Author Topic: fakdblamtd 11/30/12 update nigs  (Read 46347 times)
hotrex
« on: January 19, 2012, 06:56:57 PM »
new b/p build. 97 mtd chassis  too much bs to list.   just know ive got a vanguard that will make 50hp on gas going in it.   front and rear brakes the whole shebang.
« Last Edit: November 30, 2012, 09:25:19 PM by hotrex »
Re: fakdblamtd
« Reply #1 on: January 19, 2012, 07:34:54 PM »
so, its a go kart that looks like a lawnmower?
i lose interest at that point. the cool thing about lawnmower racing to me is making something that was meant to do 3-4mph go 30mph. its sketchy as hell cause the brakes suck, the steering geometry is stupid, and the center of gravity is way off.
hotrex
Re: fakdblamtd
« Reply #2 on: January 19, 2012, 07:40:17 PM »
its still very much a lawn tractor, still uses factory style belt drive with push pull clutch, must use mower turf tires, must use a lawnmower engine.  this class is a verticle vtwin of not more than 20hp.  internal mods are unlimited but must retain stock outward appearance.  the chassis is all mower with some 1x1 and 3x4 box steel reinforcement for rigidity.  trust me it rides like a mower.  uses a walk behind mower tranny,  and all mower sheetmetal
Re: fakdblamtd
« Reply #3 on: January 19, 2012, 07:43:35 PM »
you can put 50hp down with a v belt?
hotrex
Re: fakdblamtd
« Reply #4 on: January 19, 2012, 07:48:17 PM »
yea custom aluminum pullies and a aramid cord belt.  i run a billet ball b earing push pull clutch and a HEAVY clutch spring.  yes it holds.
JACER63
  • well shit..
Re: fakdblamtd
« Reply #5 on: January 19, 2012, 07:59:17 PM »
so there's no turbo? meh.....
does it run at 66% throttle ftw?
hotrex
Re: fakdblamtd
« Reply #6 on: January 19, 2012, 08:21:15 PM »
it runs in and out of your moms cauliflower anushole
Re: fakdblamtd
« Reply #7 on: January 19, 2012, 08:32:54 PM »
That is pretty damn wicked IMO.
DasPoop
Re: fakdblamtd
« Reply #8 on: January 19, 2012, 08:35:47 PM »
i dig those little disks
Re: fakdblamtd
« Reply #9 on: January 19, 2012, 08:45:55 PM »
hotrex
Re: fakdblamtd
« Reply #10 on: January 19, 2012, 08:52:57 PM »
10 inch rear rotor with 2 piston caliper.  single piston front calipers with 3.5 inch rotors.  twin mcp 3/4 master cyls with  remote adj brake bias
DasPoop
Re: fakdblamtd
« Reply #11 on: January 19, 2012, 09:04:02 PM »
what sort of trans mods are required to make a mower do 30? i would imagine different final drive?
hotrex
Re: fakdblamtd
« Reply #12 on: January 19, 2012, 09:14:00 PM »
pulley swap.  8 inch front and a 5 or 4 inch tranny pulley
Re: fakdblamtd
« Reply #13 on: January 19, 2012, 09:21:32 PM »
Any details on the engine?
 ;DDD
hotrex
Re: fakdblamtd
« Reply #14 on: January 19, 2012, 09:50:09 PM »
30ci briggs vanguard v twin.
shaved pistons
arc aluminum long rods
arp hardware
massive headwork
oversize valves
twin valve springs as
cromoly pushrods
roller rockers
huge roller cam
billet aluminum flywheel
hogged out 40ci vanny intake mani with modded flanges
40ci intek 2bbl carb rejetted bored with new throttle plates and some secret sauce that i wasnt even told about.
shaved heads for comp kart fuel pump and some other shit im probably forgetting.   but stock 16hp motor will roll almost 50hp on gas
DasPoop
Re: fakdblamtd
« Reply #15 on: January 19, 2012, 10:50:09 PM »
what sort of rpm do you spin them too?
What sort of setups do the "unlimited"? mowers use? i remember watching them on tv and they had cent. clutches and shit.
Re: fakdblamtd
« Reply #16 on: January 19, 2012, 10:56:46 PM »
I'd guess 50-100% stock redline.
I'm curious if you're restricted to belts. Chains take less power to run.
hotrex
Re: fakdblamtd
« Reply #17 on: January 20, 2012, 12:11:08 AM »
yes my class is restricted to belts a push pull clutch and a shiftable transmission of lawnmower origin.
my motor will be a 8k rpm motor.    stock gov is set at 3650
hotrex
Re: fakdblamtd
« Reply #18 on: January 20, 2012, 12:12:26 AM »
the class you saw was the f/x class.  anything goes motor must be 465cc or less single cyl ohv.  fastest mowers u can run.  problem is noone runs em around ct so i built a b/p
Re: fakdblamtd
« Reply #19 on: January 20, 2012, 12:14:43 AM »
badass rexy!
7808
Re: fakdblamtd
« Reply #20 on: January 20, 2012, 04:54:13 AM »
what kinda blades you runnin  :noel: seriously tho , i can just throw differnt pulleys on my rider and if i want to i can hit 30 goin to the liqour store after i mow?
Re: fakdblamtd
« Reply #21 on: January 20, 2012, 03:11:24 PM »
If you want to be a double amputee
to hit high speed with a stock engine you have to really gear it up.  10 or 11 to 4 pulley ratios.  Aka 3x speed to the blades, 6x to the rear, etc.  Remove the blades first... Lol
« Last Edit: January 20, 2012, 03:15:54 PM by jabberwock »
Cmak
Re: fakdblamtd
« Reply #22 on: January 20, 2012, 08:29:15 PM »
thats fucking sweet, I expect we'll be seein' some rippers?
Re: fakdblamtd
« Reply #23 on: January 20, 2012, 08:45:23 PM »
odds are it will catch fire at 66% throttle and then shoot coolant in his eye....... even though it doesnt have coolant.
Re: fakdblamtd
« Reply #24 on: January 20, 2012, 08:54:34 PM »
fucking el oh el
Re: fakdblamtd
« Reply #25 on: January 20, 2012, 09:51:23 PM »
I'm guessing brake fluid in the eye as he's bleeding them, with 66% pedal used.
hotrex
Re: fakdblamtd
« Reply #26 on: January 22, 2012, 10:14:53 PM »
small amount of work today, got the dual master cyls mounted along with brake pedal finished and brake bias added.
hotrex
Re: fakdblamtd
« Reply #27 on: February 05, 2012, 06:48:27 PM »
rolling chassis is done and wired.  small odds and ends left.  finish work.   think the rig came out well.  now sitting back and waiting for the magic from ron at Ace race engines to arrive in the mail...  common big hp.   yee haw!
heres the complete roller
brake bias master cyls and shot of my rad shifter
turf pros i just scored off of drew burton.
shot of the rear end with turf pros and notice the rear caliper and rotor have been moved inboard to leave room for tire selection ect.
dash minus digatron
ec brakes tucked in the new douglas 7.25s and cheng shin meat
all wired up minus digatron
deck halves on...
Re: fakdblamtd
« Reply #28 on: February 05, 2012, 09:33:35 PM »
As big of a faggot as you are thats fucking sick Josh. I like it... Looks like more fun than Johnmichaels sloppily lubed anus at a prison party
hotrex
Re: fakdblamtd
« Reply #29 on: February 05, 2012, 10:02:51 PM »
the big hp ones are just like a fast turbo honda.  you know the feeling you get when u rip it...   honestly the most fun ive had, this tractor will rip and handle and stop should propel me to a class championship.   well see...    thanks man
