Author Topic: Integra Sedan b18a + hy35 **NSFW**  (Read 34311 times)
Dirty_Mech_Style
« on: April 08, 2012, 01:39:24 PM »
Just now posting up on here been lurking the site for at least the last 7 years, used it for an information base and never joined.  I ended up with a 90 integra sedan that i figured would be pretty fun with a holset on it.  If anyone is down to lend a hand in the next couple weeks with the head removal or fab im pretty new to hondas but im pretty well read in them, Im located in oak harbor.  So here is what ive assembled so far.
parts:
chipped and socketed the stock pr4
hulog and moates burn2 (thanks craig for the fast shipping and service)
lc-1 wideband and db1 guage
evo 560cc injectors (free)
turboedit with extratables and ecucontrol running ng63
revhard manifold
turbonetics evolution wastegate
holset hy35 (thanks 88dx)
greddy type rs bov (free)
evo 9 fmic (free)
stealthmode performance oil line kit (with adapter to holset)
civic half rad
a set of je 10:1 81.5mm pistons that i stole from a guy in cali for 75 bucks, used but had a machine shop look at them said they were good to go, saving them for when this pile of garbage explodes.
im sure there is more ill update after ive made the chargepipes and downpipe, i have a lincoln wirefeed full of fluxcore... I would like to backdoor one endtank of the intercooler if anyone has the ability to weld aluminum i would be willing to provide beer/coke/strippers.  I still need a few things, mainly an oil drain flange for a holset if anyone has one.
was curious to see how it fit in there, This week im pulling the head and its getting the arp's and a fresh honda gasket.
2000 shee and my mtn bike, 98 xr400... not stock.
The big toy and the mobile electrical fire... at least its a diesel
Sorry for the weak ass porn, wife is right next to me.  no pics of said wife sorry  :)
« Last Edit: April 08, 2012, 01:44:16 PM by Dirty_Mech_Style »
Your local T-56/F414 mechanic
Re: Integra Sedan b18a + hy35 **NSFW**
« Reply #1 on: April 08, 2012, 02:08:27 PM »
Good start, like to see more on the build and more porn,
But decent first post, keep it coming   :noel:
Dirty_Mech_Style
« Reply #2 on: April 08, 2012, 04:49:07 PM »
Yes more to come i just pulled the bumper/ac/and hood off of it yesterday so this is just the beginning.
Im kinda debating not doing the arp's until winter, i have a 9 psi spring in the gate right now and thats all i intend to run until i build a block for it.
« Reply #3 on: April 08, 2012, 07:02:46 PM »
dont worry bout head studs till you blow the fucker up. not needed for 9psi.
catsman50
  • perpetual noob
  • im a terrorist
« Reply #4 on: April 08, 2012, 08:02:29 PM »
put a few tees in the wastegate line and make it a few pounds more if you got balls :noel:
FUCK VOLKSWAGEN'#039#039S
Dirty_Mech_Style
« Reply #5 on: April 08, 2012, 08:09:39 PM »
ill keep it running off wastegate until i get more comfortable tuning, isn't the old saying 10 lbs will turn ya out  :noel:
« Reply #6 on: April 08, 2012, 10:43:40 PM »
d+10lbs= turn ya out
ls+20lbs= fuckin fun ask me how I know
« Reply #7 on: April 09, 2012, 02:47:56 PM »
Solid post!
« Reply #8 on: April 09, 2012, 04:08:18 PM »
Says the guy that has yet to boost a car and runs a 75 shot.  ::)
I saw something about pulling the head, if you are then I would go ahead and do the arp's. If you aren't, then I would just wait for the build.
« Reply #9 on: April 10, 2012, 09:16:32 AM »
Look at boosted 00 black si build, 20psi on a stock ls :noel:
« Reply #10 on: April 10, 2012, 04:24:59 PM »
But it wasn't his first time around the block.
« Reply #11 on: April 10, 2012, 11:18:37 PM »
On my last holset I bastardized a t3 drain and welded it to some flat stock and drilled it to fit. O0
Dirty_Mech_Style
« Reply #12 on: April 11, 2012, 09:06:19 AM »
How did that work for you??  I have a tdo4 suby drain but the id measures like 5/8, and the holset is right at 3/4.  From what i read they like their drains to be large.. maybe ill give it a try
« Reply #13 on: April 11, 2012, 12:30:22 PM »
Every turbo wants a huge free flowing drain.
« Reply #14 on: April 13, 2012, 10:33:33 PM »
I just used a standard drain flange fits fine. drain hole is close to same size.
Dirty_Mech_Style
« Reply #15 on: April 13, 2012, 11:11:15 PM »
tacking the downpipe, 2.5 tubing due to the fact columbia manderal bending doesnt sell a 3" holset flange.
here is where i stuck a fork in it for the night.  retapped the oil inlet of the holset to accept 12x1.0 so my oil feed is dealth with leaving return to be done another day.
« Last Edit: April 14, 2012, 12:18:59 AM by Dirty_Mech_Style »
« Reply #16 on: April 15, 2012, 08:24:14 AM »
I wish my turd still looked decent like that. All the salt and being hurried in snow every winter is beginning to take its toll.
Nice build.
Dirty_Mech_Style
« Reply #17 on: April 15, 2012, 08:25:45 PM »
update again, did some good old sunday afternoon fabricating.  made an oil drain flange and dude it intake the intercooler pipe today, didnt have anything to cut a hole for the bov so i used my wirefeed as a plasma cutter  :?:.  Everything seems to come out good with no holes to be seen.  Parts are on order and next weekend it should start.  baller ass oil drain
« Reply #18 on: April 16, 2012, 09:37:25 PM »
Boost +porn= WIN :noel:
Dirty_Mech_Style
« Reply #19 on: April 21, 2012, 02:37:50 AM »
so when i pulled my oil pan to weld in a drain line, i found a bolt on the #1 main bearing cap backed all the way out.  So i took it out and found the head of the bolt was broken causing it to back out obviously.  pulled the cap and looked at the bearing, it looked fine and there was no abnormal wear patterns or anything.  Then i pulled the next main bearing cap (next down the row).  and found this.  Pretty much am wondering whether i should just replace main bolts and slap it back together, or is this bearing even worth fucking with?
Dirty_Mech_Style
« Reply #20 on: April 22, 2012, 08:10:28 PM »
did some more today, chargepipes are all done.  Oil feed and injectors are taken care of, even made a basemap to start it up on.  this week i should get the drain together and dp finished and hooked up to the rest of the exhaust.  Still have to get the radiator back in, there a bunch of abs shit under the battery trey that needs to go so i can get the gangster lean goin on.  anyone know how to get rid or that shit?
« Last Edit: April 22, 2012, 08:12:03 PM by Dirty_Mech_Style »
« Reply #21 on: April 22, 2012, 09:15:15 PM »
i cant really tell from the pic but bearings are cheap. i would stick some new ones in it.
Dirty_Mech_Style
« Reply #22 on: April 24, 2012, 03:39:10 PM »
Meh i ordered new bolts yesterday just gonna slap it back together, rev limiter is gonna be set at 7500 so hopefully itll last.  If not i have an excuse to build a 10:1 ls block  :noel:
JaredKaragen
« Reply #23 on: April 24, 2012, 08:40:59 PM »
I've tuned several large turbO stock ls cars...
Most have taken 15psi easy; and one took 21 on pump with a h1c....
Rippin like mad;  only one blown headgasket between all owners, and he let his car overheat so there u go :)
« Reply #24 on: April 24, 2012, 11:08:47 PM »
I run 20psi outa a h1c daily pretty fun
Dirty_Mech_Style
« Reply #25 on: April 30, 2012, 08:16:05 PM »
oh yeah car is done, motorola 2.5 bar on order, 15psi rippers soon to come  :noel:  it scoots for being on a basemap at 9 psi
NoPistons!
« Reply #26 on: April 30, 2012, 08:45:15 PM »
Why i like it.
1.   b18a!
2.   4 door 2g!!!!!!!!!  Clean for the age of the car.
3.   10:1.  got popcorn for that.  Sounds like you know your way around tuning enough to make that happen i hope.   High compression turbo builds are always interesting to see.   As far as i'm concerned that's the only way to do it.  minimal lag and good off boost throttle response is where it's at!
4.   Pie cut downpipe!
ARP bolts are like flack jacket in cod black ops.  That's pretty crazy to see them snap like that and not have catastrophic failure go down.
Dirty_Mech_Style
« Reply #27 on: April 30, 2012, 09:42:49 PM »
they were actually factory honda bolts, whole motor is untouched as of now.  Well see how well my tuning skills are soon enough haha
« Reply #28 on: May 01, 2012, 12:04:07 AM »
wanna see how she does
NoPistons!
« Reply #29 on: May 01, 2012, 11:08:18 AM »
Nah, i meant arp's ARE the shit.   I assumed factory bolts.  They have a much lower sheer tolerance.   Good luck.  Wanna see this bitch  spin 3rd from a roll!
