_eg_c1
« Reply #13 on: January 21, 2012, 12:33:25 AM »
You sir are correct. I did a little research right after i read this and stock evo pump is good up to 400whp! looks like im on the hunt for a stock evo pump.
« Reply #14 on: January 21, 2012, 12:45:57 AM »
don't the supra pumps work also or was that for ef's?
« Reply #15 on: January 21, 2012, 12:49:11 AM »
Aren't supra pumps physically too big? Ask JD, he knows where to get a CDM pump that will work for half the price. You will have to sell your soul to buy it though.
« Reply #16 on: January 21, 2012, 01:01:39 AM »
I use one from ebay that is the same source as xenocrackhead.  :noel:
Cost me $50 each, I have two.
With stock FPR I wash pegging 200psi gauge, had to get a aftermarket FPR.  :noel:
« Reply #17 on: January 21, 2012, 03:19:23 AM »
supra pump is fuckin huge... i have one sitting here for the GVR4. might work on an EF... i think i remember those being bigger.
« Reply #18 on: January 21, 2012, 07:05:32 AM »
Can you point me to an auction for the same pump? I need one for my flow bench.
Edit: is this it? http://www.ebay.com/itm/HIGH-PERFORMANCE-UNIVERSAL-255LPH-FUEL-PUMP-INSTALL-KIT-/230733587268?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item35b8cb2344
Looks like the same everything as xeno, minus the herpes: http://www.xenocron.com/images/gss340.jpg
« Last Edit: January 21, 2012, 07:08:48 AM by HiProfile »
« Reply #19 on: January 21, 2012, 09:59:43 AM »
Looks like it except both of mine came with a shitier sock. I did not see any numbers stamped on the side to be sure.
92_eg_c1
« Reply #20 on: January 27, 2012, 03:19:15 AM »
Almost ready for my street tune. Just gotta get my cams degreed,buy a 2.5bar map sensor, spark plug, spark plug wires and fluids.
92_eg_c1
« Reply #21 on: January 29, 2012, 04:03:58 AM »
http://youtu.be/0LQpglZYuaw
http://youtu.be/vBZ12grukiQ
should be getting my dyno tune soon, street tuning went great. had NO problems except for police.  :noel:
fuck lynnwood.  8)
« Reply #22 on: January 29, 2012, 12:55:57 PM »
What were the popo problems?
92_eg_c1
« Reply #23 on: January 29, 2012, 05:30:38 PM »
Might have over exaggerated a little on that part haha but lynnwood is hot. Right before we were gonna do 3rd gear and 4th gear pulls a cop always passes us. The main road next to my house is pretty much the only stretch i got around lynnwood. Need to hit the dyno soon after i fix my alt. wiring and get a new oil feed line my ghetto lowes hose line is all that crackin haha
I think it was like 5k full boost @ 10lbs with no knocks no nothinggg, NOT toooo bad. i didnt mind it at all except for my redline being 7k lol my tuner said 8k would be fine but i wanted to be on the safe side for now. Still need to hit a dyno.
« Reply #24 on: January 29, 2012, 06:26:41 PM »
lol, lynnwood cops are rough.
i was doing pulls out by my place, on a lake stevens/sno county/wsp patrolled highway. i swear every time i would get back down to the speedlimit i would fly passed one.
you see the NW RHMT Dyno day thread? all else fails, you can just make some pulls that day... or do some more lol. but be there either way!
« Reply #25 on: January 29, 2012, 07:40:28 PM »
When I was up in the Lynnwood area last year Daspoop used the HOV lane of I-5 to tune my car and do some pulls.  :noel:
92_eg_c1
« Reply #26 on: January 30, 2012, 04:10:55 AM »
I feel like this is a really stupid question to ask but whatever... I already know my turbo is to big for my setup but is there any way possible to make my turbo spool a little sooner?
« Reply #27 on: January 30, 2012, 05:22:42 AM »
nos
« Reply #28 on: January 30, 2012, 08:05:04 AM »
Nos
Two step
Brake boosting
Have a huge compressor blow into a medium size compressor  :noel:
92_eg_c1
« Reply #29 on: January 30, 2012, 09:02:40 AM »
What about with tuning? Is there anything my tuner can do?
Pages: [1] 2 3   Go Up
